Tcpdump pkg ver. 4.99.4-1 still not working correctly!
Hi crowd,
On OCT 2024 I posted that the tcpdump package (ver. 4.99.4-1) was still not working as expected. When you enter a host and port together with the protocol the corresponding script will generate a syntactically incorrect tcpdump command and this will therefore not be executed.
I am running my RUT360 with FW RUT36X_R_00.07.12 and I still don’t see any change in the tcpdump package.
Who else is experiencing the same issue I reported?
Same issue still no fix to this.
Hope it resolves soon!
Thank you for reaching out.
Could you please clarify if you’re executing the tcpdump packet capture and then downloading the TCP dump file via the WebUI (System → Maintenance → Troubleshoot), or if you’re simply running the command via SSH?
If you’re using the WebUI, make sure to press “Save & Apply” after enabling TCPdump and inserting the host and port parameters.
Additionally, it would be helpful if you could provide more details or a screenshot (if possible) that demonstrates the issue you’re encountering, especially when the described behavior occurs.
Hi Martynas,
Please read my previous posts:
I explain there what the issue is and propose a solution.
Don’t hesitate to get back to me for more details if needed.
Hi guys!
On my RUT955, both running RUT9_R_00.07.06.17, both installed tcpdump with same commands:
opkg -e /etc/opkg/openwrt/distfeeds.conf install tcpdump
RUT955 A:
root@crsdre:~# tcpdump --version
tcpdump version 4.99.4
libpcap version 1.9.1 (with TPACKET_V3)
RUT955 B:
root@GRDI:~# tcpdump --version
tcpdump version 4.9.3
While tcpdump on router A is correctly working:
root@crsdre:~# tcpdump -i tun_c_dre port 502 -vvv -n -t
tcpdump: listening on tun_c_dre, link-type RAW (Raw IP), snapshot length 262144 bytes
IP (tos 0x0, ttl 64, id 11096, offset 0, flags [DF], proto TCP (6), length 52)
10.55.44.19.502 > 10.55.44.1.42346: Flags [.], cksum 0x4fe0 (correct), seq 1224827159, ack 417244451, win 4073, options [nop,nop,TS val 3013385588 ecr 288438453], length 0
IP (tos 0x0, ttl 62, id 4234, offset 0, flags [DF], proto TCP (6), length 52)
10.55.44.1.42346 > 10.55.44.19.502: Flags [.], cksum 0x8165 (correct), seq 1, ack 1, win 502, options [nop,nop,TS val 288440486 ecr 3013374448], length 0
IP (tos 0x0, ttl 64, id 11097, offset 0, flags [DF], proto TCP (6), length 52)
10.55.44.19.502 > 10.55.44.1.42346: Flags [.], cksum 0x400f (correct), seq 0, ack 1, win 4073, options [nop,nop,TS val 3013387604 ecr 288440486], length 0
IP (tos 0x0, ttl 62, id 4235, offset 0, flags [DF], proto TCP (6), length 52)
Here output on router B:
root@GRDI:~# tcpdump -i tun_c_openvpn
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on tun_c_openvpn, link-type RAW (Raw IP), capture size 262144 bytes
00:00:00.1741182132 [|ip]
00:00:00.1741182133 [|ip]
How can I fix?
Thanks.
