RUTX50 Mobile data disconnected (internal modem)
I just updated the firmware on my RUTX50 and I regret it!!! I had a working router, but now it disconnects all the time from mobile network.
I user my router for streaming sports to different platforms in my photography business. So the connection is critical.
After the firmware update to RUTX_R_00.07.04.5 I get “Mobile data disconnected (internal modem)” as soon as I load the router for a bit :frowning:
This makes the router pretty much useless and unreliable!!! I have a paid job the coming weekend that will fail due to this!!
HELP!
Here is a cut from the router log:
ID Date Event Type Event
543 2023-08-07 20:48:38 Network Operator Connected to operator (internal modem)
542 2023-08-07 20:48:38 Network Type Joined network (internal modem)
541 2023-08-07 20:48:38 Mobile Data Mobile data connected (internal modem)
540 2023-08-07 20:48:35 Network Operator Connected to operator (internal modem)
539 2023-08-07 20:48:35 Network Type Joined network (internal modem)
538 2023-08-07 20:48:35 Mobile Data Mobile data connected (internal modem)
537 2023-08-07 20:46:24 Mobile Data Mobile data disconnected (internal modem)
536 2023-08-07 20:43:46 Network Operator Connected to operator (internal modem)
535 2023-08-07 20:43:46 Network Type Joined network (internal modem)
534 2023-08-07 20:43:46 Mobile Data Mobile data connected (internal modem)
Firmware version RUTX_R_00.07.04.5
Firmware build date 2023-07-24 14:42:15
Internal modem firmware version RG501QEUAAR12A08M4G_04.200.04.200
Kernel version 5.4.229
Since this matter seem quite urgent, I would recommend downgrading to the previous known-working firmware version, as when you have some time, let me know and we can troubleshoot the issue further.
Has anything else changed other than the firmware version? Is the router being used in the same location?
You could also try setting the router to 4G-only for now to check if that has any effect on the connection.
I will try earlier firmware.
Other changes is that part of when I experienced the issue I also updated the modem firmware.
I’m happy to supply diagnostic files or other log files to troubleshoot the error if you can provide me with the instruction of what diag/logs you would need.
Thanks!
System logs would be needed to diagnose the issue further. They can be gathered by navigating to System → Administration → Troubleshoot and pressing the System Log option. After replicating the issue, copy the text and paste it here.
ATTENTION: These logs can contain sensitive information as APN authentication, public IP address, MAC addresses, etc. Please review the logs and censor this information before posting it. Thank you!
I changed Firmware to mass update version RUTX_R_00.07.04.3
Loaded modem with some upload traffc and the modem did a reset after a few seconds.
Im not allowed to attach logfile as Im a new portal user.
How should I proceed to send the logfile to you?
Please let me know if I should send a debug file also.
No need to attach the file, the contents can be pasted directly in the comment field. Make sure to take the logs after replicating the issue.
There is a limit to how much text I can enter as a new portal user also. But will then add it in several posts
Page 1
Tue Aug 8 16:20:37 2023 daemon.notice netifd: mob1s1a1_4 (6745): udhcpc: broadcasting renew
Tue Aug 8 16:20:37 2023 daemon.notice netifd: mob1s1a1_4 (6745): udhcpc: lease of xx.xx.xx.116 obtained from xx.xx.xx.117, lease time 7200
Tue Aug 8 16:27:17 2023 kern.notice Authentication was successful from HTTP 192.168.2.123
Tue Aug 8 16:27:17 2023 daemon.err uhttpd[2592]: vuci: accepted login for admin from 192.168.2.123
Tue Aug 8 16:31:15 2023 daemon.info mobifd: [gsm.modem0] Config reload initiated
Tue Aug 8 16:31:15 2023 daemon.notice netifd: mob1s1a1 (31288): Stopping network mob1s1a1
Tue Aug 8 16:31:15 2023 daemon.notice netifd: Network device ‘qmimux0’ link is down
Tue Aug 8 16:31:15 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ has link connectivity loss
Tue Aug 8 16:31:15 2023 daemon.notice netifd: mob1s1a1_4 (6745): udhcpc: SIOCGIFINDEX: No such device
Tue Aug 8 16:31:15 2023 daemon.notice netifd: mob1s1a1_4 (6745): udhcpc: received SIGTERM
Tue Aug 8 16:31:15 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is now down
Tue Aug 8 16:31:15 2023 user.warn mwan3-hotplug[31287]: hotplug called on mob1s1a1 before mwan3 has been set up
Tue Aug 8 16:31:15 2023 user.notice netifd: uqmi -s -d /dev/cdc-wdm0 -t 3000 --set-client-id wds,14 --stop-network 0xFFFFFFFF --autoconnect
Tue Aug 8 16:31:15 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is disabled
Tue Aug 8 16:31:15 2023 daemon.warn dnsmasq[5040]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Tue Aug 8 16:31:15 2023 daemon.notice netifd: mob1s1a1 (31288): Stopping network on /dev/cdc-wdm0!
Tue Aug 8 16:31:15 2023 daemon.notice netifd: mob1s1a1 (31288): “No effect”
Tue Aug 8 16:31:16 2023 daemon.notice netifd: mob1s1a1 (31288): Releasing client-id 14 on /dev/cdc-wdm0
Tue Aug 8 16:31:16 2023 user.notice netifd: uqmi -s -d /dev/cdc-wdm0 -t 3000 --set-client-id wds,14 --release-client-id wds
Tue Aug 8 16:31:16 2023 daemon.notice netifd: mob1s1a1 (31288): Command failed: Not found
Tue Aug 8 16:31:16 2023 daemon.notice netifd: mob1s1a1 (31288): Command failed: Permission denied
Tue Aug 8 16:31:16 2023 daemon.notice netifd: Interface ‘mob1s1a1’ is now down
Tue Aug 8 16:31:17 2023 daemon.info dnsmasq[5040]: read /etc/hosts - 4 addresses
Tue Aug 8 16:31:17 2023 daemon.info dnsmasq[5040]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Tue Aug 8 16:31:17 2023 daemon.info dnsmasq-dhcp[5040]: read /etc/ethers - 0 addresses
Tue Aug 8 16:31:17 2023 kern.info Mobile data disconnected (internal modem)
Tue Aug 8 16:31:20 2023 daemon.info mobifd: [gsm.modem0] Initializing modem. Please wait.
Page 2
Tue Aug 8 16:31:34 2023 daemon.info mobifd: [gsm.modem0] SMS storage: sm
Tue Aug 8 16:31:34 2023 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with 5 seconds of timeout
Tue Aug 8 16:31:34 2023 daemon.info mobifd: [gsm.modem0] Connected to operator ‘Tele2 Tele2’
Tue Aug 8 16:31:35 2023 daemon.info mobifd: [gsm.modem0] -CFUN- Functionality: “Full”
Tue Aug 8 16:31:35 2023 daemon.info mobifd: [gsm.modem0] -COPS- Mode: “Auto”, operator: “Tele2 Tele2”
Tue Aug 8 16:31:35 2023 daemon.info mobifd: [gsm.modem0] -CREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “34056”, cell ID: “80608269”, technology: “E-UTRAN”
Tue Aug 8 16:31:35 2023 daemon.info mobifd: [gsm.modem0] -CGREG- Mode: “Enabled (with location information)”, status: “Not registered”, LAC: “”, cell ID: “”, technology: “Unknown”
Tue Aug 8 16:31:35 2023 daemon.info mobifd: [gsm.modem0] -CEREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “34056”, cell ID: “80608269”, technology: “E-UTRAN”
Tue Aug 8 16:31:35 2023 daemon.info mobifd: [gsm.modem0] IP address on PDP context “1”: “xx.xx.xx.116”
Tue Aug 8 16:31:35 2023 daemon.notice netifd: Interface ‘mob1s1a1’ is setting up now
Tue Aug 8 16:31:35 2023 daemon.notice netifd: mob1s1a1 (32118): wwan[32118] Using wwan usb device on bus 2-1
Tue Aug 8 16:31:35 2023 daemon.notice netifd: mob1s1a1 (32118): wwan[32118] Using proto:qmapv5 device:/dev/cdc-wdm0 iface:wwan0 desc:Quectel RG50X
Tue Aug 8 16:31:35 2023 daemon.notice netifd: mob1s1a1 (32118): Failed to parse message data
Tue Aug 8 16:31:35 2023 daemon.notice netifd: mob1s1a1 (32118): Command failed: Not found
Tue Aug 8 16:31:35 2023 daemon.notice netifd: mob1s1a1 (32118): WARNING: Variable ‘list’ does not exist or is not an array/object
Tue Aug 8 16:31:35 2023 daemon.notice netifd: mob1s1a1 (32118): Creating context with PDP: 1
Tue Aug 8 16:31:37 2023 daemon.notice netifd: mob1s1a1 (32118): Quering active sim position
Tue Aug 8 16:31:37 2023 daemon.notice netifd: mob1s1a1 (32118): Calculated qmimux ifname: qmimux0
Tue Aug 8 16:31:37 2023 user.notice root: uqmi -d /dev/cdc-wdm0 --timeout 3000 --wda-set-data-format --qos-format 0 --link-layer-protocol raw-ip --endpoint-type hsusb --endpoint-iface-number 4 --ul-protocol qmapv5 --dl-protocol qmapv5 --ul-max-datagrams 11 --ul-datagram-max-size 8192 --dl-max-datagrams 62 --dl-datagram-max-size 31744 --dl-min-padding 0
Tue Aug 8 16:31:37 2023 daemon.notice netifd: mob1s1a1 (32118): Starting network mob1s1a1 using APN: 4g.tele2.se
Tue Aug 8 16:31:38 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,14 --release-client-id wds --modify-profile --profile-identifier 3gpp,1 --profile-name profile1 --roaming-disallowed-flag no --auth-type none --apn 4g.tele2.se --pdp-type ip
Page 3
Tue Aug 8 16:31:38 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --get-client-id wds
Tue Aug 8 16:31:38 2023 daemon.notice netifd: mob1s1a1 (32118): 14
Tue Aug 8 16:31:38 2023 daemon.notice netifd: mob1s1a1 (32118): cid4: 14
Tue Aug 8 16:31:38 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --wds-bind-mux-data-port --mux-id 1 --ep-iface-number 4 --set-client-id wds,14
Tue Aug 8 16:31:38 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-ip-family ipv4 --set-client-id wds,14
Tue Aug 8 16:31:38 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,14 --start-network --apn 4g.tele2.se --profile 1 --auth-type none --username --password
Tue Aug 8 16:31:38 2023 daemon.notice netifd: mob1s1a1 (32118): pdh4: 1580058256
Tue Aug 8 16:31:38 2023 daemon.notice netifd: mob1s1a1 (32118): 1580058256
Tue Aug 8 16:31:38 2023 daemon.notice netifd: mob1s1a1 (32118): Setting up qmimux0
Tue Aug 8 16:31:38 2023 daemon.notice netifd: mob1s1a1 (32118): Setting MTU: 1500 on qmimux0
Tue Aug 8 16:31:38 2023 daemon.notice netifd: Interface ‘mob1s1a1’ is now up
Tue Aug 8 16:31:38 2023 daemon.notice netifd: Network device ‘wwan0’ link is up
Tue Aug 8 16:31:38 2023 daemon.notice netifd: mob1s1a1 (32118): Setting up qmimux0 V4 DCHP
Tue Aug 8 16:31:38 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is enabled
Tue Aug 8 16:31:38 2023 daemon.notice netifd: Network device ‘qmimux0’ link is up
Tue Aug 8 16:31:38 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ has link connectivity
Tue Aug 8 16:31:38 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is setting up now
Tue Aug 8 16:31:38 2023 daemon.notice netifd: mob1s1a1_4 (32488): udhcpc: started, v1.34.1
Tue Aug 8 16:31:38 2023 daemon.notice netifd: mob1s1a1_4 (32488): udhcpc: broadcasting discover
Tue Aug 8 16:31:39 2023 daemon.notice netifd: mob1s1a1_4 (32488): udhcpc: broadcasting select for xx.xx.xx.116, server xx.xx.xx.117
Tue Aug 8 16:31:39 2023 daemon.notice netifd: mob1s1a1_4 (32488): udhcpc: lease of xx.xx.xx.116 obtained from xx.xx.xx.117, lease time 7200
Tue Aug 8 16:31:39 2023 user.warn mwan3-hotplug[32438]: hotplug called on mob1s1a1 before mwan3 has been set up
Tue Aug 8 16:31:39 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is now up
Tue Aug 8 16:31:39 2023 daemon.info dnsmasq[5040]: reading /tmp/resolv.conf.d/resolv.conf.auto
Tue Aug 8 16:31:39 2023 daemon.info dnsmasq[5040]: using only locally-known addresses for domain test
Tue Aug 8 16:31:39 2023 daemon.info dnsmasq[5040]: using only locally-known addresses for domain onion
Tue Aug 8 16:31:39 2023 daemon.info dnsmasq[5040]: using only locally-known addresses for domain localhost
Page 4
Tue Aug 8 16:31:39 2023 daemon.info dnsmasq[5040]: using only locally-known addresses for domain invalid
Tue Aug 8 16:31:39 2023 daemon.info dnsmasq[5040]: using only locally-known addresses for domain bind
Tue Aug 8 16:31:39 2023 daemon.info dnsmasq[5040]: using only locally-known addresses for domain lan
Tue Aug 8 16:31:39 2023 daemon.info dnsmasq[5040]: using nameserver 130.244.127.161#53
Tue Aug 8 16:31:39 2023 daemon.info dnsmasq[5040]: using nameserver 130.244.127.169#53
Tue Aug 8 16:31:39 2023 user.notice firewall: Reloading firewall due to ifup of mob1s1a1 (wwan0)
Tue Aug 8 16:31:39 2023 daemon.err mobifd: Failed to send PING IPV4
Tue Aug 8 16:31:41 2023 daemon.info dnsmasq[5040]: read /etc/hosts - 4 addresses
Tue Aug 8 16:31:41 2023 daemon.info dnsmasq[5040]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Tue Aug 8 16:31:41 2023 daemon.info dnsmasq-dhcp[5040]: read /etc/ethers - 0 addresses
Tue Aug 8 16:31:41 2023 kern.info Mobile data connected (internal modem)
Tue Aug 8 16:31:41 2023 kern.info Joined network (internal modem)
Tue Aug 8 16:31:41 2023 kern.info Connected to operator (internal modem)
Tue Aug 8 16:31:42 2023 user.warn mwan3-hotplug[678]: hotplug called on mob1s1a1_4 before mwan3 has been set up
Tue Aug 8 16:31:42 2023 user.notice firewall: Reloading firewall due to ifup of mob1s1a1_4 (qmimux0)
Tue Aug 8 16:31:44 2023 daemon.info dnsmasq[5040]: read /etc/hosts - 4 addresses
Tue Aug 8 16:31:44 2023 daemon.info dnsmasq[5040]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Tue Aug 8 16:31:44 2023 daemon.info dnsmasq-dhcp[5040]: read /etc/ethers - 0 addresses
Tue Aug 8 16:31:44 2023 kern.info Mobile data connected (internal modem)
Tue Aug 8 16:31:44 2023 kern.info Joined network (internal modem)
Tue Aug 8 16:31:44 2023 kern.info Connected to operator (internal modem)
Done with the log file…
It seems like configuration was changed, and that caused the mobile connection to restart. Could you clarify what steps were taken here before gathering the logs? If you caused the disconnection manually, please wait for the actual issue to replicate, and post the logs then, as at the moment all that is visible, is that the mobile connection was restarted manually.
I have now had some more time to capture the systemlog after reproducing the error.
Of my tests it does not have any effect on if I have the network type set to “Auto” or “4G (LTE) only”. The problem with disconnected Mobile data disconnected (internal modem) still appears in both scenarios.
Here is explanation of the log for more easy understanding
• 2023-08-14 22:33:13 Simcard configuration change to 4G (LTE) only
• Generating network traffic
• 2023-08-14 22:40:28 Mobile data disconnected (internal modem)
• About 2 min outage
• 2023-08-14 22:42:41 Mobile data connected (internal modem)
Log part 1
Mon Aug 14 22:33:13 2023 kern.info kernel: simcard configuration has been changed
Mon Aug 14 22:33:15 2023 daemon.info mobifd: Service reload initiated
Mon Aug 14 22:33:15 2023 daemon.info mobifd: [gsm.modem0] Config reload initiated
Mon Aug 14 22:33:15 2023 daemon.notice netifd: mob1s1a1 (29388): Stopping network mob1s1a1
Mon Aug 14 22:33:15 2023 daemon.notice netifd: Network device ‘qmimux0’ link is down
Mon Aug 14 22:33:15 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ has link connectivity loss
Mon Aug 14 22:33:15 2023 daemon.notice netifd: mob1s1a1_4 (24197): udhcpc: SIOCGIFINDEX: No such device
Mon Aug 14 22:33:15 2023 daemon.notice netifd: mob1s1a1_4 (24197): udhcpc: received SIGTERM
Mon Aug 14 22:33:15 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is now down
Mon Aug 14 22:33:15 2023 user.warn mwan3-hotplug[29387]: hotplug called on mob1s1a1 before mwan3 has been set up
Mon Aug 14 22:33:15 2023 user.notice netifd: uqmi -s -d /dev/cdc-wdm0 -t 3000 --set-client-id wds,14 --stop-network 0xFFFFFFFF --autoconnect
Mon Aug 14 22:33:15 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is disabled
Mon Aug 14 22:33:15 2023 daemon.warn dnsmasq[3449]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Mon Aug 14 22:33:15 2023 daemon.notice netifd: mob1s1a1 (29388): Stopping network on /dev/cdc-wdm0!
Mon Aug 14 22:33:15 2023 daemon.notice netifd: mob1s1a1 (29388): Releasing client-id 14 on /dev/cdc-wdm0
Mon Aug 14 22:33:15 2023 user.notice netifd: uqmi -s -d /dev/cdc-wdm0 -t 3000 --set-client-id wds,14 --release-client-id wds
Mon Aug 14 22:33:15 2023 daemon.notice netifd: mob1s1a1 (29388): Command failed: Not found
Mon Aug 14 22:33:16 2023 daemon.notice netifd: mob1s1a1 (29388): Command failed: Permission denied
Mon Aug 14 22:33:16 2023 daemon.notice netifd: Interface ‘mob1s1a1’ is now down
Mon Aug 14 22:33:16 2023 daemon.info dnsmasq[3449]: read /etc/hosts - 4 addresses
Mon Aug 14 22:33:16 2023 daemon.info dnsmasq[3449]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Mon Aug 14 22:33:16 2023 daemon.info dnsmasq-dhcp[3449]: read /etc/ethers - 0 addresses
Mon Aug 14 22:33:17 2023 daemon.info mobifd: [gsm.modem0] SMS storage: sm
Mon Aug 14 22:33:17 2023 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with 5 seconds of timeout
Mon Aug 14 22:33:17 2023 daemon.info mobifd: [gsm.modem0] Connected to operator ‘Tele2 Tele2’
Mon Aug 14 22:33:17 2023 kern.info Mobile data disconnected (internal modem)
Mon Aug 14 22:33:17 2023 daemon.info mobifd: [gsm.modem0] -CFUN- Functionality: “Full”
Mon Aug 14 22:33:17 2023 daemon.info mobifd: [gsm.modem0] -COPS- Mode: “Auto”, operator: “Tele2 Tele2”
Mon Aug 14 22:33:17 2023 daemon.info mobifd: [gsm.modem0] -CREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “34056”, cell ID: “80572171”, technology: “E-UTRAN”
Mon Aug 14 22:33:17 2023 daemon.info mobifd: [gsm.modem0] -CGREG- Mode: “Enabled (with location information)”, status: “Not registered”, LAC: “”, cell ID: “”, technology: “Unknown”
Mon Aug 14 22:33:17 2023 daemon.info mobifd: [gsm.modem0] -CEREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “34056”, cell ID: “80572171”, technology: “E-UTRAN”
Mon Aug 14 22:33:17 2023 daemon.info mobifd: [gsm.modem0] IP address on PDP context “1”: “37.199.171.16”
Mon Aug 14 22:33:17 2023 daemon.notice netifd: Interface ‘mob1s1a1’ is setting up now
Mon Aug 14 22:33:17 2023 daemon.notice netifd: mob1s1a1 (30113): wwan[30113] Using wwan usb device on bus 2-1
Log part 2
Mon Aug 14 22:33:18 2023 daemon.notice netifd: mob1s1a1 (30113): wwan[30113] Using proto:qmapv5 device:/dev/cdc-wdm0 iface:wwan0 desc:Quectel RG50X
Mon Aug 14 22:33:18 2023 daemon.notice netifd: mob1s1a1 (30113): Failed to parse message data
Mon Aug 14 22:33:18 2023 daemon.notice netifd: mob1s1a1 (30113): Command failed: Not found
Mon Aug 14 22:33:18 2023 daemon.notice netifd: mob1s1a1 (30113): WARNING: Variable ‘list’ does not exist or is not an array/object
Mon Aug 14 22:33:18 2023 daemon.notice netifd: mob1s1a1 (30113): Creating context with PDP: 1
Mon Aug 14 22:33:20 2023 daemon.notice netifd: mob1s1a1 (30113): Quering active sim position
Mon Aug 14 22:33:20 2023 daemon.notice netifd: mob1s1a1 (30113): Calculated qmimux ifname: qmimux0
Mon Aug 14 22:33:20 2023 user.notice root: uqmi -d /dev/cdc-wdm0 --timeout 3000 --wda-set-data-format --qos-format 0 --link-layer-protocol raw-ip --endpoint-type hsusb --endpoint-iface-number 4 --ul-protocol qmapv5 --dl-protocol qmapv5 --ul-max-datagrams 11 --ul-datagram-max-size 8192 --dl-max-datagrams 62 --dl-datagram-max-size 31744 --dl-min-padding 0
Mon Aug 14 22:33:20 2023 daemon.notice netifd: mob1s1a1 (30113): Starting network mob1s1a1 using APN: 4g.tele2.se
Mon Aug 14 22:33:20 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,14 --release-client-id wds --modify-profile --profile-identifier 3gpp,1 --profile-name profile1 --roaming-disallowed-flag no --auth-type none --apn 4g.tele2.se --pdp-type ip
Mon Aug 14 22:33:20 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --get-client-id wds
Mon Aug 14 22:33:21 2023 daemon.notice netifd: mob1s1a1 (30113): 14
Mon Aug 14 22:33:21 2023 daemon.notice netifd: mob1s1a1 (30113): cid4: 14
Mon Aug 14 22:33:21 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --wds-bind-mux-data-port --mux-id 1 --ep-iface-number 4 --set-client-id wds,14
Mon Aug 14 22:33:21 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-ip-family ipv4 --set-client-id wds,14
Mon Aug 14 22:33:21 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,14 --start-network --apn 4g.tele2.se --profile 1 --auth-type none --username --password
Mon Aug 14 22:33:21 2023 daemon.notice netifd: mob1s1a1 (30113): pdh4: -2109867040
Mon Aug 14 22:33:21 2023 daemon.notice netifd: mob1s1a1 (30113): -2109867040
Mon Aug 14 22:33:21 2023 daemon.notice netifd: mob1s1a1 (30113): Setting up qmimux0
Mon Aug 14 22:33:21 2023 daemon.notice netifd: mob1s1a1 (30113): Setting MTU: 1500 on qmimux0
Mon Aug 14 22:33:21 2023 daemon.notice netifd: Interface ‘mob1s1a1’ is now up
Mon Aug 14 22:33:21 2023 daemon.notice netifd: Network device ‘wwan0’ link is up
Mon Aug 14 22:33:21 2023 daemon.notice netifd: mob1s1a1 (30113): Setting up qmimux0 V4 DCHP
Mon Aug 14 22:33:21 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is enabled
Mon Aug 14 22:33:21 2023 daemon.notice netifd: Network device ‘qmimux0’ link is up
Mon Aug 14 22:33:21 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ has link connectivity
Mon Aug 14 22:33:21 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is setting up now
Mon Aug 14 22:33:21 2023 daemon.notice netifd: mob1s1a1_4 (30566): udhcpc: started, v1.34.1
Mon Aug 14 22:33:21 2023 daemon.notice netifd: mob1s1a1_4 (30566): udhcpc: broadcasting discover
Mon Aug 14 22:33:21 2023 daemon.notice netifd: mob1s1a1_4 (30566): udhcpc: broadcasting select for 37.199.171.16, server 37.199.171.17
Mon Aug 14 22:33:21 2023 daemon.notice netifd: mob1s1a1_4 (30566): udhcpc: lease of 37.199.171.16 obtained from 37.199.171.17, lease time 7200
Mon Aug 14 22:33:21 2023 user.warn mwan3-hotplug[30501]: hotplug called on mob1s1a1 before mwan3 has been set up
Mon Aug 14 22:33:22 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is now up
Mon Aug 14 22:33:22 2023 daemon.info dnsmasq[3449]: reading /tmp/resolv.conf.d/resolv.conf.auto
Mon Aug 14 22:33:22 2023 daemon.info dnsmasq[3449]: using only locally-known addresses for domain test
Mon Aug 14 22:33:22 2023 daemon.info dnsmasq[3449]: using only locally-known addresses for domain onion
Mon Aug 14 22:33:22 2023 daemon.info dnsmasq[3449]: using only locally-known addresses for domain localhost
Log part 3
Mon Aug 14 22:33:22 2023 daemon.info dnsmasq[3449]: using only locally-known addresses for domain invalid
Mon Aug 14 22:33:22 2023 daemon.info dnsmasq[3449]: using only locally-known addresses for domain bind
Mon Aug 14 22:33:22 2023 daemon.info dnsmasq[3449]: using only locally-known addresses for domain lan
Mon Aug 14 22:33:22 2023 daemon.info dnsmasq[3449]: using nameserver 130.244.127.161#53
Mon Aug 14 22:33:22 2023 daemon.info dnsmasq[3449]: using nameserver 130.244.127.169#53
Mon Aug 14 22:33:22 2023 user.notice firewall: Reloading firewall due to ifup of mob1s1a1 (wwan0)
Mon Aug 14 22:33:22 2023 daemon.err mobifd: Failed to send PING IPV4
Mon Aug 14 22:33:24 2023 daemon.info dnsmasq[3449]: read /etc/hosts - 4 addresses
Mon Aug 14 22:33:24 2023 daemon.info dnsmasq[3449]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Mon Aug 14 22:33:24 2023 daemon.info dnsmasq-dhcp[3449]: read /etc/ethers - 0 addresses
Mon Aug 14 22:33:24 2023 kern.info Mobile data connected (internal modem)
Mon Aug 14 22:33:24 2023 kern.info Joined network (internal modem)
Mon Aug 14 22:33:24 2023 kern.info Connected to operator (internal modem)
Mon Aug 14 22:33:25 2023 user.warn mwan3-hotplug[31217]: hotplug called on mob1s1a1_4 before mwan3 has been set up
Mon Aug 14 22:33:25 2023 user.notice firewall: Reloading firewall due to ifup of mob1s1a1_4 (qmimux0)
Mon Aug 14 22:33:27 2023 daemon.info dnsmasq[3449]: read /etc/hosts - 4 addresses
Mon Aug 14 22:33:27 2023 daemon.info dnsmasq[3449]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Mon Aug 14 22:33:27 2023 daemon.info dnsmasq-dhcp[3449]: read /etc/ethers - 0 addresses
Mon Aug 14 22:33:27 2023 kern.info Mobile data connected (internal modem)
Mon Aug 14 22:33:27 2023 kern.info Joined network (internal modem)
Mon Aug 14 22:33:27 2023 kern.info Connected to operator (internal modem)
Mon Aug 14 22:33:31 2023 daemon.info procd: Instance ntpclient::instance1 pid 25413 not stopped on SIGTERM, sending SIGKILL instead
Mon Aug 14 22:40:26 2023 daemon.info mobifd: [gsm.modem0] Config reload initiated
Mon Aug 14 22:40:26 2023 daemon.notice netifd: mob1s1a1 (2626): Stopping network mob1s1a1
Mon Aug 14 22:40:26 2023 daemon.notice netifd: Network device ‘qmimux0’ link is down
Mon Aug 14 22:40:26 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ has link connectivity loss
Mon Aug 14 22:40:26 2023 daemon.notice netifd: mob1s1a1_4 (30566): udhcpc: SIOCGIFINDEX: No such device
Mon Aug 14 22:40:26 2023 daemon.notice netifd: mob1s1a1_4 (30566): udhcpc: received SIGTERM
Mon Aug 14 22:40:26 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is now down
Mon Aug 14 22:40:26 2023 user.warn mwan3-hotplug[2625]: hotplug called on mob1s1a1 before mwan3 has been set up
Mon Aug 14 22:40:26 2023 user.notice netifd: uqmi -s -d /dev/cdc-wdm0 -t 3000 --set-client-id wds,14 --stop-network 0xFFFFFFFF --autoconnect
Mon Aug 14 22:40:26 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is disabled
Mon Aug 14 22:40:26 2023 daemon.notice netifd: mob1s1a1 (2626): Stopping network on /dev/cdc-wdm0!
Mon Aug 14 22:40:26 2023 daemon.warn dnsmasq[3449]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Mon Aug 14 22:40:26 2023 daemon.notice netifd: mob1s1a1 (2626): “No effect”
Mon Aug 14 22:40:26 2023 daemon.notice netifd: mob1s1a1 (2626): Releasing client-id 14 on /dev/cdc-wdm0
Mon Aug 14 22:40:26 2023 user.notice netifd: uqmi -s -d /dev/cdc-wdm0 -t 3000 --set-client-id wds,14 --release-client-id wds
Mon Aug 14 22:40:26 2023 daemon.notice netifd: mob1s1a1 (2626): Command failed: Not found
Mon Aug 14 22:40:26 2023 daemon.notice netifd: mob1s1a1 (2626): Command failed: Permission denied
Mon Aug 14 22:40:26 2023 daemon.notice netifd: Interface ‘mob1s1a1’ is now down
Mon Aug 14 22:40:27 2023 daemon.info dnsmasq[3449]: read /etc/hosts - 4 addresses
Mon Aug 14 22:40:27 2023 daemon.info dnsmasq[3449]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Mon Aug 14 22:40:27 2023 daemon.info dnsmasq-dhcp[3449]: read /etc/ethers - 0 addresses
Mon Aug 14 22:40:28 2023 kern.info Mobile data disconnected (internal modem)
Mon Aug 14 22:40:31 2023 daemon.info mobifd: [gsm.modem0] Initializing modem. Please wait.
Mon Aug 14 22:42:31 2023 daemon.info mobifd: [gsm.modem0] SMS storage: sm
Log part 4
Mon Aug 14 22:42:31 2023 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with 5 seconds of timeout
Mon Aug 14 22:42:31 2023 daemon.info mobifd: [gsm.modem0] Connected to operator ‘Tele2 Tele2’
Mon Aug 14 22:42:31 2023 daemon.info mobifd: [gsm.modem0] -CFUN- Functionality: “Full”
Mon Aug 14 22:42:31 2023 daemon.info mobifd: [gsm.modem0] -COPS- Mode: “Auto”, operator: “Tele2 Tele2”
Mon Aug 14 22:42:31 2023 daemon.info mobifd: [gsm.modem0] -CREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “34056”, cell ID: “80572166”, technology: “E-UTRAN”
Mon Aug 14 22:42:31 2023 daemon.info mobifd: [gsm.modem0] -CGREG- Mode: “Enabled (with location information)”, status: “Not registered”, LAC: “”, cell ID: “”, technology: “Unknown”
Mon Aug 14 22:42:31 2023 daemon.info mobifd: [gsm.modem0] -CEREG- Mode: “Enabled (with location information)”, status: “Registered, home”, LAC: “34056”, cell ID: “80572166”, technology: “E-UTRAN”
Mon Aug 14 22:42:31 2023 daemon.info mobifd: [gsm.modem0] IP address on PDP context “1”: “37.196.114.79”
Mon Aug 14 22:42:31 2023 daemon.notice netifd: Interface ‘mob1s1a1’ is setting up now
Mon Aug 14 22:42:32 2023 daemon.notice netifd: mob1s1a1 (3909): wwan[3909] Using wwan usb device on bus 2-1
Mon Aug 14 22:42:32 2023 daemon.notice netifd: mob1s1a1 (3909): wwan[3909] Using proto:qmapv5 device:/dev/cdc-wdm0 iface:wwan0 desc:Quectel RG50X
Mon Aug 14 22:42:32 2023 daemon.notice netifd: mob1s1a1 (3909): Failed to parse message data
Mon Aug 14 22:42:32 2023 daemon.notice netifd: mob1s1a1 (3909): Command failed: Not found
Mon Aug 14 22:42:32 2023 daemon.notice netifd: mob1s1a1 (3909): WARNING: Variable ‘list’ does not exist or is not an array/object
Mon Aug 14 22:42:32 2023 daemon.notice netifd: mob1s1a1 (3909): Creating context with PDP: 1
Mon Aug 14 22:42:34 2023 daemon.notice netifd: mob1s1a1 (3909): Quering active sim position
Mon Aug 14 22:42:34 2023 daemon.notice netifd: mob1s1a1 (3909): Calculated qmimux ifname: qmimux0
Mon Aug 14 22:42:34 2023 user.notice root: uqmi -d /dev/cdc-wdm0 --timeout 3000 --wda-set-data-format --qos-format 0 --link-layer-protocol raw-ip --endpoint-type hsusb --endpoint-iface-number 4 --ul-protocol qmapv5 --dl-protocol qmapv5 --ul-max-datagrams 11 --ul-datagram-max-size 8192 --dl-max-datagrams 62 --dl-datagram-max-size 31744 --dl-min-padding 0
Mon Aug 14 22:42:34 2023 daemon.notice netifd: mob1s1a1 (3909): Starting network mob1s1a1 using APN: 4g.tele2.se
Mon Aug 14 22:42:34 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,14 --release-client-id wds --modify-profile --profile-identifier 3gpp,1 --profile-name profile1 --roaming-disallowed-flag no --auth-type none --apn 4g.tele2.se --pdp-type ip
Mon Aug 14 22:42:35 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --get-client-id wds
Mon Aug 14 22:42:35 2023 daemon.notice netifd: mob1s1a1 (3909): 14
Mon Aug 14 22:42:35 2023 daemon.notice netifd: mob1s1a1 (3909): cid4: 14
Mon Aug 14 22:42:35 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --wds-bind-mux-data-port --mux-id 1 --ep-iface-number 4 --set-client-id wds,14
Mon Aug 14 22:42:35 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-ip-family ipv4 --set-client-id wds,14
Mon Aug 14 22:42:35 2023 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 3000 --set-client-id wds,14 --start-network --apn 4g.tele2.se --profile 1 --auth-type none --username --password
Mon Aug 14 22:42:35 2023 daemon.notice netifd: mob1s1a1 (3909): pdh4: -2111299488
Mon Aug 14 22:42:35 2023 daemon.notice netifd: mob1s1a1 (3909): -2111299488
Mon Aug 14 22:42:35 2023 daemon.notice netifd: mob1s1a1 (3909): Setting up qmimux0
Mon Aug 14 22:42:35 2023 daemon.notice netifd: mob1s1a1 (3909): Setting MTU: 1500 on qmimux0
Mon Aug 14 22:42:35 2023 daemon.notice netifd: Interface ‘mob1s1a1’ is now up
Mon Aug 14 22:42:35 2023 daemon.notice netifd: Network device ‘wwan0’ link is up
Mon Aug 14 22:42:35 2023 daemon.notice netifd: mob1s1a1 (3909): Setting up qmimux0 V4 DCHP
Mon Aug 14 22:42:35 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is enabled
Mon Aug 14 22:42:35 2023 daemon.notice netifd: Network device ‘qmimux0’ link is up
Mon Aug 14 22:42:35 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ has link connectivity
Mon Aug 14 22:42:35 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is setting up now
Mon Aug 14 22:42:35 2023 daemon.notice netifd: mob1s1a1_4 (4282): udhcpc: started, v1.34.1
Log part 5
Mon Aug 14 22:42:35 2023 daemon.notice netifd: mob1s1a1_4 (4282): udhcpc: broadcasting discover
Mon Aug 14 22:42:35 2023 daemon.notice netifd: mob1s1a1_4 (4282): udhcpc: broadcasting select for 37.196.114.79, server 37.196.114.80
Mon Aug 14 22:42:36 2023 daemon.notice netifd: mob1s1a1_4 (4282): udhcpc: lease of 37.196.114.79 obtained from 37.196.114.80, lease time 7200
Mon Aug 14 22:42:36 2023 user.warn mwan3-hotplug[4231]: hotplug called on mob1s1a1 before mwan3 has been set up
Mon Aug 14 22:42:36 2023 daemon.notice netifd: Interface ‘mob1s1a1_4’ is now up
Mon Aug 14 22:42:36 2023 daemon.info dnsmasq[3449]: reading /tmp/resolv.conf.d/resolv.conf.auto
Mon Aug 14 22:42:36 2023 daemon.info dnsmasq[3449]: using only locally-known addresses for domain test
Mon Aug 14 22:42:36 2023 daemon.info dnsmasq[3449]: using only locally-known addresses for domain onion
Mon Aug 14 22:42:36 2023 daemon.info dnsmasq[3449]: using only locally-known addresses for domain localhost
Mon Aug 14 22:42:36 2023 daemon.info dnsmasq[3449]: using only locally-known addresses for domain invalid
Mon Aug 14 22:42:36 2023 daemon.info dnsmasq[3449]: using only locally-known addresses for domain bind
Mon Aug 14 22:42:36 2023 daemon.info dnsmasq[3449]: using only locally-known addresses for domain lan
Mon Aug 14 22:42:36 2023 daemon.info dnsmasq[3449]: using nameserver 130.244.127.161#53
Mon Aug 14 22:42:36 2023 daemon.info dnsmasq[3449]: using nameserver 130.244.127.169#53
Mon Aug 14 22:42:36 2023 user.notice firewall: Reloading firewall due to ifup of mob1s1a1 (wwan0)
Mon Aug 14 22:42:38 2023 daemon.info dnsmasq[3449]: read /etc/hosts - 4 addresses
Mon Aug 14 22:42:38 2023 daemon.info dnsmasq[3449]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Mon Aug 14 22:42:38 2023 daemon.info dnsmasq-dhcp[3449]: read /etc/ethers - 0 addresses
Mon Aug 14 22:42:38 2023 kern.info Mobile data connected (internal modem)
Mon Aug 14 22:42:38 2023 kern.info Joined network (internal modem)
Mon Aug 14 22:42:38 2023 kern.info Connected to operator (internal modem)
Mon Aug 14 22:42:39 2023 user.warn mwan3-hotplug[4937]: hotplug called on mob1s1a1_4 before mwan3 has been set up
Mon Aug 14 22:42:39 2023 user.notice firewall: Reloading firewall due to ifup of mob1s1a1_4 (qmimux0)
Mon Aug 14 22:42:41 2023 daemon.info dnsmasq[3449]: read /etc/hosts - 4 addresses
Mon Aug 14 22:42:41 2023 daemon.info dnsmasq[3449]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Mon Aug 14 22:42:41 2023 daemon.info dnsmasq-dhcp[3449]: read /etc/ethers - 0 addresses
Mon Aug 14 22:42:41 2023 kern.info Mobile data connected (internal modem)
Mon Aug 14 22:42:41 2023 kern.info Joined network (internal modem)
Mon Aug 14 22:42:41 2023 kern.info Connected to operator (internal modem)
Mon Aug 14 22:42:45 2023 daemon.info procd: Instance ntpclient::instance1 pid 31802 not stopped on SIGTERM, sending SIGKILL instead
Done sending the log.
I really need help with this issue as I can not use the router with its current failing in my streaming business. Last weekends gig I needed to use another router to manage to pull of the assignment which caused me many hours of extra work.
I really like to formfactor and potention of the RUTX50, but not with the instability it gives me.
If needed I also generated troubeshoot files just right after the outages that I could supply.
Current firware information
Firmware version RUTX_R_00.07.04.3
Firmware build date 2023-05-17 11:31:06
Thanks for any help!
