RUT955 Bootloader
is it possible for me to also receive the bootloader files for reviving the (old) RUT955, like mentioned in this post:
Thank you very much!
Could you please provide a detailed description of the issue you’re experiencing with your RUT955?
It is one of the older RUT955. I tried to update the firmware to the latest possible according to RUT955 Firmware Downloads (legacy WebUI) - Teltonika Networks Wiki
It is not possible, due to “not enough flash memory”. I tried it anyways and afterwards the router boots into safe mode. I read, that it needs an update for the Bootloader. I reached the uboot.html page of the router, but don’t have the correct Bootloader files.
It is the RUT955 017V020.
Thank you!
Thank you for the information.
Could you please confirm if you have tried updating the firmware via the bootloader at 192.168.1.1/index.html?
Ah, thanks, Marija! Didn’t know that, that worked indeed!
Thanks again!
I’m glad to hear that it helped!
If you have any more questions or concerns, please don’t hesitate to reach out.
