Hello Leigh,
thank you very much for your post and for sharing the downgrade procedure.
I can confirm that the same modem firmware problem also affected my Teltonika RUTC50 eSIM version with the Quectel RG520N-EBDC modem.
The modem firmware was already RG520NEBDCR03A05M4G_A0.300.A0.300 before I sent the device in for repair. After almost one month I received it back, but the same problems were still there. So in my case, it was very likely not a hardware issue, but related to the modem firmware.
With A05 installed, normal operation in 5G/Auto mode was not really possible. The modem became unstable, the connection sometimes dropped, and the router behaved unpredictably. In some cases, when using 5G/Auto, the WebUI froze for up to around two minutes. Sometimes the internal modem disappeared completely and was no longer visible/usable in the router until a restart or recovery action.
The only way to get a somewhat usable connection was to manually select specific bands instead of using full auto mode.
I followed your idea and downgraded the modem firmware to:
RG520NEBDCR03A04M4G_01.200.01.200
I did it via SSH on my RUTC50, using a stable WAN connection and not the mobile connection for the download. In my case, I first had to install sshfs, otherwise the downgrade failed before flashing.
The successful commands were:
sh opkg update && opkg install sshfs modem_updater modem_updater -v RG520NEBDCR03A04M4G_01.200.01.200
After the downgrade, I checked it with:
sh modem_updater -g gsmctl -A ATI
The modem now reports:
Revision: RG520NEBDCR03A04M4G_01.200.01.200
Interestingly, after the downgrade, A05 is no longer offered to me by modem_updater -g. The RUT WebUI also does not offer an update back to A05 anymore and shows the current modem firmware as the newest installed version.
Since the downgrade, 5G/Auto mode looks much more stable on my RUTC50. The modem connects again to Vodafone Germany with 5G NSA and does not crash immediately like before.
So this issue is not only affecting the RUTX50. It also affects at least my RUTC50 eSIM version with RG520N-EBDC.
Thanks again for pointing us in the right direction.
Stefan
