Thank you for the detailed reply.
I used FT over DS deliberately because I don’t use mesh and wanted my network to be more reliable. However, I wasn’t aware of this limitation about the same L2 segment. Could you please make this requirement a bit more obvious on the web interface?
My network topology is: two of the TAP400s are connected to a central switch, the two others are connected to one-one other switches (that are connected to this central switch). And this central switch is managed by a router. Therefore, the TAPs are on the same L2 segment (if I understood the definition correctly).
I use multiple VLANs on the switches, but all of them are set by TAPs (by assigning the appropriate VLAN IDs on the selected networks). The switches enable the TAP ports to participate in all of these VLANs. The one example SSID shown above uses the default VLAN (1), and for this SSID the VLAN ID is left on “Default” on all TAPs.
I have multiple WiFi SSIDs configured on them, but the one I shown in the original message uses 5 GHz only, with WPA3-SAE (on all TAPs). The channels were selected manually, individually for all TAPs.
I ran the command but grep didn’t return anything, so I ran it without, and I didn’t see any disconnection (apart from a timeout).
This got logged after I connected with my mobile phone:
684 Fri Jun 12 22:29:45 2026 daemon.notice hostapd: wlan1-1: AP-STA-CONNECTED wi:fi:mac:add:ress auth_alg=sae
685 Fri Jun 12 22:29:45 2026 connections.notice WiFiSSIDName: WiFi client connected: wi:fi:mac:add:ress
686 Fri Jun 12 22:29:45 2026 daemon.info hostapd: wlan1-1: STA wi:fi:mac:add:ress IEEE 802.1X: authorizing port
687 Fri Jun 12 22:29:45 2026 daemon.info hostapd: wlan1-1: STA wi:fi:mac:add:ress RADIUS: starting accounting session FCA7256xxxxxxx
688 Fri Jun 12 22:29:45 2026 daemon.info hostapd: wlan1-1: STA wi:fi:mac:add:ress WPA: pairwise key handshake completed (RSN)
689 Fri Jun 12 22:29:45 2026 daemon.notice hostapd: wlan1-1: EAPOL-4WAY-HS-COMPLETED wi:fi:mac:add:ress
Then, in the next minute I moved to another AP but there was no sign of acknowledging this. The next logs show that it simply couldn’t connect to the mobile phone after a few minutes of timeout. During this five minutes I was on the neighbouring AP.
Is it expected to have a small gap in the message numbering? It remains when I rerun this command.
704 Fri Jun 12 22:36:19 2026 daemon.notice hostapd: wlan1-1: AP-STA-DISCONNECTED wi:fi:mac:add:ress
705 Fri Jun 12 22:36:19 2026 connections.notice WiFiSSIDName: WiFi client disconnected: wi:fi:mac:add:ress
706 Fri Jun 12 22:36:19 2026 daemon.info hostapd: wlan1-1: STA wi:fi:mac:add:ress IEEE 802.11: disassociated due to inactivity
707 Fri Jun 12 22:36:20 2026 daemon.info hostapd: wlan1-1: STA wi:fi:mac:add:ress IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
802.1X client is disabled on all TAPs, I don’t have a Radius server.
Afterwards, I changed the roaming info sharing to FT over the Air on all devices, but unfortunately, I still see the same behaviour:
3767 Sat Jun 13 21:59:25 2026 connections.notice WiFiSSIDName: WiFi client connected: wi:fi:mac:add:ress
3768 Sat Jun 13 21:59:25 2026 daemon.info hostapd: wlan1-1: STA wi:fi:mac:add:ress IEEE 802.1X: authorizing port
3769 Sat Jun 13 21:59:25 2026 daemon.info hostapd: wlan1-1: STA wi:fi:mac:add:ress RADIUS: starting accounting session 54B7F28xxxxxx
3770 Sat Jun 13 21:59:25 2026 daemon.info hostapd: wlan1-1: STA wi:fi:mac:add:ress WPA: pairwise key handshake completed (RSN)
3771 Sat Jun 13 21:59:25 2026 daemon.notice hostapd: wlan1-1: EAPOL-4WAY-HS-COMPLETED wi:fi:mac:add:ress
This time my phone stayed on the wrong network with a -20 vs. -87 dBm difference for a few minutes.
