Hello. I just received a TRB142 and I’m trying to use Serial Over IP in TCP Client mode. It works at its first connection, however if the receiving socket is closed, the gateway does not seem to try reconnecting. How the Reconnection time and the Inactivity timeout are supposed to work? I did not change their default values.
Sorry for any inconvenience caused by the issue. As a temporary solution, some users have resolved this issue by downgrading to TRB1_R_00.07.06 firmware version. However, since it is not currently available, I recommend trying to downgrade to either TRB1_R_00.07.05.4 or TRB1_R_00.07.06.2 firmware versions, which you can download from this link.
Thank you for your understanding and patience.
The issue regarding the Serial over IP Client not automatically reconnecting should be resolved with the release of firmware version 7.8.
Thank you for your patience!
