TSW202 doesen't forward IPv6 Multicast ff02::1 again
Continuing the discussion from TSW202 doesen’t forward IPv6 Multicast ff02::1:
Already again with TSW2_R_00.01.09.1
And dropbear ssh is not listen on ipv6.
For troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 18961.
I am also having the same problem only on TSW212 switch, but from what I gather they both use the same firmware.
I hope we will se a public solution to this issue.
same issue here for SWM282 with SWM2_R_00.01.09.1 again. Seems to be the same as fixed in SWM2_R_00.01.08, see also SWM282 doesen’t forward IPv6 Multicast ff02::1 .
Best regards
Just confirming that IPv6 (on connected devices) is broken on SWM282 with these FW versions:
  • 00.01.07.1
  • 00.01.09.1
  • 00.01.10
It appears to only work in the 1.8 branch (00.01.08.3 is OK for example). We bought five SWM282, one of them is in the center of a star topology, and it was rather confusing to debug that only this “central” switch would get an IPv6 address from the router, while other switches (and also all other devices connected to any of these switches) would simply not work over IPv6.
Is there a chance to improve your QA testing so that it includes end-to-end IPv6 deployments?
Why were the fixes from the 1.8 not kept in the 1.9 and 1.10 releases?
Hello, @jkt ,
Apologies for a delayed response and thank you for your observations and for the information you have provided so far.
For further troubleshooting, we will require some additional, potentially sensitive information, including the device troubleshoot file. Please note that this file may contain confidential data such as passwords, public IP addresses, serial numbers, and other device-related information.
To ensure this information is submitted securely and avoid exposing it publicly on the forum, we have sent you a form to the email address registered with your forum account.
When completing the form, please enter 18961-1 in the Ticket ID field.
Once you have submitted the form, please let me know so we can proceed with the investigation.
Thank you for your cooperation.
SLAAC started working with FW version 00.01.10.4.
Greetings, @jkt ,
Apologies for the delay,
From your last message, it seems that the latest firmware release resolved your issue.
Please let me know if you still require our assistance regarding this matter.
