Could you please clarify a few things? When the issue occurs, does the WiFi not appear at all, or is it still available, but when devices connect, they get no internet connection?
Does this happen only with WiFi, and if you use an ethernet cable, do you get the internet connection?
What devices are being used to connect to the WiFI on? Does the location of RUTX50 change, or is it always in the same spot? Are you using the default WiFi antennas that came with the router and if not, could you please provide details about the antennas being used? Are they properly attached to the device?
You can download a troubleshoot file from the device, which would contain all the logs, just keep in mind that you would have to do so, after the issue occurs and before any reboot takes place, since the logs are saved in the device’s RAM and delete after a reboot.
To get a troubleshoot file:
- Log in to WebUI
- Press on System → Maintenance → Troubleshoot
- Scroll down to Troubleshoot section and press “Download”
For troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 15988.
Once you fill out the form, I will reach out to you via email, and when the issue occurs, you will be able to send me the file.
