TSW202 SFP 100Mb (155Mbps) Modules
Hi Team
We’re looking at using TSW202 in an industrial environment, the same this post:
TSW202 is a really attractive option, as its L3 and managed, at a really good price point.
The site is pretty big and uses 155mbps, 1310uM Multimode (on OM1 fibre, which is probably not relevant, but it only supports lower data rates at longer distances), to give a maximum link range of 2km.
We have tried some StarTech SFP modules which use the standard above but we cant get the TSW202 to link, or at least, they do occasionally link to other devices using these modules but are really erratic. Using other modules to link to more modern switches at 1Gbps works fine.
Placing the same modules in an older desktop ZyXel switch that supports 100Mbps SFP connections works flawlessly with the same module when linking to other unmanaged switches on the network.
The TSW202 is an industrial switch and as such it really needs the ability to connect to other industrial switches at 100mbps, which is a fairly widely used standard. Has anyone found a solution to this?
Thanks :slight_smile:
Our R&D team is currently investigating the possibility of adding the functionality you described.
Marijus
Thanks for your help, do you have an estimated timescale for this?
We can’t give any time scale for this feature implementation, as it is only in the testing phase.
Thanks, happy to test a beta firmware for this if its helpful. Also, can we we notified once the feature has been released in a firmware revision?
I’m happy to hear that you are willing to test it! This should be noted in the firmware update logs. I’ll mark this post and will update this topic when we have new firmware or any news on it.
