TRB501 – Intermittent loss of Internet due to modem crashes
Thanks @Matas for the quick reply, I’ve filled out the form. Running gsmctl -y outputs RG520NEBDCR03A01M4G_OCPU_02.200.00.000 same as bofh’s version.
I am experiencing the same issue on my TRB501.
The modem randomly restarts and I see messages like:
  • rmnet_ipa3 started initialization
  • wlan_msg_process failed
  • lan_msg_process failed
  • subsystem_restart_wq_func(): Restart sequence for modem completed
After that, the modem reconnects again.
I am currently using modem firmware:
Has anyone found a stable solution or workaround for this problem?
Did updating RutOS or modem firmware help?
Is this related to 5G NSA, carrier aggregation, or specific operators?
Any help would be appreciated.
Thanks!
[ 4343.721465] QTI: Modem is down
[ 4353.826148] subsys-pil-tz 4080000.qcom,mss: modem: Brought out of reset
[ 4353.826199] subsys-pil-tz: subsys_powerup(): pil_boot is successful from modem and waiting for error ready
[ 4353.846783] subsys-pil-tz 4080000.qcom,mss: modem: Power/Clock ready interrupt received
[ 4353.847060] subsys-pil-tz: subsys_err_ready_intr_handler(): Subsystem error monitoring/handling services are up frommodem
[ 4353.856368] ipa-wan ipa3_lcl_mdm_ssr_notifier_cb:4417 IPA received MPSS AFTER_POWERUP
[ 4353.864959] rmnet_ipa3 started initialization
[ 4353.872554] IPA SSR support = True
[ 4353.876857] IPA SG support = False
[ 4353.880160] IPA Napi Enable = False
[ 4353.883531] using default for wan-rx-desc-size = 256
[ 4353.887284] ipa-wan ipa3_wwan_register_netdev_pm_client:3833 rmnet_ipa%d register done
[ 4353.892652] ipa-wan ipa3_wwan_probe:4038 rmnet_ipa completed initialization
[ 4353.900539] ipa ipa3_odl_pipe_open:371 adpl pipe not configured
[ 4353.906733] ipa-wan ipa3_lcl_mdm_ssr_notifier_cb:4422 IPA AFTER_POWERUP handling is complete
[ 4353.912660] subsys-restart: subsystem_restart_wq_func(): [kworker/u3:2:18793]: Restart sequence for modem completed.
[ 4353.924208] qcom_smd_qrtr_probe:Entered
[ 4353.949635] qcom_smd_qrtr_probe:SMD QRTR driver probed
[ 4353.949744] qrtr: Modem QMI Readiness RX cmd:0x2 node[0x3]
[ 4353.953895] qrtr: Modem QMI Readiness TX cmd:0x2 node[0x2]
[ 4353.970384] qrtr: announce_servers(): Avoiding duplicate announce for NODE ID 3
[ 4353.970672] sysmon-qmi: ssctl_new_server: Connection established between QMI handle and modem's SSCTL service
[ 4354.312054] coresight-remote-etm soc:modem2_etm0: Connection established between QMI handle and 11 service
[ 4354.312143] coresight-remote-etm soc:modem_etm0: Connection established between QMI handle and 2 service
[ 4354.398178] Sending QMI_IPA_INIT_MODEM_DRIVER_REQ_V01
[ 4354.418440] QMI_IPA_INIT_MODEM_DRIVER_REQ_V01 response received
[ 4354.418491] ipa ipa3_send_msg:619 wlan_msg_process failed
[ 4354.430155] ipa ipa3_send_msg:622 lan_msg_process failed
[ 4354.430540] ipa-wan ipa3_check_qmi_response:609 Got bad response 49 from request id 1 (error 48)
[ 4354.434533] ipa-wan rmnet_ipa_get_network_stats_and_update:4596 ipa3_qmi_get_network_stats failed: 1
[ 4357.252594] QTI: DPM Init cb
[ 4357.696510] QTI:DPM port closed
[ 4357.719917] QTI:USB tethered modem SMD port opened
[ 4357.762153] QTI: Modem is up
[ 4358.423033] ipa ipa3_set_aggr_limit:4873 get close-by 8192
[ 4358.423067] ipa ipa3_set_aggr_limit:4875 set default rx_buff_sz 7808
[ 4358.456057] ipa3_wwan_ioctl: 5 callbacks suppressed
[ 4358.456062] ipa-wan ipa3_wwan_ioctl:3153 dev(rmnet_data0) register to IPA
root@TRB501:~# gsmctl -y
root@TRB501:~#
A form has been sent to you as well. The ID that you’ll have to fill out needs to be 16039-8. Once the form appears in our system, I’ll reach out to you, so we can discuss further details.
Matas.
i have the same Problem with 3 TRB501 can you also send me the Modemupdate?
RutOS Version: TRB501_R_00.07.23.2
Thanks a lot
Hello there,
Same goes to you - sent the form, use the ID of 16039-9 please.
Matas.
Hey everyone!
We’ve posted instructions on how to upgrade your own TRB501 modem firmwares to speed up the process, please refer to this topic: Modem Firmware Update guide for TRB501 RG520NEBDC
We’ll be locking this thread, in case further issues occur, don’t hesitate to post feedback under the new thread.
Matas.
