WAN Failover with VPN not working (RUTX50)
Hi
I have a RUTX50 with Multi Wan failover enabled, switching between a Wifi interface (prio) and a mobile interface. This works as expected.
I also have NordVPN setup on the router via the easy setup “external services”. This also works as expected, traffic goes via VPN.
Problem
However, the combination failover & VPN does not work: when the VPN is active and a failover event takes place, I loose internet access. It looks like the VPN is still trying to access via the old, unavailable interface. I have activated the 4 flush connection on all interfaces.
If I then disable and re-enable VPN (or restart the router), it works again.
I’ve sent you a form to fill out so we can continue our conversation in private, to avoid accidentally leaking any sensitive information. In the Ticket ID field, simply enter the thread’s number, which is 15081.
Issue has been resolved by upgrading to the latest firmware version.
