What power connectors do Teltonika routers use?
The RUTXR1 and RUTX50 use a 4-pin power connector directly wired to a brick.
This isn’t quite good enough for me, because I have some fairly stringent power efficiency and modularity requirements. Because of this, considering that it looks like a 4-pin ATX connector, I searched for a USB-C to 4-pin male ATX connector, and found nothing.
https://www.reddit.com/user/rokejulianlockhart/comments/167lfed/does_a_usbc_to_4pin_male_atx_connector_exist_not/?utm_source=share&utm_medium=web2x&context=3
However, today, I realized that the pins themselves are too small when compared to a standard ATX connector to be ATX. Are they proprietary? Can I get a power connector that connects to something non-country specific like IEC 60320 (C8 or C13?) or USB?
For custom applications we offer the standalone connector: 4-PIN PLUG WITH CONTACT TERMINALS
Or the whole cable with a 4-way screw terminal instead of a power brick: POWER CABLE WITH 4-WAY SCREW TERMINAL
Hope this helps!
