TRB501 signal instability and passthrough / bridge anomaly
@Justinas
Following today sessions, the anomaly to be solved are these two:
a) with high signal strenght stable in good/excellent range, antennas in open sky, no obstacles (and where other 4G modems works well) TBR501 shows RSRP and SINR instability in their rapid fluctuation, confirmed by the same aspects in evaluating latency in recursive ping, in idle with no download or upload and also forcing a single 4G band;
b) both passthrough and bridge configuration, after many tests TRB501 doesn’t transfers mobile WAN public IP to the ethernet port.
As suggest by Vilius in this post:
TRB501 Modem Instability Fixed After Firmware Update? - #6 by Jagger
is it possible to evaluate the changing TRB501 with RUTM30 ?
May I have a ticket ID ?
Reference to post no.18939 and no.18437
Many thanks,
@Justinas
Can you give me an estimate of the expected resolution time ?
Tks,
For troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 19345.
Kind regards
@Zilvinas
I have already filled the form.
Do you need a desktop share now ?
(Justinas, yesterday, has already taken the troubleshoot file and other TRB501 info)
We have passed this issue to our RnD team and will let you know once we receive any feedback from them.
We appreciate your patience.
Žilvinas.
Received @Zilvinas
Tks,
Hi @Zilvinas
Can you help me with an estimated resolution time ?
Without passthrough I can’t use the TRB501 at all.
Tks,
Hello Mik,
Please check your email , I have sent you further instructions regarding this case.
Žilvinas
Hi @Zilvinas
Could you explain exaclty what file you need ?
TKs,
Hi @Zilvinas
Which file ?
Apologies for misunderstanding i send it all relevant information in to your email.
Žilvinas.
Hi @Zilvinas
today, will be my lucky day ?
Hello mik,
We have asked our RnD team for an estimated timeframe regarding when they may be able to provide more information about your issue. We will let you know once we receive a response from them.
Thank you for your patience.
Žilvinas.
Hello @Zilvinas
did RnD give you a resolution date ?
tks, michele
Hi @Zilvinas
I bought TRB501 for passtrought / bridge, asking before to your tech support (web form) if TRB501 can be the correct product for passthrough or bridge …and after more then a month I still have an unusable device.
Michele
Hi @Zilvinas
any news ?
@Zilvinas
I am very dissatisfied with the indifference in solving this issue
Hello @mik,
We have forwarded the information from your email to our R&D team. As soon as we receive any feedback from them, we will let you know.
We appreciate your patience and understanding.
Hello @mik,
Our R&D team has informed us that, starting with firmware 7.24.1, hardware offloading will be enabled in passthrough mode, which should improve its performance.
Good day @Marija
do you have an estimated date for firmware 7.24.1 ?
It will be possible to have the public WAN IP address turned on the ethernet side, in passthrough ?
(now, bridge and passthrough (both) …we do not have public IP on ethernet port; this is also an anomaly with results in unusable TRB501 gateway)
tks, regards, michele
