Is there a way to change/upgrade the TSWOS to support multiple managers in an mrp-ring? I spotted some indicators for the multi-manager-role in some of the header-files from the sdk, but I’m a too far away from C-Programming for a diy-fix… Is it already hidden under the hood but only missing in the web-UI?
Another thing is a multi-ring-topology, where a switch is part or (multi-)manager of two or more mrp-rings at once. Any plans for this feature or allready possible?
Both features are included in switches from other manufacturers and it would be a great improvement to see those on teltonika switches as well!
I have received an update from our R&D team regarding your inquiry.
The requested functionality is planned to be implemented in future firmware releases. However, at this time I do not have an exact ETA for when this feature will be introduced.
Additionally, multi-ring topologies are supported, but the configuration currently needs to be performed using plain uci commands. For the time being, this configuration option is not exposed in the WebUI.
If I receive any further updates regarding the availability of this feature in upcoming firmware versions, I will make sure to inform you.
Thank you for the additional feedback, and glad the multi-ring information was useful. Also please accept my sincere apologies for a delayed response.
To follow up:
On multi-ring configuration via UCI:
So I can provide accurate configuration steps for your specific setup, could you confirm:
Which TSW model and firmware version you’re running.
How many rings you’re looking to configure, and which ports/interfaces are intended for each ring.
Once I have those details, I’ll put together the correct uci steps for your setup rather than a generic example, to avoid any misconfiguration on your side.
On multi-manager support:
This remains planned for a future firmware release with no confirmed ETA at this time. I’ll continue to update this thread if that changes.
On firewall logic / VLAN integration:
Thank you for raising this - I’ve forwarded it to our R&D team as a suggestion, alongside the multi-manager request. If you have a specific use case in mind (e.g., per-VLAN filtering rules, or something closer to the RutOS firewall model), it would help R&D scope the request - feel free to share more detail if you’d like it included.
I’ll follow up here as soon as I have updates on either item.
I’m planning a setup with two independent MRP rings, each consisting of approximately 10 TSW202 switches, connected to a central SWM281 acting as MRP Manager for both rings:
Ring 1: SFP1–SFP2
Ring 2: SFP3–SFP4
Both rings will share some data VLANs, but I’d like to confirm that MRP control frames (IEC 62439-2) remain isolated within their respective MRP domains, even when VLAN traffic is bridged between the rings.
Also, out of curiosity, does TSWOS transmit MRP control frames over VLAN 1, or are they sent untagged?
thanks for your effort and also for your message, @Vilius . I’m a bit late as well …
My setup with several tsw212-switches and multiple mrp-domains would look like this
switch1:
eth-port1 & eth-port2: mrp-domain-sub1 as “mrp automanager”
sfp-port1 & sfp-port2: mrp-domain-glob1 as “mrp automanager”
switch2:
eth-port1 & eth-port2: mrp-domain-sub2 as “mrp automanager”
switch3:
eth-port1 & eth-port2: mrp-domain-sub3 as “mrp automanager”
switchX:
eth-port1 & eth-port2: mrp-domain-subX as “mrp automanager”
All switches are connected to a bigger mrp-domain named “mrp-domain-glob1” with their sfp-ports, while serving as local “mrp-domain-subX”-automanagers as well (in conjunction with industrial plc’s and several IO-stations, also capable of mrp-automanager-feature).
Participants in any “mrp-domain-subN” should be able to reach any participant in any “mrp-domain-subX” and vice-versa, so no VLAN-tagging should be needed in this case. Also the other eth-ports2..8 on each switch should still be usable, to form a “global” switched network. The connection-redundancy should be handled only within each mrp-domain, like @gilito mentioned for his use-case.
All ports still should be reachable via one or more responsible profinet-masters, so that the ports can be switched on/off and monitored by the assigned profinet-masters.
Thank you for providing the details of your proposed topology.
We will verify whether the SWM281 supports managing both MRP rings simultaneously using the specified SFP port pairs. We will also check how MRP control frames are handled when the rings share data VLANs, including whether the frames are transmitted untagged or associated with a specific VLAN.
To help us verify the configuration for your setup, could you please provide:
The firmware version running on the SWM281.
The firmware version or versions running on the TSW202 switches.
Confirmation of whether the two rings will have any physical connections between them other than through the SWM281.
This information will allow me to investigate further,
