We spend three month in Marokko and trying to setup a VPN connection with our RUTX50 to a german VPN Server from Proton. We tried a lot configurations and sometimes it works for one or two days, but then the Maroc Telecom cut the connection. We also tried Wireguard but with the same result. Is somebody there how has experience with that issue?
thank you for the quick responce. I had a look at the other thread you mentioned and made a step by step configuration, but unfortunately with the same result. It works for 2 - 3 minutes, I get a handshake (see text below) and then after 2-3 minutes maroc telecom cuts the internet connection. After that I must disable the VPN to get a internet connection again (without VPN). I think they are able to see the VPN tunnel and cut the line.
Let me remark that I also tested the wireguard VPN on my notebook with the Proton App for Windows and that works ongoing through my router.
KR Günter
root@RUTX50:~# wg show
interface: RUTX50GP
public key: dCLR**************************
private key: (hidden)
listening port: 51820
peer: vFEx*******************************
endpoint: 217.138.216.98:51820
allowed ips: 0.0.0.0/0, ::/0
latest handshake: 2 minutes, 40 seconds ago
transfer: 404.91 KiB received, 581.55 MiB sent
persistent keepalive: every 25 seconds
For troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 17751.
