Unfortunately, your email with the attachment didn’t arrive. I checked the logs, and it seems that your sender disconnects:
connect from bd77fb3.bf.eu1.r.hubspot-inbox.com[143.244.84.209]
NOQUEUE: lost connection after EHLO from bd77fb3.bf.eu1.r.hubspot-inbox.com[143.244.84.209]
disconnect from bd77fb3.bf.eu1.r.hubspot-inbox.com[143.244.84.209] ehlo=2 starttls=1 commands=3
I see it retrying, but with the same outcome. So far I could receive e-mails with attachments, therefore I’m not sure what is the problem. I enabled debug logging for hubspot-inbox, and if I could ask you to resend that email with the attachment, I could now see what is happening exactly.
Nonetheless, you should have received a 5xx rejection letter from your own mailer daemon that it could not deliver the email.
To speed things up a bit to be able to test the new firmware in the meantime, I shared a storage space link with you.
Thank you for the firmware. I updated all of my TAP devices and have been testing them in the past days.
In general, the client transfer works:
When the signal strength goes below a certain level, the current AP forcibly disconnects.
There’re ~two seconds while the client is not connected to an AP; I don’t know if that’s intended or the roaming should work seamlessly. Currently, there’s a gap.
Then the new AP is connected to.
One feature request: it would be great if the AP would disconnect only if the client has already negotiated with a new AP. This would ensure that at the edge of the covered zone, the client kept working, even slowly.
However, there’s a significant connection issue with one of my APs (but I’m not sure if it’s related to this modification or it’s a general problem). One of my APs is really slow to accept new clients. I tested it with three different Android devices, and each exhibited the same problems:
The devices don’t connect automatically.
Even when they do, for ten seconds, Android tells that there’s no internet on that Wi-Fi.
The SSID is slow to appear in the Android’s available Wi-Fi list; it’s simply not there. Other SSIDs from the AP are there with maximum signal strength. This behaviour is also visible on multiple Android devices.
While trying to connect manually, Android tells the connection was unsuccessful on multiple manual tries before it finally succeeds.
Roughly, it takes 2-5 minutes to be able to connect.
I sent the logs along with a bit more information in our e-mail thread.
You could try running these commands on the APs to reduce how aggressive the AP steering mechanism is:
uci set usteer.@usteer[0].min_snr='-80' uci set usteer.@usteer[0].min_snr_kick_delay='10000' uci set usteer.@usteer[0].roam_scan_snr='0' uci set usteer.@usteer[0].roam_trigger_snr='0' uci commit usteer /etc/init.d/usteer restart
Devices that attempt to connect to access points when the signal is worse than the min_snr value get the “Access point is temporarily full” errors, so this would lower the minimum signal threshold to -80dBm which should let clients with worse signal to stay on the AP. This will also turn off AP-initiated roaming, since if the client does not move to another AP, the original AP disconnects them.
