VPN Problem with IPSEC Tunnel, when a Wireguard Tunnel is also online
Apologies for the delay, and thank you for your reminder.
From the IPsec, WireGuard, and routing configurations you shared, it appears that a few configuration steps may be incorrect. To clarify, if I understood it properly, your goal is to split the traffic originating from the two interfaces (Terminal 1 and Terminal 2) so that each interface’s traffic is routed through either the IPsec or WireGuard tunnel, correct?
If that’s the case, you’ll need to create two separate routing tables, which can be set up using Policy Based Routing (PBR) under Network → Routing → PBR. Previously configured static routes should be ignored and removed, as PBR will take precedence for specific traffic flows.
It would be useful to review our wiki guide on traffic splitting through multiple interfaces to better understand how PBR works, as well as similar forum threads discussing this setup:
If you experience difficulties setting up PBR, please feel free to share your current configurations and describe how you want the traffic between tunnels to be split.
