harre
June 11, 2024, 9:34pm
1
Continuation from:
I followed this page to setup my RUTX11 to act as a wireguard node.
https://wiki.teltonika-networks.com/view/WireGuard_Configuration_Example
I get nothing shown when I type wg in the terminal as root.
I tried going full wireguard in commandline in the router and it works perfectly.
# wg
interface: wg0
public key: XXXXXXXXXXX
private key: (hidden)
listening port: 51820
peer: YYYYYYYYYYYYYY
endpoint: 192.168.1.166:59935
allowed ips: 192.168.2.2/32
latest handshake: 1 minute, 6 sec…
I never got around to factory reset my RUTX11 and try again.
I have flashed the latest fw and done a complete reset and I still get the same problem that I get no wireguard network adapter created if I enter as exactly in the wiki page linked.
harre
June 12, 2024, 12:44am
2
I tried creating my network manually with uci and was also able to create the network.
If I just did this commands I was able to get my wireguard network named “wireguard ” to be visible when running “wg ” command:
uci delete network.wireguard.device
uci commit network
/etc/init.d/network restart
root@RUTX11:~# wg
interface: wireguard
public key: xxxx
peer: yyyy
allowed ips: 192.168.2.0/24, 2001:db8::4/128
It seems now the device will be named as the same as what I named it in the GUI.
This is my uci show network:
network.wireguard=interface
network.wireguard.proto='wireguard'
network.wireguard.private_key='xxx'
network.wireguard.public_key='yyy'
network.wireguard.addresses='192.168.2.1/24' '2001:db8::1/128'
network.wireguard.disabled='0'
network.wireguard.listen_port='51820'
network.pixel8=wireguard_wireguard
network.pixel8.allowed_ips='192.168.2.4/24' '2001:db08::4/128'
network.pixel8.public_key='zzz'
network.pixel8.tunlink='any'
network.pixel8.route_allowed_ips='1'
If I readd the line I removed my network link is not visible again:
root@RUTX11:~# uci set network.wireguard.device='wg0'
root@RUTX11:~# uci commit network
root@RUTX11:~# /etc/init.d/network restart
"state": "OK"
root@RUTX11:~# wg
root@RUTX11:~#
Did you follow the tutorial? Can you show me a screenshot of your WireGuard settings?
Also, don’t forget to enable the WireGuard instance; otherwise, it won’t appear as an active interface.
harre
June 12, 2024, 10:36pm
5
Aye, I followed the tutorial.
Keys are just modified and not saved obviously
system
Closed
June 26, 2024, 9:34pm
6
