TSW202 - PoE wont switch off from CLI/SSH
Hello
I noted this thread for controlling the POE from CLI/SSH
When I attempted the command, I initially got an error
admin@TSW202:~$ uci set tswconfig.port1.poe_enable=‘0’
uci: I/O error
admin@TSW202:~$
I logged in as “root” and the command was accepted without error but the POE on the port did not go off.
root@TSW202:~# uci set tswconfig.port1.poe_enable=‘0’
root@TSW202:~#
root@TSW202:~# uci set tswconfig.port4.poe_enable=‘0’
root@TSW202:~#
root@TSW202:~#
the uci show status indicates that the value was set to “0” on the ports that had the command run.
root@TSW202:~# uci show tswconfig.port1.poe_enable
root@TSW202:~# uci show tswconfig.port4.poe_enable
root@TSW202:~# uci show tswconfig.port2.poe_enable
uci: Entry not found
Why is the POE not switching off
Probably because poe configuration was moved from /etc/config/tswconfig to /etc/config/poe
Hello HRTX
thankyou for the quick reply
I also tried
uci set poe.port1.poe_enable=‘0’
This did not switch off the POE on Port1 but I did notice that it toggled the POE radio button on the GUI for port 1
Maybe
uci set poe.port1.poe_enable=‘0’ && uci commit && reload_config
Ok will try that when next in the lab
many thanks
Hi hrtx
The command
worked to turn off the POE on the required port but I was unable to turn POE back on using the same script even though the get command indicated it was set back to 1
root@aucct-aqt-esw-l01:~# uci set poe.port1.poe_enable=‘0’ && uci commit && reload_config
root@aucct-aqt-esw-l01:~# uci get poe.port1.poe_enable
‘0’
root@aucct-aqt-esw-l01:~# uci set poe.port1.poe_enable=‘1’ && uci commit && reload_config
‘1’
Hi rlibrizzi,
Can you try this commands to turn PoE off/on?
Turning Off PoE
uci set poe.port1.poe_enable='0' && uci commit poe && reload_config
Turning On PoE
uci set poe.port1.poe_enable='1' && uci commit poe && reload_config
The only difference is that we are saving the ‘poe’ instance using uci commit command.
Let me know if this helps.
Regards.
