I’m trying to set up a Teltonika remote router using a TAP VPN HUB. My goal is to use it as a remote access to an Industrial Network for a programists. For that I need it to be in a Layer 2 soo broadcast need to work. I’ve managed to configure it using new beta TAP VPN HUB by creating a bridge between tap_ network and LAN network, however it only works if I change address into that local network subnet. I cannot change IP address DHCP in TAP Mode and also it in about 5 minutes changes my local network adapter into address from DHCP.
I want to clarify if I’m approaching it the right way or there is a better way to achive same goal.
We have encountered a similar case on our Community Forum, where one of our colleagues provided troubleshooting steps that may help resolve the issue.
Please refer to the response in the following topic and let us know whether it helps:
If the issue persists, could you please provide the following information:
Could you also clarify the exact issue you are currently experiencing? For example, are you unable to reach devices on the remote network, or are you encountering another problem?
What is the IP subnet of the remote LAN?
What IP address does your PC receive when connected to the TAP VPN Hub?
Is your PC obtaining its IP address from the remote DHCP server, or from another DHCP server on your local network?
This information will help us better understand your setup and continue troubleshooting.
We appreciate your patience and look forward to your response.
