TRB145 brick after firmware upgrade
My TRB145 device is no longer reachable via network after the update. In fact, when I connect the USB cable, it no longer assigns an IP address automatically. At the moment, it is not usable, and the 2G/3G/4G LEDs are flashing continuously. Is there a way to recover it? it is possible to use the rs485 to login in openwrt?
Thank you in advance.
If you haven’t tried it yet, I would suggest attempting a factory reset of your device. Here is the information on how to do it: link to the TRB145 Device Recovery Options
If after this procedure the device still does not boot, you can try accessing your device via the bootloader menu. Instructions on how to do this can be found here: link to the Bootloader menu instructions
Marijus
Thanks Marijus…YES the factory reset has been done but nothing…Anyway I will try the bootloader procedure…I was wondering if the bootloader procedure that you sent me is ok also for TRB145
thanks
Sorry for mix-up, I mistaken TRB145 to TRB245. Just to clarify, the TRB145 does not have an available bootloader procedure, but it can utilize fastboot.
Please try to perform the following procedure with TRB1XX series device:
  1. Download “ADB software” and “rootfs.ubi” file from here: https://kaunas.teltonika.lt:444/f/a9ffe2e9d98446f2aaf3/?dl=1
  2. Install ADB software. More information can be found in this forum page(Video tutorial - https://www.youtube.com/watch?v=LbAq6d2Du0U)
  3. Turn off/unplug TRB145
  4. Press and hold reset button, at the same time plug the power cable and keep holding reset button for about 5 seconds (mobile signal LED’s should start blinking). Connect TRB to PC via USB cable.
  5. Place rootfs.ubi file in any easily accessible directory (e.g. in “C:\Test”)
  6. Open CMD (“Command Prompt” window) with administrator rights
  7. Use cd command to navigate to the place where you saved the rootfs.ubi file (Example: cd C:\Test)
  8. Then use this command: fastboot flash rootfs_a rootfs.ubi
  9. When it completes, use this command: fastboot flash rootfs_b rootfs.ubi
  10. When both commands are executed and finished running, unplug power from TRB and plug it again. It should boot up as normal (or use fastboot reboot command)
  11. Install desired firmware version to TRB through WebUI. Latest firmware can be downloaded from here: TRB145 Firmware Downloads - Teltonika Networks Wiki
Marijus
Hi @Marijus,
done! but the result is that the operating system now reboot continusly…below some detail:
Format: Log Type - Time(microsec) - Message - Optional Info
Log Type: B - Since Boot(Power On Reset),  D - Delta,  S - Statistic
S - QC_IMAGE_VERSION_STRING=BOOT.BF.3.1.2-00084
S - IMAGE_VARIANT_STRING=LAATANAZA
S - OEM_IMAGE_VERSION_STRING=HF-SW-P2-HARDEN
S - Boot Config, 0x000002e1
B -      1216 - PBL, Start
B -      3723 - bootable_media_detect_entry, Start
B -      4434 - bootable_media_detect_success, Start
B -      4438 - elf_loader_entry, Start
B -      6682 - auth_hash_seg_entry, Start
B -      6903 - auth_hash_seg_exit, Start
B -     56329 - elf_segs_hash_verify_entry, Start
B -    101105 - PBL, End
B -    109556 - SBL1, Start
B -    168116 - pm_device_init, Start
B -    187971 - PM_SET_VAL:Skip
D -     18086 - pm_device_init, Delta
B -    188978 - boot_config_data_table_init, Start
D -    174948 - boot_config_data_table_init, Delta - (420 Bytes)
B -    367433 - CDT version:3,Platform ID:8,Major ID:1,Minor ID:0,Subtype:0
B -    373594 - sbl1_ddr_set_params, Start
B -    377437 - Pre_DDR_clock_init, Start
D -       213 - Pre_DDR_clock_init, Delta
D -         0 - sbl1_ddr_set_params, Delta
S - This JSC 4+2 or 2+2 MCP, DDR_id=[0x1c],density=[0x5]
B -    594780 - pm_driver_init, Start
D -      4544 - pm_driver_init, Delta
B -    599416 - cpr_init, Start
D -        91 - cpr_init, Delta
B -    602192 - cpr_cx_mx_apc_vol_update, Start
D -        91 - cpr_cx_mx_apc_vol_update, Delta
B -    616771 - sbl1_qhsusb_al_do_fast_enum, Start
D -         0 - sbl1_qhsusb_al_do_fast_enum, Delta
B -    619912 - clock_init, Start
D -       152 - clock_init, Delta
B -    625707 - boot_flash_init, Start
D -     27419 - boot_flash_init, Delta
B -    659928 - Image Load, Start
B -    659959 - [QUEC_SECBOOT]Image Type = 1
B -    663619 - [QUEC_SECBOOT]Image Auth Enable Sate = 1
B -    671152 - [QUEC_SECBOOT]Image Auth Result Sate = 0
D -     76006 - QSEE Image Loaded, Delta - (491164 Bytes)
D -       183 - boot_pm_post_tz_device_init, Delta
B -    740357 - sbl1_efs_handle_cookies, Start
D -         0 - sbl1_efs_handle_cookies, Delta
B -    747646 - Devcfg Partition does not exist
B -    751916 - Image Load, Start
D -        30 - SEC Image Loaded, Delta - (0 Bytes)
B -    759572 - Image Load, Start
B -    762500 - [QUEC_SECBOOT]Image Type = 1
B -    769362 - [QUEC_SECBOOT]Image Auth Enable Sate = 1
B -    776743 - [QUEC_SECBOOT]Image Auth Result Sate = 0
D -     36234 - RPM Image Loaded, Delta - (153504 Bytes)
B -    795867 - Image Load, Start
B -    797514 - [QUEC_SECBOOT]Image Type = 1
B -    802668 - [QUEC_SECBOOT]Image Auth Enable Sate = 1
B -    806694 - [QUEC_SECBOOT]Image Auth Result Sate = 0
D -     55967 - APPSBL Image Loaded, Delta - (321916 Bytes)
B -    851865 - QSEE Execution, Start
D -       213 - QSEE Execution, Delta
B -    857538 - SBL1, End
D -    750361 - SBL1, Delta
S - Throughput, 3000 KB/s  (967004 Bytes,  304626 us)
S - DDR Frequency, 240 MHz
Android Bootloader - UART_DM Initialized!!!
[0] welcome to lk (build: 2023-11-07-d48a3687a6)
[0] SCM call: 0x2000601 failed with :fffffffc
[0] Failed to initialize SCM
[10] platform_init()
[10] target_init()
[10] 111 flash->id=0x1590acad,supported_flash[0]=0x1590ac2c, flash->id2=0x90acad56, supported_flash_id2=0x56[20] 111 flash->id=0x1590acad,supported_flash[1]=0x1590ac01, flash->id2=0x90acad56, supported_flash_id2=0x56[30] 111 flash->id=0x1590acad,supported_flash[2]=0x1590aaad, flash->id2=0x90acad56, supported_flash_id2=0x46[40] 111 flash->id=0x1590acad,supported_flash[3]=0x1590aa98, flash->id2=0x90acad56, supported_flash_id2=0x76[50] 111 flash->id=0x1590acad,supported_flash[4]=0x1590aa2c, flash->id2=0x90acad56, supported_flash_id2=0x6[50] 111 flash->id=0x1590acad,supported_flash[5]=0x1590acad, flash->id2=0x90acad56, supported_flash_id2=0x56[60] smem ptable found: ver: 4 len: 19
CTRL+C: enter fasboot
[170] flash_read_image: success (0 errors)
[170] @Ramos Ql_check_RestoreFlag:offset=4a0000, magic1=78e5d4c2,magic2=54f7d60e[180] [carl]msg1.backup_flag = �����������������������������������x��T
[190] [carl] quec_backup_cefs is ok
[190] @francis QuecBackupInfo.cefs_restore_flag=0
[910] Authenticating boot image (5281792): start
[960] ERROR: Image Invalid! signature check failed! ret -1
[960] Authenticating boot image: done return value = 0
[1010] DTB Total entry: 5, DTB version: 3
[1020] Using DTB entry 0x00000129/00010000/0x00000008/0 for device 0x00000129/00010000/0x00010008/0
[1060] boot configuration: a, kernel: boot_a, rootfs: rootfs_a
[1060] cmdline: console=ttyMSM0,115200,n8 earlycon=msm-uartdm,0x78b3000 ubi.fm_autoconvert=1 ubi.mtd=rootfs_a ubi.block=0,0 root=/dev/ubiblock0_0 rootfstype=squashfs ubi.mtd=modem ubi.block=1,0 ubi.mtd=storage
[1080] booting linux @0x80008000, ramdisk @0x81100000 (0), tags/device tree @0x81e00000
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.4.221 (app@runner-xs3tzhbe-project-352-concurrent-1) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r16279-5cc0535800)) #0 Tue Feb 7 12:46:36 2023
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Teltonika TRB14X
[    0.000000] Memory policy: Data cache writeback
[    0.000000] Removed memory: created DMA memory pool at 0x82700000, size 83 MiB
[    0.000000] OF: reserved mem: initialized node modem_adsp_region@0, compatible id removed-dma-pool
[    0.000000] Removed memory: created DMA memory pool at 0x87c00000, size 4 MiB
[    0.000000] OF: reserved mem: initialized node external_image_region@0, compatible id removed-dma-pool
[    0.000000] cma: Reserved 4 MiB at 0x8fc00000
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 42688
[    0.000000] Kernel command line: console=ttyMSM0,115200,n8 earlycon=msm-uartdm,0x78b3000 ubi.fm_autoconvert=1 ubi.mtd=rootfs_a ubi.block=0,0 root=/dev/ubiblock0_0 rootfstype=squashfs ubi.mtd=modem ubi.block=1,0 ubi.mtd=storage
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 155804K/173056K available (6522K kernel code, 490K rwdata, 1924K rodata, 1024K init, 348K bss, 13156K reserved, 4096K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] arch_timer: mmio timer(s) running at 19.20MHz (virt).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000009] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000023] Switching to timer-based delay loop, resolution 52ns
[    0.000679] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.000699] pid_max: default: 32768 minimum: 301
[    0.000874] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.000889] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.001708] CPU: Testing write buffer coherency: ok
[    0.002726] Setting up static identity map for 0x80100000 - 0x80100060
[    0.021352] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.021610] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.021632] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[    0.021921] pinctrl core: initialized pinctrl subsystem
[    0.023931] NET: Registered protocol family 16
[    0.025277] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.026177] cpuidle: using governor ladder
[    0.026192] cpuidle: using governor menu
[    0.032754] mem_acc_corner: Bringing 0uV into 1-1uV
[    0.034735] No ATAGs?
[    0.051556] msm_smsm_probe: missing key: irq-reg-base
[    0.052877] smd_channel_probe_now: allocation table not initialized
[    0.053370] msm_rpm_glink_dt_parse: qcom,rpm-glink compatible not matches
[    0.053383] msm_rpm_dev_probe: APSS-RPM communication over SMD
[    0.062016] mdm9607_s3_level: Bringing 1uV into 16-16uV
[    0.062446] mdm9607_s3_level_ao: Bringing 1uV into 16-16uV
[    0.062888] mdm9607_s3_floor_level: Bringing 1uV into 16-16uV
[    0.065276] mdm9607_s3_level_so: Bringing 1uV into 16-16uV
[    0.071919] mdm9607_l12_level: Bringing 1uV into 16-16uV
[    0.072388] mdm9607_l12_level_ao: Bringing 1uV into 16-16uV
[    0.082318] mdm9607_l12_level_so: Bringing 1uV into 16-16uV
[    0.082818] mdm9607_l12_floor_lebel: Bringing 1uV into 16-16uV
[    0.085755] cpr_efuse_init: apc_corner: efuse_addr = 0x000a4000 (len=0x1000)
[    0.085807] cpr_read_fuse_revision: apc_corner: fuse revision = 2
[    0.085823] cpr_parse_speed_bin_fuse: apc_corner: [row: 37]: 0x88002032616513dd, speed_bits = 4
[    0.085907] cpr_pvs_init: apc_corner: pvs voltage: [1050000 1100000 1262500] uV
[    0.085919] cpr_pvs_init: apc_corner: ceiling voltage: [1050000 1225000 1350000] uV
[    0.085931] cpr_pvs_init: apc_corner: floor voltage: [1050000 1050000 1150000] uV
[    0.088227] sps:sps is ready.
[    0.129054] qcom,gcc-mdm9607 1800000.qcom,gcc: Registered GCC clocks
[    0.129713] msm_bus_fabric_init_driver
[    0.137176] KPI: Bootloader start count = 30792
[    0.137194] KPI: Bootloader end count = 66841
[    0.137205] KPI: Bootloader load kernel count = 1608966860
[    0.137214] KPI: Kernel MPM timestamp = 79959
[    0.137222] KPI: Kernel MPM Clock frequency = 32768
[    0.137244] socinfo_print: v0.10, id=297, ver=1.0, raw_id=72, raw_ver=0, hw_plat=8, hw_plat_ver=65536
[    0.137244]  accessory_chip=0, hw_plat_subtype=0, pmic_model=65539, pmic_die_revision=131074 foundry_id=1 serial_number=1634014173
[    0.137860] usbcore: registered new interface driver usbfs
[    0.137926] usbcore: registered new interface driver hub
[    0.137993] usbcore: registered new device driver usb
[    0.151673] workqueue: max_active 576 requested for napi_workq is out of range, clamping between 1 and 512
[    0.153264] clocksource: Switched to clocksource arch_sys_counter
[    0.187686] thermal_sys: Registered thermal governor 'step_wise'
[    0.187696] thermal_sys: Registered thermal governor 'user_space'
[    0.195450] NET: Registered protocol family 2
[    0.195786] IP idents hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.196495] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.196535] TCP established hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.196568] TCP bind hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.196600] TCP: Hash tables configured (established 2048 bind 2048)
[    0.196700] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.196725] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.196988] NET: Registered protocol family 1
[    0.199749] workingset: timestamp_bits=14 max_order=16 bucket_order=2
[    0.205109] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.205127] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.221788] qcom-sps-dma 7884000.qcom,sps-dma: dma_async_device_register: device has no channels!
[    0.224978] pil-q6v5-mss 4080000.qcom,mss: assigned reserved memory node modem_adsp_region@0
[    0.225349] pil-q6v5-mss 4080000.qcom,mss: No pas_id found.
[    0.226054] pil-q6v5-mss 4080000.qcom,mss: for modem segments only will be dumped.
[    0.226892] msm_serial 78b3000.serial: msm_serial: detected port #0
[    0.226934] msm_serial 78b3000.serial: uartclk = 7372800
[    0.227001] 78b3000.serial: ttyMSM0 at MMIO 0x78b3000 (irq = 22, base_baud = 460800) is a MSM
[    0.227021] msm_serial: console setup on port #0
[    0.862962] printk: console [ttyMSM0] enabled
[    0.868160] msm_serial: driver initialized
[    0.872331] uart_tx_gpio is not available
[    0.875956] uart_rx_gpio is not available
[    0.879960] uart_cts_gpio is not available
[    0.883998] uart_rfr_gpio is not available
[    0.888006] msm_serial_hs 78b1000.uart: IRQ wakeup_irq not found
[    0.892025] Wakeup irq not specified
[    0.899311] sps: BAM device 0x07884000 is not registered yet.
[    0.902039] sps:BAM 0x07884000 is registered.
[    0.904569] 78b1000.uart: ttyHS0 at MMIO 0x78b1000 (irq = 23, base_baud = 460800) is a MSM HS UART
[    0.911730] msm_hs_set_mctrl_locked(): Clocks are off
[    0.929288] random: crng init done
[    0.938355] msm_nand_bus_register: couldn't register due to missing config option
[    0.938468] sps: BAM device 0x07984000 is not registered yet.
[    0.945219] sps:BAM 0x07984000 is registered.
[    0.945236] msm_nand_bam_init: msm_nand_bam_init: BAM device registered: bam_handle 0xced94400
[    0.955704] sps:BAM 0x07984000 (va:0x43e6b66f) enabled: ver:0x18, number of pipes:7
[    0.964049] msm_nand_version_check: nand_major:1, nand_minor:5, qpic_major:1, qpic_minor:5
[    0.970947] msm_nand_parse_smem_ptable: Parsing partition table info from SMEM
[    0.979394] msm_nand_parse_smem_ptable: SMEM partition table found: ver: 4 len: 19
[    0.986539] msm_nand_version_check: nand_major:1, nand_minor:5, qpic_major:1, qpic_minor:5
[    0.994108] msm_nand_flash_onfi_probe: msm_nand_flash_onfi_probe: no apps partition found in smem
[    1.002317] msm_nand_scan: NAND Id: 0x1590acad Buswidth: 8Bits Density: 512 MByte
[    1.011262] msm_nand_scan: pagesize: 2048 Erasesize: 131072 oobsize: 128 (in Bytes)
[    1.018727] msm_nand_scan: BCH ECC: 4 Bit
[    1.026196] msm_nand_scan: CFG0: 0x2a0408c0,           CFG1: 0x0804745c
[    1.026196]             RAWCFG0: 0x2c8400c0,        RAWCFG1: 0x0005055d
[    1.026196]           ECCBUFCFG: 0x00000203,      ECCBCHCFG: 0x42040700
[    1.026196]           RAWECCCFG: 0x42000701, BAD BLOCK BYTE: 0x000001d1
[    1.034655] Creating 19 MTD partitions on "7980000.nand":
[    1.056608] 0x000000000000-0x000000140000 : "sbl"
[    1.062868] 0x000000140000-0x000000280000 : "mibib"
[    1.067460] 0x000000280000-0x000001880000 : "efs2"
[    1.072087] 0x000001880000-0x000001d80000 : "sys_rev"
[    1.077028] 0x000001d80000-0x000002080000 : "rawdata"
[    1.082036] 0x000002080000-0x000002240000 : "cust_info"
[    1.087172] 0x000002240000-0x000002540000 : "oemapp"
[    1.092166] 0x000002540000-0x000002680000 : "tz"
[    1.097447] 0x000002680000-0x0000027c0000 : "rpm"
[    1.101941] 0x0000027c0000-0x000002900000 : "aboot"
[    1.106643] 0x000002900000-0x000002a40000 : "mnf_info"
[    1.111244] 0x000002a40000-0x000002b80000 : "boot_config"
[    1.116524] 0x000002b80000-0x000003480000 : "boot_a"
[    1.121915] 0x000003480000-0x000003d80000 : "boot_b"
[    1.127069] 0x000003d80000-0x000007980000 : "modem"
[    1.131886] 0x000007980000-0x000007ac0000 : "misc"
[    1.136593] 0x000007ac0000-0x00000f200000 : "rootfs_a"
[    1.141362] 0x00000f200000-0x000016940000 : "rootfs_b"
[    1.146601] 0x000016940000-0x000020000000 : "storage"
[    1.151592] msm_nand_probe: NANDc phys addr 0x7980000, BAM phys addr 0x7984000, BAM IRQ 20
[    1.156182] msm_nand_probe: Allocated DMA buffer at virt_addr 0xa214a9b3, phys_addr 0x8fc44000
[    1.164313] msm_nand_probe: Host capabilities:0x00000000
[    1.183764] spmi spmi-0: PMIC arbiter version v2 (0x20010000)
[    1.184666] PMIC@SID0: PM8019 v2.2 options: 3, 2, 2, 2
[    1.188874] qcom,qpnp-power-on 200f000.qcom,spmi:qcom,pm8019@0:qcom,power_on@800: PMIC@SID0 Power-on reason: Triggered from CBL (External Power Supply) and 'warm' boot
[    1.193639] qcom,qpnp-power-on 200f000.qcom,spmi:qcom,pm8019@0:qcom,power_on@800: PMIC@SID0: Unknown power-off reason
[    1.208502] qcom,qpnp-power-on 200f000.qcom,spmi:qcom,pm8019@0:qcom,power_on@800: IRQ pmic-wd-bark not found
[    1.219349] input: qpnp_pon as /devices/platform/200f000.qcom,spmi/spmi-0/0-00/200f000.qcom,spmi:qcom,pm8019@0:qcom,power_on@800/input/input0
[    1.233688] spm_regulator_probe: name=mdm9607_s1, range=LV, voltage=1100000 uV, mode=AUTO, step rate=4800 uV/us
[    1.243478] msm_otg 78d9000.usb: msm_otg probe
[    1.251644] msm_otg 78d9000.usb: IRQ pmic_id_irq not found
[    1.263048] msm_otg 78d9000.usb: OTG regs = cd6bf1a1
[    1.264444] msm_otg 78d9000.usb: IRQ phy_irq not found
[    1.270121] qcom,qpnp-rtc 200f000.qcom,spmi:qcom,pm8019@0:rtc: registered as rtc0
[    1.281738] msm_otg 78d9000.usb: phy_reset: success
[    1.282100] QCE50: __qce_get_device_tree_data: BAM Apps EE is not defined, setting to default 1
[    1.286231] qcrypto 720000.qcrypto: QTI Crypto 5.3.3 device found @0x720000
[    1.294515] sps:BAM 0x00704000 is registered.
[    1.295101] sps:BAM 0x00704000 (va:0xd1dcbbbd) enabled: ver:0x27, number of pipes:8
[    1.306135] QCE50: qce_sps_init:  QTI MSM CE-BAM at 0x0000000000704000 irq 34
[    1.316358] qcrypto 720000.qcrypto: qcrypto-ecb-aes
[    1.320507] qcrypto 720000.qcrypto: qcrypto-cbc-aes
[    1.325209] qcrypto 720000.qcrypto: qcrypto-ctr-aes
[    1.330057] qcrypto 720000.qcrypto: qcrypto-ecb-des
[    1.334950] qcrypto 720000.qcrypto: qcrypto-cbc-des
[    1.339758] qcrypto 720000.qcrypto: qcrypto-ecb-3des
[    1.344639] qcrypto 720000.qcrypto: qcrypto-cbc-3des
[    1.349826] qcrypto 720000.qcrypto: qcrypto-xts-aes
[    1.354815] qcrypto 720000.qcrypto: qcrypto-sha1
[    1.359386] qcrypto 720000.qcrypto: qcrypto-sha256
[    1.364255] qcrypto 720000.qcrypto: qcrypto-aead-hmac-sha1-cbc-aes
[    1.368839] qcrypto 720000.qcrypto: qcrypto-aead-hmac-sha1-cbc-des
[    1.375049] qcrypto 720000.qcrypto: qcrypto-aead-hmac-sha1-cbc-3des
[    1.381163] qcrypto 720000.qcrypto: qcrypto-aead-hmac-sha256-cbc-aes
[    1.387375] qcrypto 720000.qcrypto: qcrypto-aead-hmac-sha256-cbc-des
[    1.394206] qcrypto 720000.qcrypto: qcrypto-aead-hmac-sha256-cbc-3des
[    1.401183] qcrypto 720000.qcrypto: qcrypto-hmac-sha1
[    1.406663] qcrypto 720000.qcrypto: qcrypto-hmac-sha256
[    1.411657] qcrypto 720000.qcrypto: qcrypto-aes-ccm
[    1.416762] qcrypto 720000.qcrypto: qcrypto-rfc4309-aes-ccm
[    1.626249] sps:BAM 0x078c4000 is registered.
[    1.630054] qcom-spmi-vadc 200f000.qcom,spmi:qcom,pm8019@0:vadc@3100: IRQ index 0 not found
[    1.643785] NET: Registered protocol family 10
[    1.645863] Segment Routing with IPv6
[    1.647207] NET: Registered protocol family 17
[    1.650893] 8021q: 802.1Q VLAN Support v1.8
[    1.656132] NET: Registered protocol family 27
[    1.666832] qcom,cc-debug-mdm9607 1800000.qcom,debug: Registered Debug Mux successfully
[    1.671652] cpr_efuse_init: apc_corner: efuse_addr = 0x000a4000 (len=0x1000)
[    1.673764] cpr_read_fuse_revision: apc_corner: fuse revision = 2
[    1.680943] cpr_parse_speed_bin_fuse: apc_corner: [row: 37]: 0x88002032616513dd, speed_bits = 4
[    1.687041] cpr_pvs_init: apc_corner: pvs voltage: [1050000 1100000 1262500] uV
[    1.695473] cpr_pvs_init: apc_corner: ceiling voltage: [1050000 1225000 1350000] uV
[    1.702728] cpr_pvs_init: apc_corner: floor voltage: [1050000 1050000 1150000] uV
[    1.710564] cpr_init_cpr_parameters: apc_corner: up threshold = 2, down threshold = 3
[    1.718062] cpr_init_cpr_parameters: apc_corner: CPR is enabled by default.
[    1.725870] cpr_init_cpr_efuse: apc_corner: [row:65] = 0x15200259259361
[    1.732597] cpr_init_cpr_efuse: apc_corner: CPR disable fuse = 0
[    1.739224] cpr_init_cpr_efuse: apc_corner: Corner[1]: ro_sel = 0, target quot = 601
[    1.745471] cpr_init_cpr_efuse: apc_corner: Corner[2]: ro_sel = 0, target quot = 601
[    1.753161] cpr_init_cpr_efuse: apc_corner: Corner[3]: ro_sel = 0, target quot = 865
[    1.761882] cpr_config: apc_corner: Timer count: 0x17700 (for 5000 us)
[    1.769032] apc_corner: Bringing 0uV into 1-1uV
[    1.776860] clock-a7 b010008.qcom,clock-a7: Speed bin: 4 PVS Version: 0
[    1.779518] a7ssmux: set OPP pair(400000000 Hz: 1 uV) on cpu0
[    1.786418] a7ssmux: set OPP pair(1305600000 Hz: 7 uV) on cpu0
[    1.793565] thermal thermal_zone5: binding zone cpuss-step with cdev thermal-cpufreq-0 failed:-22
[    1.797609] thermal thermal_zone7: binding zone nav-lowf with cdev thermal-cpufreq-0 failed:-22
[    1.806604] thermal thermal_zone8: binding zone wddac-lowf with cdev thermal-cpufreq-0 failed:-22
[    1.815104] thermal thermal_zone9: binding zone modem-dsp-lowf with cdev thermal-cpufreq-0 failed:-22
[    1.824118] thermal thermal_zone10: binding zone ipss-lowf with cdev thermal-cpufreq-0 failed:-22
[    1.833311] thermal thermal_zone11: binding zone cpuss-lowf with cdev thermal-cpufreq-0 failed:-22
[    1.842834] ubi0: attaching mtd16
[    2.113300] ubi0: scanning is finished
[    2.120290] ubi0: attached mtd16 (name "rootfs_a", size 119 MiB)
[    2.120317] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[    2.125427] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[    2.132039] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[    2.138937] ubi0: good PEBs: 954, bad PEBs: 0, corrupted PEBs: 0
[    2.145701] ubi0: user volume: 2, internal volumes: 1, max. volumes count: 128
[    2.151919] ubi0: max/mean erase counter: 8/5, WL threshold: 4096, image sequence number: 35935352
[    2.158985] ubi0: available PEBs: 0, total reserved PEBs: 954, PEBs reserved for bad PEB handling: 80
[    2.167988] ubi0: background thread "ubi_bgt0d" started, PID 970
[    2.177348] ubi1: attaching mtd14
[    2.314036] ubi1: scanning is finished
[    2.320548] ubi1: attached mtd14 (name "modem", size 60 MiB)
[    2.320575] ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[    2.325335] ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[    2.331953] ubi1: VID header offset: 2048 (aligned 2048), data offset: 4096
[    2.338846] ubi1: good PEBs: 480, bad PEBs: 0, corrupted PEBs: 0
[    2.345611] ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
[    2.351831] ubi1: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 1973314473
[    2.358896] ubi1: available PEBs: 0, total reserved PEBs: 480, PEBs reserved for bad PEB handling: 80
[    2.368233] ubi1: background thread "ubi_bgt1d" started, PID 973
[    2.377390] ubi2: attaching mtd18
[    2.715316] ubi2: scanning is finished
[    2.722324] ubi2: attached mtd18 (name "storage", size 150 MiB)
[    2.722350] ubi2: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[    2.727112] ubi2: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[    2.734022] ubi2: VID header offset: 2048 (aligned 2048), data offset: 4096
[    2.740847] ubi2: good PEBs: 1206, bad PEBs: 0, corrupted PEBs: 0
[    2.747650] ubi2: user volume: 1, internal volumes: 1, max. volumes count: 128
[    2.753902] ubi2: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 570930209
[    2.760986] ubi2: available PEBs: 0, total reserved PEBs: 1206, PEBs reserved for bad PEB handling: 80
[    2.770038] ubi2: background thread "ubi_bgt2d" started, PID 976
[    5.448176] block ubiblock0_0: created from ubi0:0(ubi_vol_rom)
[    5.448646] block ubiblock1_0: created from ubi1:0(modem)
[   �[    5.460599] Filesystem uses "lzo" compression. This is not supported
[    5.460687] List of all partitions:
[    5.466112] 1f00            1280 mtdblock0
[    5.466117]  (driver?)
[    5.473429] 1f01            1280 mtdblock1
[    5.473434]  (driver?)
[    5.479900] 1f02           22528 mtdblock2
[    5.479905]  (driver?)
[    5.486442] 1f03            5120 mtdblock3
[    5.486447]  (driver?)
[    5.492919] 1f04            3072 mtdblock4
[    5.492924]  (driver?)
[    5.499434] 1f05            1792 mtdblock5
[    5.499439]  (driver?)
[    5.505975] 1f06            3072 mtdblock6
[    5.505980]  (driver?)
[    5.512453] 1f07            1280 mtdblock7
[    5.512458]  (driver?)
[    5.518963] 1f08            1280 mtdblock8
[    5.518968]  (driver?)
[    5.525504] 1f09            1280 mtdblock9
[    5.525509]  (driver?)
[    5.531982] 1f0a            1280 mtdblock10
[    5.531987]  (driver?)
[    5.538840] 1f0b            1280 mtdblock11
[    5.538844]  (driver?)
[    5.545470] 1f0c            9216 mtdblock12
[    5.545474]  (driver?)
[    5.552037] 1f0d            9216 mtdblock13
[    5.552041]  (driver?)
[    5.558635] 1f0e           61440 mtdblock14
[    5.558640]  (driver?)
[    5.565259] 1f0f            1280 mtdblock15
[    5.565263]  (driver?)
[    5.571827] 1f10          122112 mtdblock16
[    5.571832]  (driver?)
[    5.578427] 1f11          122112 mtdblock17
[    5.578432]  (driver?)
[    5.585051] 1f12          154368 mtdblock18
[    5.585056]  (driver?)
[    5.591618] fe00           21728 ubiblock0_0
[    5.591623]  (driver?)
[    5.598217] fe01           49104 ubiblock1_0
[    5.598222]  (driver?)
[    5.604927] No filesystem could mount root, tried:
[    5.604932]  squashfs
[    5.607157]
[    5.614391] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(254,0)
[    5.615937] CPU: 0 PID: 1 Comm: swapper Not tainted 5.4.221 #0
[    5.624349] Hardware name: Qualcomm Technologies, Inc. MDM 9607 (Flattened Device Tree)
[    5.630016] [<c010e498>] (unwind_backtrace) from [<c010c1e0>] (show_stack+0x10/0x14)
[    5.637899] [<c010c1e0>] (show_stack) from [<c011cab4>] (panic+0xf8/0x330)
[    5.645889] [<c011cab4>] (panic) from [<c0a017dc>] (mount_block_root+0x284/0x2a4)
[    5.652565] [<c0a017dc>] (mount_block_root) from [<c0a01a3c>] (prepare_namespace+0x158/0x190)
[    5.660124] [<c0a01a3c>] (prepare_namespace) from [<c0759c9c>] (kernel_init+0x8/0x110)
[    5.668630] [<c0759c9c>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[    5.676433] Exception stack(0xcf42ffb0 to 0xcf42fff8)
[    5.683982] ffa0:                                     00000000 00000000 00000000 00000000
[    5.689109] ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    5.697268] ffe0: 00000000 00000000 00000000 00000000 00000013 00000000
[    5.705434] cpr_panic_callback: apc_corner: [corner:7, fuse_corner:3] = 1237500 uV
[    5.711854] Rebooting in 1 seconds..
it is available a ubi file recently updated ?
Can you provide your device model code? Use this command mnf_info -n.
Marijus
TRB145003000
this one is good?
furthermore this happens during fastboot reboot-bootloader
[10] target_init()
[190] fastboot_init()
[300] USB init ept @ 0x8296e000
[320] udc_start()
[460] -- reset --
[460] -- portchange --
[590] -- reset --
[590] -- portchange --
[740] fastboot: processing commands
[760] fastboot: getvar:product
now…it is stucked like this:
[    4.368517] procd: - init -
Please press Enter to activate this console.
[    4.949287] urngd: v1.0.2 started.
[    5.023775] UBIFS (ubi1:0): Mounting in unauthenticated mode
[    5.153574] UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "modem", R/O mode
[    5.153608] UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[    5.160735] UBIFS (ubi1:0): FS size: 48885760 bytes (46 MiB, 385 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
[    5.170698] UBIFS (ubi1:0): reserved for root: 0 bytes (0 KiB)
[    5.180903] UBIFS (ubi1:0): media format: w4/r0 (latest is w5/r0), UUID FC90F0B8-396E-4415-94EE-FE261DF989CF, small LPT model
[    5.193467] kmodloader: no module folders for kernel version 5.4.221 found
[    5.223590] UBIFS (ubi2:0): Mounting in unauthenticated mode
[    5.238731] UBIFS (ubi2:0): background thread "ubifs_bgt2_0" started, PID 1256
[    5.278490] UBIFS (ubi2:0): recovery needed
[    5.402469] UBIFS (ubi2:0): recovery completed
[    5.402566] UBIFS (ubi2:0): UBIFS: mounted UBI device 2, volume 0, name "storage"
[    5.405877] UBIFS (ubi2:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[    5.413407] UBIFS (ubi2:0): FS size: 141070336 bytes (134 MiB, 1111 LEBs), journal size 7110656 bytes (6 MiB, 56 LEBs)
[    5.423290] UBIFS (ubi2:0): reserved for root: 4952683 bytes (4836 KiB)
[    5.433878] UBIFS (ubi2:0): media format: w4/r0 (latest is w5/r0), UUID 5F284A7D-C9F7-44F7-B1C5-7880D0A31819, small LPT model
[   13.878272] using random self ethernet address
[   13.878304] using random host ethernet address
[   13.897961] rndis0: HOST MAC e2:aa:fb:45:8b:93
[   13.897989] rndis0: MAC fe:68:18:6b:db:ae
[   13.901329] msm_hsusb msm_hsusb: [ci13xxx_start] hw_ep_max = 32
[   13.930521] msm_otg 78d9000.usb: phy_reset: success
[   14.043617] msm_otg 78d9000.usb: USB exited from low power mode
[   14.043690] msm_hsusb msm_hsusb: CI13XXX_CONTROLLER_UDC_STARTED_EVENT received
[   14.611484] kmodloader: no module folders for kernel version 5.4.221 found
[   16.561826] msm_otg 78d9000.usb: USB in low power mode
[   29.923178] smd_pkt_open: wait on smd_pkt_dev id:0 allocation failed rc:-110
[   33.123187] mem_acc_corner: disabling
[   33.123243] emac_lan_vreg: disabling
[   50.403177] smd_pkt_open: wait on smd_pkt_dev id:0 allocation failed rc:-110
[   70.883177] smd_pkt_open: wait on smd_pkt_dev id:0 allocation failed rc:-110
[   91.363179] smd_pkt_open: wait on smd_pkt_dev id:0 allocation failed rc:-110
[  111.843176] smd_pkt_open: wait on smd_pkt_dev id:0 allocation failed rc:-110
[  132.323178] smd_pkt_open: wait on smd_pkt_dev id:0 allocation failed rc:-110
[  152.803176] smd_pkt_open: wait on smd_pkt_dev id:0 allocation failed rc:-110
[  173.283197] smd_pkt_open: wait on smd_pkt_dev id:0 allocation failed rc:-110
[  193.763184] smd_pkt_open: wait on smd_pkt_dev id:0 allocation failed rc:-110
[  214.243181] smd_pkt_open: wait on smd_pkt_dev id:0 allocation failed rc:-110
[  234.723178] smd_pkt_open: wait on smd_pkt_dev id:0 allocation failed rc:-110
For this TRB version, please try using the following commands instead:
fastboot erase boot_a
fastboot erase boot_b
fastboot erase rootfs_a
fastboot erase rootfs_b
fastboot flash boot_a /path/to/kernel.img
fastboot flash boot_b /path/to/kernel.img
fastboot flash rootfs_a /path/to/rootfs.ubi
fastboot flash rootfs_b /path/to/rootfs.ubi
You can download the required files from this link: Download Files
Marijus
Solved!!! thanks Marijus you save my life!
I’m glad to hear that it worked for your device. If you’ll have any additional questions or need further support from Teltonika, feel free to reach out to us.
Marijus
