TSW202 - control PoE from CLI/SSH
Is there a way to control PoE on a port via CLI/SSH? I need to do 4 power cycle on a Cambium AP to reset, but i cannot do this via web interface, because i have to switch off and on again in 4 secs.
Thank you for your help.
Cheers,
Zoltan
Yes, you can control Power over Ethernet (PoE) on ports through SSH/CLI using uci commands. Follow this guide to achieve it:
Access your TSW202 device’s SSH or CLI via WebUI.
Execute the following commands:
To turn off port #1:
    uci set tswconfig.port1.poe_enable='0'
To turn on port #1:
     uci set tswconfig.port1.poe_enable='1'
Note: You can apply these commands to any of the 8 available ports.
000116
You can create a script using these commands for a quick PoE off/on cycle.
Marijus
Thank you, its working :slight_smile: And yes, i can write a small script to add the timing to the power cycle.
Cheers,
Zoltan
