TSW202 doesen’t forward IPv6 Multicast ff02::1 betwen ethernet ports.
Apologies for the delay. Could you please confirm which firmware version is currently installed on your TSW202? If it’s an older version (<1.5), make sure to update it to the latest available version, 1.5.1, and then check whether the initially described issue with IPv6 multicast forwarding between is still present.
If the behavior persists after updating, feel free to let me know.
The Product code is TSW20200XXXX with firmware version TSW2_R_00.01.03.1.
OTA display “No update available”
I have found the new version 1.05 on https://wiki.teltonika-networks.com/view/FW_%26_SDK_Downloads#TSW_Switches and will update manual next days.
Same problem with new firmware TSW2_R_00.01.05.1.
