SWM282 doesen’t forward IPv6 Multicast ff02::1
my SWM282 is not forwarding IPv6 Multicast messages ff02::1 between the ethernet ports.
The router is connected to port 1 and sending Router Advertisements, which can be monitored with tcpdump, but they never reach port 3 and port 4.
The switch is running on the latest firmware SWM2_R_00.01.07.1_WEBUI.bin . It seems similar to this thread TSW202 doesen't forward IPv6 Multicast ff02::1 .
Is that a known issue also for the SWM282? Is there any solution, maybe also via SSH?
Best regards
For troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 16694.
