Hello Teltonika Support Team,
I am experiencing a critical and persistent Wi-Fi stability issue on my RUTX50 since updating to the latest firmware. During periods of higher network activity (e.g., video streaming/training sessions), the entire Wi-Fi module appears to crash or restart, causing all connected clients to drop simultaneously. My Setup is small. no extra AP, only 1 Windows Notebook, 2 Android devices, 1 Smart TV and 1 Smarthome device
Environment & Setup:
Device: RUTX50
Firmware: Latest release (recently re-installed cleanly & recovery)
WAN Connection: Mobile (5G/LTE via Lidl Mobile, stable connection)
Wi-Fi Configuration: Combined SSID (2.4 GHz and 5 GHz networks sharing the same name/WPA2-PSK key). Band Steering is disabled.
The Symptom (Log Evidence): The issue is definitively isolated to a Layer 2 Wi-Fi drop on the router side. The RutOS system log clearly shows that completely different client devices (an Intel-based Windows laptop and a tablet) are disconnected at the exact same second, followed by a re-connection a few seconds later.
Example from my log:
2026-05-27 20:27:31 WiFi Connections Notice: WiFi client connected: AC:5A:FC:C4:49:0B (Intel Laptop)
2026-05-27 20:27:36 WiFi Connections Notice: WiFi client connected: D2:42:65:95:A1:10 (Tablet)
2026-05-27 20:27:30 WiFi Connections Notice: WiFi client disconnected: AC:5A:FC:C4:49:0B
2026-05-27 20:27:30 WiFi Connections Notice: WiFi client disconnected: D2:42:65:95:A1:10
Troubleshooting already performed (without success): To rule out client-side issues and aggressive power-saving or roaming mechanisms, we have already adjusted the following settings based on advanced troubleshooting:
Client-Side (Intel Wi-Fi Card): Fixed preferred band to 5 GHz, disabled all power-saving modes (MIMO Power Save set to ‘No SMPS’), set Roaming Aggressiveness to ‘Lowest’, and disabled ‘Fat Channel Intolerant’. Windows Random Hardware Addresses are turned OFF.
Router-Side (Wireless Advanced Settings):
Reduced 5 GHz bandwidth from 80 MHz to a fixed 40 MHz with “Force 40MHz mode” enabled.
Set “ACS exclude DFS” to ON to prevent radar-scan drops.
Set Distance Optimization to a fixed value (10m) to avoid ACK timeout miscalculations.
Increased “Time interval for rekeying GTK” to the maximum of 65535 to rule out key-handshake bugs.
Turned “Disable Inactivity Polling” to ON to stop the hostapd process from dropping active clients.
Set “802.11w Management frame protection” to Disabled (strictly using WPA2-PSK).
Despite all these isolation steps, the simultaneous disconnections still occur. Since multiple independent devices drop at the exact same moment, this points directly to a bug in the wireless driver (ath11k / mac80211 or hostapd process) handled by the new firmware, specifically when operating a combined SSID setup.
Could you please investigate if this is a known regression in the hostapd/Wi-Fi driver stack of this firmware version, or provide a hotfix?
Best regards
Tomas
