WIFI random drop to Zero Power
I have to report an issue that is causing the WIFI signal to drop to zero power.
The problem seem to have appeared after release 7.23, but I cannot be sure.
Currently I have 3 devices, 2 X RUTX50 and 1 X RUT260. All running ver. 7.25.3.
The issue is random, WIFI power is ok for few days and than will drop to zero.
Tested some of the solutions suggested in the forum without any success.
Only option is to reboot the router.
I will be available to provide all the info that Support may need to understand the issue.
I’ll be waiting for Teltonika Support to get in touch with me.
NOTE:
This I think is the same issue reported in the topic RUTX50 Wifi running, signal 0%, no ssid to be found
Thank you, kind regards
Giovanni
It is important to note that an End User Device needs to be connected to a particular radio before any power reading will be registered.
If no WiFi devices are connected, then the reading will show 0%.
Hi Mike,
yes there would be clients connected, the SSID is no longer available, so the clients have gone.
It may be worth a note that this issue has been going on for some time now, on 3 different devices in 3 different locations with 3 different configurations.
In my case there is nothing special in the config used, one SIM, one SSID, very standard.
I will pay attention next time it happens, collect the log file before and after, hope this will help.
Giovanni
To investigate and gather more information about the Wi-Fi issue, we would like to continue our communication with you privately.
We have sent you a form to complete, which you should receive in the email inbox associated with your forum account. When filling out the form, please enter 21365 in the Ticket ID field.
Once you have submitted the form, please let us know, and we will contact you privately for further investigation.
T.
I have submitted the form.
I can confirm that on one RUTX50 after the latest update to 7.25.2 this issue has got worst.
On this router I have 3 SSID and both 2.4 and 5 Ghz enabled.
So it would seems that the number of SSID configured do have a play with this problem.
The SSID disappearing happens every 3-4 days in this case.
On another router RUTX50 with just one SSID it happens circa every 2 weeks.
Waiting for your contact,
Thank you, ciao for now
Giovanni
Thank you for completing the form! I have reached out to you by email. When you have time, please check your inbox.
T.
