RUT901 Route all traffic through a wireguard tunnel
I just called your support hotline and they told me to create a forum post about that topic. I have a cloud VPS where my RUT901 should connect via wireguard through a internet connection on the WAN port of the router.
I want to route all traffic from the LAN ports of the router through the wireguard tunnel.
The wireguard connection works perfectly fine, but as soon as i enable the option “Route allowed IPs”, the wireguard tunnel completely stops working. When i type “wg” on the routers command line i see the wireguard tunnel, but it has only a few KB send and 0 bytes received. I also don’t see any incoming traffic on my VPS on the wireguard port at all. It also doesn’t matter what i config on the option “Allowed IPs” on the RUT901 WebUI. It just stops working.
As soon as i disable the “Route allowed IPs”, the tunnel starts working again, but obviously, not all traffic than is routed through the wireguard tunnel.
I also called the support, we tried to setup policy based routing, but it didn’t change anything, no traffic than is routed through the wireguard tunnel.
The support wasn’t able to help me any further and i should create a forum post instead. So here it is.
Thank you for reaching out.
There have been identical setup guidelines and discussions shared on the forum regarding routing all LAN traffic through a WireGuard tunnel here:
I’d recommend having a look at those topics, as they might offer some valuable insights or help clarify the necessary configuration steps to get this working.
Looking forward to hearing how it goes.
