If You Could Change 3 Things in a Teltonika Networks Device – What Would They Be?
Dear community,
We’re always looking for ways to improve our devices and the overall Teltonika Networks ecosystem — and your feedback matters the most.
If you could change, improve, or add up to 3 things in Teltonika Networks devices, what would they be?
It could be:
  • A missing feature
  • A usability improvement
  • Better ecosystem integration
  • Performance, stability, or management enhancements
  • Anything else you feel is currently lacking
Warm regards,
Teltonika community team
nmap
Post must contain at least 10 chars
It would be nice to have ntp updated to ntpsec if possible unless you have constrains ntpsec doesn’t support which feature you still need from original. Which is considered legacy ntp and you ship as /usr/local/sbin/ntp.
ntpsec issues with musl libc seem like solved last year.
While at it, please do not forget to provide both ntpq, ntpmon and ntpdate -utilities.
You don’t now have a good tool to observe ntp sync using cli, Seeing which servers/peers were preferred, observe and fix drifting and/or jitter issues. These two would make solving sync issues much easier and faster at least from my perspective.
Tthese utilities are available ntp and ntpsec. Latter reimplemeted both cli options and output match and there is no difference except minor changes in config files which drops some options that were dropped from ntpsec code also. Difference is that ntpsec implemented using python3 which now hard dependency. but as NTPD is also add-on package, that would just adding dependency have python3 installed first.
I put forward these improvement suggestions. Not something, had to be there immediately. Even though of course I wouldn’t complain if they were done already :slight_smile:
  1. Dark theme
  2. Same rules for calls as SMS rules
  3. I dont know.
  1. To gracefully dismount plugged in USB Drives and shutdown (Turn Off) router before a planned power outage by the click / tap of a button or a text message.
  2. Make login via HTTPS ports genuinely secure by default removing the need to mess about manually creating certificates, downloading them and importing them into browsers, what a carry on and completely unnecessary. Nobody should be doing this!!! You can securely log into ISP cheap and nasty freebies without having to do this.
  3. remove the need for the addition of a password when sending text message commands via a specific trusted mobile number. All unrecognised, untrusted numbers requiring a password. Create a different password (not the same as routers login password) for sending text messages, as these passwords are human-readable (Shoulder Surfing) in the text that you send to the router. Someone can then use the password to get into the router and greater access to it.
  1. Proper modem firmware update support for TRB devices. See multiple forum discussions involving dissatisfied users.
  2. Feature - Batman-adv
Otherwise, thanks for producing some of the best mobile networking hardware available in the market and providing us with an actively supported community forum to discuss and solve any issues the users are trying to solve!
When you go to Services / VPN / WireGuard there should be “last handshake X seconds ago” indicator, as well as some way to show whether wireguard tunnel is up or not. Like green status for connected, yellow for idle, and red for disconnected.
Simplify Wireguard configuration in Client or Server mode. Also add QR codes for configuration.
New 5G router in RUTX50 industrial case:
  • Min. 1x 2,5/5 Gbps ethernet or 10 Gbps LAN/SFP+ for LAN
  • Min. x75 5G modem (eg. Quectel RM551E-GL)
  • Min 4x SMA ports for outdoor mobile antennas (for full 4x4 MIMO), maybe mmwave antenna/support / or integrated all antennas with strong amplification (gain 10+ dBi) and mmwave support in outdoor version
We have an ISP that broadcasts mmwave n258 band public.
Without mmWave, on the 5CA 5G NSA network with the N78 band we have been measuring 2,2 Gbps/190 Mbps over mobile phone for several years now but you don’t have a router that has 2,5 Gbps LAN
Thanks!
EDIT: Why can’t I create a new post on this forum? I can’t find the button to create a new post anywhere. Thank you…
I dont have answer to this question but I am unable to contact you regarding a closed topic
Could you please reopen this topic MQTT to SMS issue , since I have now log files to send when the issue is active
Hello @tirkiz,
To create a new topic please select “Networking Solutions” under Categories in the left menu:
Then press “New Topic”:
Hello @andreasS,
Your topic has been reopened.
Sorry for the off-topic but I don’t see the “New topic” button :slight_smile:
Please view this announcement: Regarding the ability to create new topics [2026.01.28]
Thank you kindly for sharing!
Matas.
Thank you kindly for sharing & thank you for the feedback, it is very appreciated :beating_heart:
Matas.
Thank you for the feedback, I can’t agree more on the dark theme suggestion, it would be great.
Matas.
Thanks for the feedback, michiel!
Matas
Great suggestion, thank you, mesrik, we’ll look into it!
Matas.
