MQTT to SMS issue
I have an issue with sending SMS from MQTT on my RUT200.
It is connected to hivecloud via 4G. The modem is publishing GSM data to hivecloud and works always.
RUT200 is also subscribed to a topic on same hivecloud account that I use to control SMS sending
It works fine for a few days and then the SMS sending from MQTT stops working
SMS sending from web interface works fine, also modem is publishing GSM data to hivecloud.
After a reboot or after I disable an re-enable Collection, the SMS sending via MQTT starts working again.
I would most likely have to collect & view the troubleshoot file from your device from when the issue is present (so the logs are visible within the .log files). But for you to be able to share that troubleshoot file, we’ll have to move to a different channel for communication. I’ve sent you a form to fill out, in the Ticket ID field, please enter the number 16460 and I’ll contact you via your e-mail.
Thank you for your assistance.
Can you advise me how to get the logs in case of a failure, although it has now been working fine for 4 days.
Andreas
Of course, Andreas,
Whenever you need to collect the logs, simply head to WebUI → System → Maintenance → Troubleshoot and press Download. This will generate the troubleshoot file which contains all of your configurations, as well as the logs.
Just as an update, the modem has now been running for 51d 22h 42m 10s wihtout any issues.
All is still working, including SMS from MQTT.
Andreas
Greetings, @andreasS ,
Thank you for your message,
And thank you for an update, I am glad that everything seems to be working fine. In case you have any additional questions, please don’t hesitate to let me know.
Warm reagards,
Thank you for re-opening this topic.
I now have log files to share, when the issue is active. No SMS message from mqtt, only from Services > Mobile Utilities > Messages
Could someone have a look?
I believe you’ve filled out the form we’ve sent you not too long ago, I’ll reply to that.
Apologies, I’ll have to send a new form, as you didn’t fill out your contact details (no e-mail available).
I’ve sent you the form again, fill it out once more with your contact details as well as the Ticket ID.
Ok, thanks. I filled out the form, what happens now?
Hi, andreass,
Once again, it looks like you did not enter your contact e-mail address within the form, so I’m not able to reply to you. Could you please fill out the form one more time with your contact details included?
Weird, as I did fill in my email address, submitting is not possible without empty email address.
But I filled the form and submitted it, again. Now I entered my email also in the description field
This topic was automatically closed after 31 days. New replies are no longer allowed.
