Telefon an RUTX50 anschließen
Hallo zusammen,
We want to an connected an our RUTX50.
Have currently from Gigaset Comfort 520A IP Base, but get no function after setting the connection.
Hat jemand etwas ähnliches probiert?
Niemand versteht was du hier machen möchtest.
Kannst du deine Anfrage bitte sauber auf Englisch schreiben und dir wird geholfen.
Benutze Google Translator wenn nötig.
Aber so wird das nix :wink:
We would like to connect a telephone to our RUTX50.
Does anyone have experience with this?
It is not possible to connect an analogue (“regular”) phone.
Only VoIP phones will work - as described here:
RUT-200 does it work with a VOIP phone
Has anyone ever connected a telephone and can tell me the components that have been used?
It doesn’t work with my Comfort IP520A from Gigaset.
Hi @MaXi,
ok, after google’ing Comfort 520A I found out that this is an
VoIP capable DECT base.
That means you have to:
  • register your handset to the DECT base
  • connect the DECT base to your router via a LAN cable
  • usually that requires no settings on the router
  • but you have to enter your VoIP account data into the DECT base somehow
  • either 1. via the DECT handset (which may be possible)
  • or 2. via the web interface of the DECT base
In case of 2. you have to find out which IP address has been assigned to the DECT base
by looking at the DHCP leases on your router, and then configure it.
If, however, you want to make outgoing calls via the mobile phone number assigned to your
SIM card this in NOT going to work with your setup (see also the link provided by @TeWe).
In this case you need something like e.g. a Siemens TC35.
Timelapse Admin
And, yes, I have a (admittedly very old) Gigaset C450 IP DECT system running behind a router.
