Vpn Ipsec Problem dual sim
I need to configure a RUTX12 router to connect to two separate IPsec VPNs, one for each SIM card. I have already set up a DDNS service (similar to DynDNS) on both SIM interfaces so the router can be reached remotely.
I am having trouble configuring the routing for these two simultaneous connections. Could you please help me with the correct setup? Thank you.
I can see that you have already created a similar topic here: Help VPN ipsev Rutx12
I kindly ask you to continue the discussion in the original topic.
Thank you.
