RUTX50 internal modem unstable after RG520 modem firmware update – SIM failure, gsmctl N/A, no registration
Hello everyone, and thanks a lot for the tips on fixing the problem.
Sorry, but all these workarounds are, in short, bullshit.
I spent about 3 hours on the problem this evening and found a solution.
I don’t understand why Teltonika itself didn’t offer this solution to me or to the rest of you affected users.
ThisHowTo is Only for the Quectel RG520N-EU Modem!
In short: a downgrade of the modem from version RG520NEBDCR03A05M4G to the previous version RG520NEBDCR03A04M4G_01.200.01.200 via the shell.
I warn about possible damage to your devices and I will not explain how to log in via shell or how to perform this procedure.
Without technical knowledge, please keep your hands off this. I take no responsibility for success.
An internet connection via WAN is required for the fix.
Configure WAN as main, remove the SIM card and disconnect the power supply. Wait 60 seconds and reconnect it.
Once the RUTX50 is back online, check the internet connection and whether the device is online.
Ideally log into the shell and for example run: ping 1.1.1.1
If everything is fine, continue step by step.**
  1. Prepare tools**
    opkg update && opkg install sshfs modem_updater
2. Check available firmware files
/usr/local/usr/bin/modem_updater -g
3. Force downgrade (use LAN in WAN port for stability – NOT via mobile network)
/usr/local/usr/bin/modem_updater -v RG520NEBDCR03A04M4G_01.200.01.200 -f
4. Check after reboot
gsmctl -i
After that my RUTX50 was back online with 5G SA!
Ideally, after successfully downgrading, you should perform a factory reset so that all your settings are restored to their default values.
I would also like to express my disappointment with the support experience.
I opened this ticket about 14 days ago and repeatedly asked for guidance regarding a possible modem firmware downgrade, but did not receive clear technical instructions. In the end I had to investigate and test a possible fix myself.
For a professional product like this, I expected a higher level of technical support. Not having partner status and therefore no direct or faster access via the partner portal makes the process especially frustrating for technically experienced users.
I would appreciate more accessible technical guidance for non-partners as well.
Good luck with the downgrade
Best regards, Leigh
