RUT955 Bootloader - where to download?
I came across a very old RUT955 with Firmware Version 00.01.xx.x something. After I tried upgrading with RUT9XX_R_00.06.09.5_WEBUI.bin the device is now bricked, but I can get into bootloader mode.
Where can I download the bootloader to revive it?
Thanks in advance
You can reach bootloader information on our wiki pages.
You can reach FW versions for RUT950 from here
And if you need help to trigger bootloader process, please check this link.
Caner
Hi Caner,
I don’t need the FW, I need the bootloader. On the page you linked there is no bootloader. Can you tell me where to download it?
Dino
‘uboot’ files are not publicly accessible.
However, you can use FW on the bootloader menu to revive the device.
After it’s done I recommend you to go to the FOTA settings on the WebUI and to check if there is a recommendation to FW upgrade on the modem also. If yes, you can upgrade the modem FW with one click also.
This will also make the devices fully updated!
Caner
FW on the bootloader menu doesn’t work, I am getting this error:
Something went wrong during update. Probably you have chosen wrong file (too big or too small) or you were trying to update ART on device with unknown FLASH type (and size) which is not allowed. Please, try again or contact with the author of this modification. You can also get more information during update in U-Boot console.
Which FW are you trying to upload?
And which link are you trying to upload the FW?
You should use this link: 192.168.1.1/index.html and if your device has legacy WebUI, you should try to upload the corresponding FW.
Caner
Hi.
As I already wrote I tried RUT9XX_R_00.06.09.5_WEBUI.bin. And as I wrote in my first post the device is very old and had FW v.1.x on it, so it must be legacy.
I was indeed on /uboot.html because /index.html didn’t work in the first place and only showed a “server error”. Now after several reboots the /index.html worked and I was able to upload the firmware (as written above 00.06.09.5) and it’s alive again.
Now the firmware update page shows:
Bootloader version 1.0.0 [Update needed [Download]]
where “Download” is a link and goes to https://wiki.teltonika-networks.com/view/RUT9xx_Firmware
This page is empty so I again can’t download the Bootloader. Where can I get it?
FOTA also doesn’t work.
I have the exact same symptom on my 955.
Help please!
Sorry for late response.
To resolve this issue, we need to send you the files. As we can not do it on the community forum, we will handle it on a separate platform. Instructions for accessing it have been sent to the email you registered for this forum. Required ticked ID would be 4 digit number of this active case.
Caner
