RUTX50 sometimes drop 2.4wifi connection
Did somebody solve this issue of dropping 2.4 WiFi connections?
This topic was talked before in this post RUTX50 occasionally drops 2.4ghz wifi
in such situation WiFi Works, but clients are Lost. Restarting WiFi doesnt solve the problem. Reboot does but it is not a solution.
Martin
Could you please confirm what firmware version is in use currently? If you’re using 7.18.3, could you confirm that the issue is apparent with 7.19.4 version as well?
Additionally, does performing a Bootloader reset or a factory reset on the device help with the situation, or has this been tried before? For the bootloader process guide, you can find it here: Bootloader menu - Teltonika Networks Wiki
I’m using stable 7.18.3 but this also occured in previous stable release. I didn’t do bootloader reset or factory reset but I think this should be the last step. On 7.16 it didn’t happen so some upgrades broke it.
As mentioned, could you try upgrading to 7.19.4 to see if the issue persists? If it does, we’ll move to a different communication channel and I’ll collect the logs from your device.
Hello Matas,
I’m not so fast with upgrading to not stable version, only 10days after release…I don’t want to have any other troubles. Router is far away from me. But I can check some logs or try to change configuration if you have any suggestions.
Hello, Marpan,
No worries, thanks for letting me know. Could you please clarify what are these end-devices that are losing connection to your RUTX50?
As for the configuration - a few things come to mind, such as heading to Network → Wireless → Radios and changing the 2.4GHz (or 5GHz) channels to 1, 6 or 11 (try out all of them and see if it helps). Additionally, if you have Fast Roaming enabled, you can try disabling that for testing purposes to see if the situation approves.
As for the logs, make sure to reproduce the issue, head to System → Maintenance → Troubleshoot → Download and within the troubleshoot file, open up the “System.log” file which will contain all of your devices logs. You can then look for Wi-Fi related errors there and even share them here. Just make sure to leave out any sensitive information, such as MAC addresses, IP addresses (Public ones), Passwords, etc.
Hello Matas,
of course I’ll try to collect the logs if it occurs. I’m using channel 11 as I read in other topic as possible solution. Most of these 2.4 devices work as IoT, camera, smart plugs or temperature sensors. after reboot it can work 1-2 weeks without any issues. Traffic is also the same all the time. no any additional peaks on it.
I see,
I’ll be waiting for updates from your end then.
Hi Matas, maybe you have Slack channel or something similar to exchange logs, etc…or more dynamic conversation about this issue ?
Hi, Marpan,
We do have a different communication channel whenever further analysis is required, however, in your case, could you please provide any updates on the situation?
Hello Matas,
I catched some logs, maybe will help.
35702 Sat Dec 20 16:08:45 2025 kern.warn kernel: [581166.551675] WARNING: CPU: 0 PID: 29307 at backports-6.12.6/net/mac80211/driver-ops.h:1007 ieee80211_iter_chan_contexts_atomic+0x6bc/0x1080 [mac80211]
35703 Sat Dec 20 16:08:45 2025 kern.warn kernel: [581166.555669] Modules linked in: xt_connlimit pppoe ppp_async nf_conncount l2tp_ppp iptable_nat ath10k_pci(O) ath10k_core(O) ath(O) xt_state xt_nat xt_helper xt_conntrack xt_connmark xt_connbytes xt_REDIRECT xt_MASQUERADE xt_FLOWOFFLOAD xt_CT qmi_wwan pptp pppox ppp_mppe ppp_generic option nft_redir nft_ct nf_nat_tftp nf_nat_snmp_basic nf_nat_sip nf_nat_pptp nf_nat_irc nf_nat_h323 nf_nat_ftp nf_nat_amanda nf_nat nf_flow_table nf_conntrack_tftp nf_conntrack_snmp nf_conntrack_sip nf_conntrack_pptp nf_conntrack_netlink nf_conntrack_irc nf_conntrack_h323 nf_conntrack_ftp nf_conntrack_broadcast nf_conntrack_amanda nf_conntrack mac80211(O) ipt_REJECT cfg80211(O) xt_time xt_tcpudp xt_tcpmss xt_statistic xt_recent xt_policy xt_multiport xt_mark xt_mac xt_limit xt_length xt_hl xt_hashlimit xt_esp xt_ecn xt_dscp xt_coova(O) xt_comment xt_TCPMSS xt_NFLOG xt_LOG xt_HL xt_DSCP xt_CLASSIFY xfrm_interface wireguard usbnet usb_wwan ts_kmp ts_fsm ts_bm slhc sch_cake rfcomm pl2303 nft_reject_ipv6 nft_reject_ipv4 nft_reject_inet
35704 Sat Dec 20 16:08:45 2025 kern.warn kernel: [581166.556213] nft_reject nft_quota nft_numgen nft_log nft_limit nft_hash nft_fwd_netdev nft_dup_netdev nfnetlink_log nf_tables nf_reject_ipv4 nf_log_syslog nf_dup_netdev nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c libchacha20poly1305 iptable_raw iptable_mangle iptable_filter ipt_ah ipt_ECN ip6table_raw ip_tables hidp hci_uart ftdi_sio cypress_m8 curve25519_neon cp210x compat(O) ch343 ch341 cdc_wdm cdc_acm btusb btrtl btintel bnep bluetooth belkin_sa asn1_decoder ark3116 act_ipt pulse_counter(O) cypress_serial(O) usbserial sch_tbf sch_ingress sch_htb sch_hfsc em_u32 cls_u32 cls_route cls_matchall cls_fw cls_flow cls_basic act_skbedit act_mirred act_gact hid evdev input_core tlt_gpio(O) xt_set ip_set_list_set ip_set_hash_netportnet ip_set_hash_netport ip_set_hash_netnet ip_set_hash_netiface ip_set_hash_net ip_set_hash_mac ip_set_hash_ipportnet ip_set_hash_ipportip ip_set_hash_ipport ip_set_hash_ipmark ip_set_hash_ip ip_set_bitmap_port ip_set_bitmap_ipmac ip_set_bitmap_ip ip_set nfnetlink ip6table_mangle ip6table_filter
35705 Sat Dec 20 16:08:45 2025 kern.warn kernel: [581166.637679] ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 msdos ip6_gre ip_gre gre ifb l2tp_ip6 l2tp_ip l2tp_eth l2tp_netlink l2tp_core ipcomp6 xfrm6_tunnel esp6 ah6 xfrm4_tunnel ipcomp esp4 ah4 ip6_tunnel tunnel6 tunnel4 ip_tunnel vrf tun ovpn_dco_v2(O) udp_tunnel ip6_udp_tunnel xfrm_user xfrm_ipcomp af_key xfrm_algo vfat fat ntfs autofs4 nls_utf8 nls_iso8859_1 nls_cp437 ecdh_generic ecc algif_skcipher algif_rng algif_hash algif_aead af_alg echainiv cmac usb_storage leds_gpio xhci_plat_hcd xhci_pci xhci_hcd dwc3 dwc3_qcom uhci_hcd sd_mod scsi_mod scsi_common r2ec(O) gpio_button_hotplug(O) ext4 mbcache jbd2 exfat mii crc32c_generic
35706 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.784626] CPU: 0 PID: 29307 Comm: kworker/0:0 Tainted: G W O 6.6.96 #0
35707 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.803890] Hardware name: Generic DT based system
35708 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.811784] Workqueue: events_freezable ieee80211_restart_work [mac80211]
35709 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.816658] unwind_backtrace from show_stack+0x10/0x14
35710 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.823592] show_stack from dump_stack_lvl+0x40/0x4c
35711 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.829060] dump_stack_lvl from __warn+0x98/0xc0
35712 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.834006] __warn from warn_slowpath_fmt+0x170/0x174
35713 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.838782] warn_slowpath_fmt from ieee80211_iter_chan_contexts_atomic+0x6bc/0x1080 [mac80211]
35714 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.843911] ieee80211_iter_chan_contexts_atomic [mac80211] from ieee80211_iter_chan_contexts_atomic+0x1018/0x1080 [mac80211]
35715 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.852942] ieee80211_iter_chan_contexts_atomic [mac80211] from __ieee80211_link_release_channel+0xfc/0x138 [mac80211]
35716 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.864137] __ieee80211_link_release_channel [mac80211] from ieee80211_stop_ap+0x200/0x3ac [mac80211]
35717 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.875160] ieee80211_stop_ap [mac80211] from cfg80211_leave_mesh+0x13c/0x1e8 [cfg80211]
35718 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.884274] cfg80211_leave_mesh [cfg80211] from cfg80211_stop_ap+0x44/0x8c [cfg80211]
35719 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.892606] cfg80211_stop_ap [cfg80211] from cfg80211_netdev_notifier_call+0x228/0x3a8 [cfg80211]
35720 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.900507] cfg80211_netdev_notifier_call [cfg80211] from raw_notifier_call_chain+0x34/0x64
35721 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.909535] raw_notifier_call_chain from __dev_close_many+0x40/0xf4
35722 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.918211] __dev_close_many from dev_close_many+0x88/0x148
35723 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.924630] dev_close_many from dev_close.part.31+0x30/0x6c
35724 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.930361] dev_close.part.31 from cfg80211_shutdown_all_interfaces+0x3c/0xf4 [cfg80211]
35725 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.936097] cfg80211_shutdown_all_interfaces [cfg80211] from ieee80211_restart_work+0x110/0x148 [mac80211]
35726 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.944261] ieee80211_restart_work [mac80211] from process_scheduled_works+0x1e0/0x394
35727 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.954239] process_scheduled_works from worker_thread+0x190/0x3dc
35728 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.962309] worker_thread from kthread+0xe8/0x104
35729 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.968642] kthread from ret_from_fork+0x14/0x28
35730 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.973242] Exception stack(0xc264ffb0 to 0xc264fff8)
35731 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.978107] ffa0: 00000000 00000000 00000000 00000000
35732 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.983237] ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
35733 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581166.991482] ffe0: 00000000 00000000 00000000 00000000 00000013 00000000
35734 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581167.002148] —[ end trace 0000000000000000 ]—
35735 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581167.006897] ath10k_ahb a000000.wifi: failed to flush transmit queue (skip 1 ar-state 0): 500
35736 Sat Dec 20 16:08:46 2025 kern.err kernel: [581167.076199] wlan0-1: failed to remove key (2, XX:XX:XX:XX:XX:XX) from hardware (-5)
35737 Sat Dec 20 16:08:46 2025 kern.err kernel: [581167.076309] wlan0-1: failed to remove key (1, XX:XX:XX:XX:XX:XX) from hardware (-5)
35738 Sat Dec 20 16:08:46 2025 kern.warn kernel: [581167.084942] ------------[ cut here ]------------
35767 Sat Dec 20 16:08:46 2025 daemon.info dnsmasq-dhcp[3234]: DHCPREQUEST(br-lan) 192.168.1.246 XX:XX:XX:XX:XX:XX
35768 Sat Dec 20 16:08:46 2025 daemon.notice hostapd: wlan0-1: AP-STA-DISCONNECTED XX:XX:XX:XX:XX:XX
35769 Sat Dec 20 16:08:46 2025 daemon.info dnsmasq-dhcp[3234]: DHCPACK(br-lan) 192.168.1.246 XX:XX:XX:XX:XX:XX Phone1
35770 Sat Dec 20 16:08:46 2025 kern.info kernel: [581167.500795] ath10k_ahb a000000.wifi wlan0-1: left allmulticast mode
35771 Sat Dec 20 16:08:46 2025 kern.info kernel: [581167.500872] ath10k_ahb a000000.wifi wlan0-1: left promiscuous mode
35772 Sat Dec 20 16:08:46 2025 kern.info kernel: [581167.506466] br-lan: port 3(wlan0-1) entered disabled state
35773 Sat Dec 20 16:08:46 2025 kern.notice WLAN1-XXX: WiFi client disconnected: XX:XX:XX:XX:XX:XX
35774 Sat Dec 20 16:08:46 2025 daemon.notice netifd: Network device ‘wlan0-1’ link is down
35775 Sat Dec 20 16:08:46 2025 daemon.notice hostapd: wlan0-1: AP-STA-DISCONNECTED XX:XX:XX:XX:XX:XX
35776 Sat Dec 20 16:08:46 2025 daemon.info dnsmasq-dhcp[3234]: DHCPREQUEST(br-lan) 192.168.1.246 XX:XX:XX:XX:XX:XX
35777 Sat Dec 20 16:08:46 2025 daemon.info dnsmasq-dhcp[3234]: DHCPACK(br-lan) 192.168.1.246 XX:XX:XX:XX:XX:XX Phone1
35778 Sat Dec 20 16:08:46 2025 kern.notice WLAN1-XXX: WiFi client disconnected: XX:XX:XX:XX:XX:XX
35779 Sat Dec 20 16:08:46 2025 daemon.info dnsmasq-dhcp[3234]: DHCPREQUEST(br-lan) 192.168.1.246 XX:XX:XX:XX:XX:XX
35780 Sat Dec 20 16:08:46 2025 daemon.info dnsmasq-dhcp[3234]: DHCPACK(br-lan) 192.168.1.246 XX:XX:XX:XX:XX:XX Phone1
35781 Sat Dec 20 16:08:46 2025 daemon.notice hostapd: wlan0-1: AP-STA-DISCONNECTED XX:XX:XX:XX:XX:XX
35782 Sat Dec 20 16:08:46 2025 kern.notice WLAN1-XXX: WiFi client disconnected: XX:XX:XX:XX:XX:XX
35783 Sat Dec 20 16:08:46 2025 daemon.notice hostapd: wlan0-1: AP-STA-DISCONNECTED XX:XX:XX:XX:XX:XX
35784 Sat Dec 20 16:08:46 2025 kern.notice WLAN1-XXX: WiFi client disconnected: XX:XX:XX:XX:XX:XX
35785 Sat Dec 20 16:08:46 2025 daemon.notice hostapd: wlan0-1: AP-STA-DISCONNECTED XX:XX:XX:XX:XX:XX
35837 Sat Dec 20 16:08:46 2025 daemon.err hostapd: Failed to set beacon parameters
35838 Sat Dec 20 16:08:46 2025 daemon.notice hostapd: wlan0-1: INTERFACE-DISABLED
35839 Sat Dec 20 16:08:48 2025 user.info : Starting database size optimization…
35840 Sat Dec 20 16:08:50 2025 daemon.info dnsmasq-dhcp[3234]: DHCPDISCOVER(br-lan) XX:XX:XX:XX:XX:XX
35841 Sat Dec 20 16:08:50 2025 daemon.info dnsmasq-dhcp[3234]: DHCPOFFER(br-lan) 192.168.1.127 XX:XX:XX:XX:XX:XX
35842 Sat Dec 20 16:08:50 2025 daemon.info dnsmasq-dhcp[3234]: DHCPDISCOVER(br-lan) XX:XX:XX:XX:XX:XX
35843 Sat Dec 20 16:08:50 2025 daemon.info dnsmasq-dhcp[3234]: DHCPOFFER(br-lan) 192.168.1.127 XX:XX:XX:XX:XX:XX
35844 Sat Dec 20 16:08:50 2025 daemon.info dnsmasq-dhcp[3234]: DHCPDISCOVER(br-lan) XX:XX:XX:XX:XX:XX
35845 Sat Dec 20 16:08:50 2025 daemon.info dnsmasq-dhcp[3234]: DHCPOFFER(br-lan) 192.168.1.127 XX:XX:XX:XX:XX:XX
35846 Sat Dec 20 16:08:51 2025 daemon.info dnsmasq-dhcp[3234]: DHCPREQUEST(br-lan) 192.168.1.127 XX:XX:XX:XX:XX:XX
35847 Sat Dec 20 16:08:51 2025 daemon.info dnsmasq-dhcp[3234]: DHCPACK(br-lan) 192.168.1.127 XX:XX:XX:XX:XX:XX
35848 Sat Dec 20 16:08:52 2025 daemon.err hostapd: Failed to set beacon parameters
35849 Sat Dec 20 16:08:52 2025 kern.warn kernel: [581173.498714] ath10k_ahb a000000.wifi: failed to send pdev bss chan info request
35850 Sat Dec 20 16:08:58 2025 user.info : Finished database optimization
35851 Sat Dec 20 16:08:58 2025 daemon.err hostapd: Failed to set beacon parameters
35852 Sat Dec 20 16:08:58 2025 kern.warn kernel: [581179.499710] ath10k_ahb a000000.wifi: failed to send pdev bss chan info request
35853 Sat Dec 20 16:09:04 2025 daemon.err hostapd: Failed to set beacon parameters
35854 Sat Dec 20 16:09:04 2025 kern.warn kernel: [581185.500613] ath10k_ahb a000000.wifi: failed to send pdev bss chan info request
35855 Sat Dec 20 16:09:10 2025 daemon.err hostapd: Failed to set beacon parameters
You seem to be getting a lot of kernel-related error messages, I would recommend looking into Bootloader resetting your device to rule out any other external factors on your device & make sure that you upgrade to the latest available firmware version while in the process as well (this can be done through the bootloader menu as well).
Kindly let me know if the situation improves, and if it doesn’t, we’ll move to a different channel to investigate this further.
so the solution steps should be reset to factory default using bootloader option and after that upgrade to latest (7.20, not stable) release ? and recover configuration from backup ?
M
Hi, Marpan,
The bootloader reset prompts you to upgrade the firmware, which, in the process, will also hard-reset the device to factory defaults, so it’s a 2-in-1.
Do the process, check whether the issue occurs, the backup you have for your current FW will not be compatible (most likely) due to there being changes in the UI/Settings, etc.
So I have to do configuration of the router from the scratch? Restore will not work ?
Correct, but for your case, you can simply set up just the Wi-Fi to test if it starts working or not. If it ends up working, I recommend re-doing the configuration from scratch, since the backup may contain some type of configuration / files that might’ve caused the issue in the first place.
So, last question…There is no way to solve this problem without recovery, do this fully remotely, even with latest FW, there is no commit that such upgrade will solve it.
Hi, Marpan,
I understand your concerns 100%, if the bootloader reset + upgrade does not work out, you can simply downgrade to the firmware version you’re on currently, and re-apply the backup you’ve saved to restore the settings, in essence, nothing will be lost.
