TSWOS mrp multi-manager and multi-ring
Is there a way to change/upgrade the TSWOS to support multiple managers in an mrp-ring? I spotted some indicators for the multi-manager-role in some of the header-files from the sdk, but I’m a too far away from C-Programming for a diy-fix… Is it already hidden under the hood but only missing in the web-UI?
Another thing is a multi-ring-topology, where a switch is part or (multi-)manager of two or more mrp-rings at once. Any plans for this feature?
Both features are included in switches from other manufacturers and it would be a great improvement to see those on teltonika switches as well!
Best regards!
Axel
You seem to have a topic open here: TSWOS mrp multi-manager and multi-ring?
To prevent double-communication I’ll be closing this topic and will have to ask you to continue further conversations on the linked topic.
Thank you for understanding,
