RUTM30 modem problem after FW update
I am experiencing a persistent internal modem problem on a RUTM30 which started immediately after a modem firmware update. Before the modem update the router was working normally.
I got sometimes notification that the intern modem is unreachable (unexpected shutdown)
The issue persists after factory reset and clean configuration.
System firmware: RUTM_R_00.07.20.3
Modem firmware: RG520NEBDCR03A05M4G
Sim card is working (tried it in my phone) i also tried instead a Esim→didn’t work
My problem is nearly the same issue like this: RUTX50 internal modem unstable after RG520 modem firmware update – SIM failure, gsmctl N/A, no registration
Thank you
I think they’re released a buggy modem firmware.
Any possibility to downgrade the modem firmware?
i’ve found a workaround for the people with the modem firmware problem:
Choose 4G instead 5G!
In the device go to: Network→Mobile→Connection
Choose the correct SIM-Card (the one you use for the internet)
Edit the “Prefered network typ” to 4G/3G auto
Save & Apply
See the attached Screenshots how to do. I know its only 4G instead of 5G, but ist a huge difference between having a little bit slower internet or no internet. Hope that will help you and hope it will help the support for solving this problem.
Could you please try navigating to Network → Mobile → Connection
And select NSA for the 5G Mode
Please let me know if this resolves the issue.
I’ve tested it- IT didnt Work.
In the notification: “internal Modem is unreachable”
So right now the only workaround seems Like Switch to 4G.
The Rest is Up to you to get a new Modem Firmware running;-)
Just adding that I have had exactly the same fault - works on 4G but if I set it to 5G/5G/3G auto and 5G mode to NSA, it says ‘modem unreachable’.
Same issue here! After updating the modem’s firmware, 5G connections can no longer be established or drop immediately. 4G connections are still possible. Release RG520NEBDCR03A05M4G appears to have a bug. Please investigate this and provide a fixed version or a way to downgrade to a stable version. Thank you.
