RUTX50 registered packages repositories for OPKG are wrong Part 2
After I was reporting the issue here before and support was saying it will be fixed with the next version I need to reopen this here again. It’s still broken at the same repository.
So can please someone just fix it with the correct URLs that will work?
Still the workaround to use the package manager is to remove the following line from /etc/opkg/distfeeds.conf
src/gz openwrt_vuci https://downloads.openwrt.org/releases/21.02.0/packages/arm_cortex-a7_neon-vfpv4/vuci
OS Metadata:
  • Kernel: 5.10.188
  • RutOs Version: RUTX_R_00.07.05
hopefully will fix it now…
