Hi Vilius,
Thanks for your response. My intended use is as a failover WAN on a UniFi network so pass through/bridge mode are important to me. I’m aware of the pass through/bridge issues with the TRB501 however with my fairly slow 5G speeds (200/80) I don’t think it would be too much of a hindrance. Hopefully you will fix the issue via firmware some day.
Do you consider the modem firmware that you are currently deploying manually to those users with 5G instability issues, to be successful at stabilising the modem?
I’m also looking at the RUTM30 as well. I prefer the TRB501, but only if the modem is stable which I’m hoping the modem firmware that you are currently deploying has achieved.
