In the file /etc/opkg/distfeeds.conf
are all repositories defined that will used by the OPKG package manager of openwrt / RutOS. In this file the last line points to a location that does not exsists. The line is:
src/gz openwrt_vuci https://downloads.openwrt.org/releases/21.02.0/packages/arm_cortex-a7_neon-vfpv4/vuci
This line will always produce an error when you do an opkg update
. Is this already an known issue?
Should there be another line or should I just comment this line out to don’t get the issue anymore?
