We use many TRB140s. When we receive a new one, we have a script which operates over SSH and loads them all to a known firmware version and then configures them using uci
commands.
Whilst we may have a slightly older firmware version, we do not operate on the public internet so having all the latest CVE fixes is not a concern. It is more important for all modems to have the same firmware version as once they are deployed upgrading them is not really an option.
This process has been working well for several years until today. The firmware load portion of the script failed as follows:
Connecting to TRB140 at IP 192.168.2.1 with default password
Connected to TRB140
Using latest locally cached firmware TRB1_R_00.07.02.7
> uci show system.system.device_fw_version
system.system.device_fw_version='TRB1_R_00.07.03.4'
Firmware on device is version TRB1_R_00.07.03.4.
Transferring C:\Users\xxx\.cache\TRB1_R_00.07.02.7_WEBUI.bin to TRB140 /tmp/TRB1_R_00.07.02.7_WEBUI.bin
[####################################] 100% done
Running firmware update command on TRB140...
> sysupgrade /tmp/TRB1_R_00.07.02.7_WEBUI.bin
ERROR: Tue Feb 7 12:54:00 UTC 2023 upgrade: TRB1_R_00.07.02.7!
ERROR: Mods found: motorcomm_phy trb143!
ERROR: find: /greengrass/certs/: No such file or directory!
ERROR: find: /etc/hostapd/: No such file or directory!
ERROR: Tue Feb 7 12:54:04 UTC 2023 upgrade: Saving config files...!
ERROR: Tue Feb 7 12:54:04 UTC 2023 upgrade: Commencing upgrade. Closing all shell sessions.!
Normally the firmware is an upgrade, but today it seems it was a downgrade as the new device had a newer version TRB1_R_00.07.03.4 than the version we tried to load TRB1_R_00.07.02.7. The ERRORs are a concern as it seems to allow you to perform this downgrade but then it fails, possibly part way through the process.
Following this the device has been power cycled, reset and also factory reset as per TRB140 Device Recovery Options - Teltonika Networks Wiki but alas can no longer ping the device on 192.168.2.1 and fear that it is bricked.
Questions:
- Should a downgrade such as this be expected to work or should it be avoided?
- Is there a way to un-brick this device?
Kim
