RUTX11 cannot update modem 2
Continued from this thread:
I updated to latest RUTX_R_00.07.07.1 and then did a factory reset.
After that I tried to update modem again and I still get same error.
PS.Why are the topics automatically closed?
You can try updating the modem via the dfota command using SSH/CLI.
2024-06-12-09-10-07-192.168.50.1 (root)
Please note that topics are automatically closed by the system 15 days after their creation.
root@RUTX11:~# dfota -u
Preparing for gsm.modem0 update!
Searching for updates...
Update found! Update size: 25761882
Preparing system for update!
sh: out of range
Not enough memory in modem filesystem! ErrorCode: 171
Reseting modems due error!
Update script done!
I find the closing of topics to be unhelpful because it blocks the possibility of adding to pertinent topics. You basically have to start over again whereas leaving them open allows a history to develop and contributions to be added. Also, I will no longer update unless there is something I specifically need and I will try that on a test router for a few weeks minimum.
We can upgrade your modem using a file. I will share it with you on a different platform. Instructions for accessing it have been sent to the email you used to register for this forum.
To upgrade the modem using the file, follow these steps:
dfota -f /<filelocation>
If you’re using a Windows PC, you can upload the file to your router using the WinSCP program.
I tried the file I got by you and the terminal reports this:
root@RUTX11:~# dfota -f EG06ELAR04A20M4G.tar.gz
Skipping update checking because direct file or link provided
Update script done!
And if I have the router webgui up it will report this banner:
There is another way to update a modem, but it should be used with caution. In general, why do you need to update the modem firmware? What issues are you experiencing?
I cannot even use the modem. My sim card gets detected and then it just gets stuck in a loop where the modem disappears and pops up again and after a while before getting registered on the network it resets again.
I have already fibre internet so the router gets its internet via wan-port but I would like to have mobile network as backup
