Teltonika 955 (Legacy) Bootloader
Can you possibly provide the bootloader Firmware for the Rut955. I have upgraded the firmware to version 06.9.5, however it is recommending to upgrade the bootloader firmware.
Firmware version	RUT9XX_R_00.06.09.5
Firmware build date	2023-05-19, 05:46:01
Kernel version	3.18.44
Bootloader version	1.0.0 Update needed [Download]
https://wiki.teltonika-networks.com/view/RUT955_Firmware_Downloads_(legacy_WebUI) Doesn’t contain any file for the firmware to upgrade.
This previous community response was resolved with the files being sent over via email - RUT955 Bootloader - where to download? - #8 by Dino
Many thanks,
Aaron
There is no need to update the bootloader. You will not get any benefits from it.
The bootloader version does not need to be updated as long as everything is working fine.
You’ve already updated to the latest Legacy firmware. If you’d like, you can try updating to the RutOS firmware, which is available here, if your device’s hardware version supports it.
