RUTX50 Wi-Fi rejects all clients – ath10k WMI peer timeout (-110) on 07.23.7
My RUTX50 repeatedly reaches a state where all Wi-Fi SSIDs remain visible, but no client can authenticate. macOS and iOS ask for the WPA2 password again; entering the correct password does not help. Ethernet access to RutOS usually remains available. Initially a reboot restored Wi-Fi, but during the latest incident even a hard power cycle did not restore reliable operation.
Device and configuration:
  • RUTX50
  • RutOS: RUTX_R_00.07.23.7
  • Regulatory country: US, Outdoor mode
  • 2.4 GHz: channel 6, 20 MHz, 20 dBm
  • 5 GHz: channel 40, 40 MHz, 23 dBm
  • WPA2-PSK/CCMP
  • Main SSID “Tortuga” on 2.4 and 5 GHz
  • Separate 2.4 GHz SSID “Tortuga2G” was disabled as a test
  • Guest SSID was initially active on 2.4 and 5 GHz; it has now also been disabled, leaving only the main SSID active
  • Wi-Fi WAN/campground repeater functionality is not normally used; Starlink is the WAN source
Clients are mainly recent Apple devices (MacBook Pro M1 and iPhone 16/17 Pro) plus a Victron Cerbo GX, which uses 2.4 GHz. Both 2.4 and 5 GHz authentication fail at the same time.
The kernel/hostapd logs repeat errors such as:
ath10k_ahb a000000.wifi: failed to wait for created wmi peer ... on vdev 0/1: -110
ath10k_ahb a000000.wifi: failed to add peer ... when adding a new sta: -110
hostapd: Could not add STA to kernel driver
hostapd: did not acknowledge authentication response
nl80211_recv_beacons->nl_recvmsgs failed: -5
The problem recurred after approximately 24 hours with Tortuga2G disabled. After the next hard power cycle, the same ath10k peer-creation errors started again within roughly two minutes and repeated every few seconds. This makes normal RF congestion, an incorrect password, or a single disabled SSID unlikely explanations.
One failing association attempt used MAC prefix 50:8A:06 (Tuya OUI), but this device never obtained a DHCP lease and may simply be a nearby device. Other client MACs also failed, so I am not treating it as the cause.
The DHCP hostname “einstein” has now been positively identified as the Victron Cerbo GX:
  • Wi-Fi MAC: 48:E7:DA:86:F4:51
  • IP: 192.168.1.108
The Cerbo successfully connected even after the first ath10k errors had appeared. There was a timing correlation between reconnecting it and one later failure, but no evidence that it is the cause; at most it could expose a router driver/firmware defect.
This appears similar to:
Questions:
  1. Is this ath10k WMI peer timeout (-110) a known issue in RUTX_R_00.07.23.7?
  2. Is it fixed in RUTX_R_00.07.24.1, or is a downgrade recommended?
  3. Does the rapid recurrence after a hard power cycle indicate a Wi-Fi hardware fault/RMA case?
  4. Which additional logs should be captured during the failed state?
I have a RutOS troubleshoot file and Apple Wireless Diagnostics available, but would prefer to provide them privately because they may contain sensitive configuration details.
Thank you.
Update from the current live test:
Immediately after disabling TortugaGuest and applying the configuration, Apple clients could authenticate to Tortuga again without a full router reboot. Save & Apply likely reloads hostapd/the Wi-Fi subsystem, so this does not yet prove that the guest SSID itself is the cause. TortugaGuest and Tortuga2G will remain disabled while the main mixed-band Tortuga SSID is left unchanged, to see whether the failure returns.
Thank you for reaching out and apologies for the delayed response.
According to the logs, it seems that the issue is related to the ath10k WMI peer timeout. To resolve potential corruption, we recommend performing a clean firmware update via the Bootloader Menu using the latest firmware version (RUTX_R_00.07.24.3). Step-by-step instructions are available on our Wiki here: Bootloader menu - Teltonika Networks Wiki
Note that this recovery process will completely erase your current settings, so be sure to back up your configuration before proceeding.
If the issue still persists after flashing the firmware via bootloader menu, for troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 20564.
Please let me know once you have filled out the form so we can continue troubleshooting further.
Martyna
