RUTX50 Mobile Connection Issues
Model: Teltonika RUTX50
Hardware:
Product code RUTX5000XXXX
Bootloader version 3.0
Hardware revision 0202
Batch number 0015
Software:
Firmware version RUTX_R_00.07.16.3
Kernel version 6.6.92
Load average 0.07, 0.10, 0.09
We are facing a problem with a customer that is happening on a teltonika, which is connected via Ethernet to the LAN and can see the internet via the modem. No other interfaces are used.
About 10Mbps is constantly flowing from the mobile network to the LAN (Streams from cameras and tunnels). The SIM card has an unlimited data limit. If everything is working properly, we measure approximately 100/100Mbps with a speedtest.
Problem description: The teltonika modem switches to another BTS station of the operator from time to time (about 1x every 14-30 days) and at that moment either the internet speed slows down and the ping to the SIM internet address starts to show greater latency or the ping to the SIM stops responding completely.
The only solution is to either wait for it to fix itself, restart the teltonika or restart + wait.
What we tried:
Upgrade the firmware of the teltonic and modem - no improvement.
Contact the mobile operator - they do not register the problem on their side.
Set the specific desired bands in Network>Mobile>Connection - no improvement.
Replace the supplied antenna(s) with a directional one and point it towards the desired BTS - no improvement.
The last option that comes to mind and I have it in reserve for now is to set a periodic reboot during the night, but that is not entirely desirable for us.
Please advise me on how to diagnose and solve the problem.
Is it possible that this is a defect in the teltonics itself?
Thank you.
To better understand the issue you’re facing, could you clarify:
  • Whether, during these BTS station changes (when the operator most likely restarts its station and the modem automatically reconnects to another cell), the main issue is that throughput decreases significantly or that the connection is completely lost? And for how long does this situation usually persist before it recovers by itself?
  • I would also expect that during such interruptions the primary band signal drops, in that case, it might be worth trying a reconnection on a low signal level rather than relying on a scheduled periodic reboot. A ping/wget modem or connection restart could also be worth serving as a fallback option (more details on Ping Reboot can be found here).
  • How long do you typically need to wait for the connection to restore automatically?
  • Does the switch also happen when the preferred network type is locked to 4G only, or does it occur only when using 4G/3G auto?
  • Could you share a screenshot from Status → Network → Mobile the next time this switch happens?
  • Additionally, have you noticed whether this issue is tied to specific bands? If so, it could be worth trying to lock the modem to other bands that remain more stable.
Since this is a rather complex issue, if it persists or can be reproduced, we will need to continue the troubleshooting and investigation process privately.
Let me know the outcome of how it goes.
Hello Martynas,
here is the anwers…
It happens very irregularly. I can’t tell the duration. Let’s say it’s hours. The usual scenario is that the outage lasts too long and we have to restart the router manually because we always need to restore the connection as soon as possible.
I know about this option, but I’m not using it yet because we need to monitor the problem. Creating a rule would prevent it.
Same as the answer to the first question.
We have now set this option to “4G/3G auto” and will observe if the problem persists.
I am attaching a screenshot from this morning, when a completely new symptom appeared. The mobile connection seemed to be completely disconnected. I tried “Restart Connection” in this situation, but the connection was not restored. Only restarting the entire device helped.
Down I am also attaching an extract from the event log, where I marked when exactly the problem started and when we restarted the router.
We also got this idea. I am attaching a screenshot of the settings for locking to certain bands.
Unfortunately, even with this setting, the problems persist.
Event log:
ID;Date;Source;Event group;Event type;Event
2489;2025-09-24 13:25:49;CONFIG;events;notice;“User ““admin”” changed Ping_reboot configuration in “”/system/maintenance/auto_reboot/ping_reboot”" page"
2490;2025-09-24 13:37:00;Web UI;connections;notice;“User ““admin”” successfully authenticated on HTTPS from xx.xx.xx.xx to xx.xx.xx.xx”
2491;2025-09-24 13:57:31;Health checker;network;notice;IPv4 connectivity started to fail
2492;2025-09-24 13:58:34;Health checker;network;notice;IPv4 connectivity restored
2493;2025-09-24 23:56:52;Health checker;network;notice;IPv4 connectivity started to fail
2494;2025-09-24 23:57:56;Health checker;network;notice;IPv4 connectivity restored
2495;2025-09-25 04:28:16;Health checker;network;notice;IPv4 connectivity started to fail
2496;2025-09-25 04:28:37;Health checker;network;notice;DNS resolution started to fail
2497;2025-09-25 04:40:02;Health checker;network;notice;IPv4 connectivity restored
2498;2025-09-25 04:40:05;Health checker;network;notice;DNS resolution restored
2499;2025-09-25 07:46:16;Health checker;network;notice;IPv4 connectivity started to fail
2500;2025-09-25 07:46:37;Health checker;network;notice;DNS resolution started to fail
2501;2025-09-25 07:50:38;Health checker;network;notice;IPv4 connectivity restored
2502;2025-09-25 07:50:41;Health checker;network;notice;DNS resolution restored
2503;2025-09-27 17:37:06;Health checker;network;notice;IPv4 connectivity started to fail
2504;2025-09-27 17:39:47;Health checker;network;notice;DNS resolution started to fail
2505;2025-09-27 17:57:10;Health checker;network;notice;IPv4 connectivity restored
2506;2025-09-27 17:57:13;Health checker;network;notice;DNS resolution restored
2507;2025-09-28 07:07:52;Health checker;network;notice;IPv4 connectivity started to fail
2508;2025-09-28 07:08:55;Health checker;network;notice;IPv4 connectivity restored
2509;2025-09-29 07:32:51;Health checker;network;notice;IPv4 connectivity started to fail
2510;2025-09-29 07:33:55;Health checker;network;notice;IPv4 connectivity restored
2511;2025-09-29 07:35:41;Web UI;connections;notice;“User ““admin”” successfully authenticated on HTTPS from xx.xx.xx.xx to xx.xx.xx.xx”
2512;2025-09-29 07:39:13;Health checker;network;notice;IPv4 connectivity started to fail
2513;2025-09-29 07:40:16;Health checker;network;notice;IPv4 connectivity restored
2514;2025-09-29 07:46:29;CONFIG;events;notice;“User ““admin”” changed Ping_reboot configuration in “”/system/maintenance/auto_reboot/ping_reboot”" page"
===PROBLEM STARTED=======================
2515;2025-09-29 08:41:31;Health checker;network;notice;IPv4 connectivity started to fail
2516;2025-09-29 08:42:40;Health checker;network;notice;IPv4 connectivity restored
2517;2025-09-29 08:46:01;Health checker;network;notice;IPv4 connectivity started to fail
2518;2025-09-29 08:47:05;Health checker;network;notice;IPv4 connectivity restored
2519;2025-09-29 08:47:26;Health checker;network;notice;DNS resolution started to fail
2520;2025-09-29 08:48:35;Health checker;network;notice;IPv4 connectivity started to fail
2521;2025-09-29 08:48:38;Health checker;network;notice;DNS resolution restored
2522;2025-09-29 08:55:05;Ping Reboot;events;info;Sending message after 2 unsuccessful retries
2523;2025-09-29 08:59:45;Health checker;network;notice;DNS resolution started to fail
2524;2025-09-29 09:00:05;Ping Reboot;events;info;Sending message after 3 unsuccessful retries
2525;2025-09-29 09:03:24;Mobile Data;network;info;Mobile data disconnected (internal modem)
2526;2025-09-29 09:05:00;Ping Reboot;events;info;Sending message after 4 unsuccessful retries
2527;2025-09-29 09:06:34;Mobile Data;network;info;Mobile data disconnected (internal modem)
2528;2025-09-29 09:10:00;Ping Reboot;events;info;Sending message after 5 unsuccessful retries
2529;2025-09-29 09:15:00;Ping Reboot;events;info;Sending message after 6 unsuccessful retries
2530;2025-09-29 09:20:00;Ping Reboot;events;info;Sending message after 7 unsuccessful retries
2531;2025-09-29 09:25:00;Ping Reboot;events;info;Sending message after 8 unsuccessful retries
2532;2025-09-29 09:30:00;Ping Reboot;events;info;Sending message after 9 unsuccessful retries
2533;2025-09-29 09:35:00;Ping Reboot;events;info;Sending message after 10 unsuccessful retries
2534;2025-09-29 09:40:00;Ping Reboot;events;info;Sending message after 11 unsuccessful retries
2535;2025-09-29 09:43:36;Web UI;connections;notice;“User ““admin”” successfully authenticated on HTTPS from xx.xx.xx.xx to xx.xx.xx.xx”
===REBOOT FROM WEBUI=======================
2536;2025-09-29 09:45:00;Ping Reboot;events;info;Sending message after 12 unsuccessful retries
2537;2025-09-29 09:48:15;Reboot;system;info;Request from Web UI
2538;2025-09-29 09:49:08;Startup;system;notice;Device startup completed
2539;2025-09-29 09:49:10;Switch Events;network;notice;Port link state of port CPU/WiFi (1000 baseT) changed to UP
2540;2025-09-29 09:49:10;Switch Events;network;notice;Port link state of port LAN2 (1000 baseT) changed to UP
2541;2025-09-29 09:50:14;Mobile Data;network;info;Mobile data connected (internal modem)
2542;2025-09-29 09:50:14;Network Type;network;info;Joined 5G-NSA network (internal modem)
2543;2025-09-29 09:50:14;Network Operator;network;info;Connected to 23002 operator (internal modem)
2544;2025-09-29 09:50:18;Fota;system;notice;Firmware update to RUTX_R_00.07.16.6 is now available
2545;2025-09-29 09:51:38;Web UI;connections;notice;“User ““admin”” successfully authenticated on HTTPS from xx.xx.xx.xx to xx.xx.xx.xx”
Apologies for the delay, and thank you for the last update.
I just wanted to follow up and ask whether the issue is still noticeable or has been reproduced again since your last message. From the provided logs, it seems that after the reboot, the modem successfully reconnected to the 5G NSA network and connectivity was restored.
Could you please check if your case might be related to the one described in this thread, where the modem crashes under higher throughput conditions?
It would also be helpful to know whether the same issue appears when the device is locked to a 4G-only network.
If nothing changes, we’ll need to investigate this specific issue more in depth privately.
I very occasionally get this happening. My Poynting directional antenna is pointed directly at the best mast for me, which isn’t the closest at 2.6miles away. I have another roughly 70 degrees off to one side at 1.2 miles, but because of the topography of the landscape and the stuff that’s in it the signal is bad.
On rare occasions i get connected to the nearer mast for some reason, restarting the modem just reconnects me to the same mast. I think the reconnection process happens far too quickly, and i think my provider’s network just thinks it’s a minor blip. Restarting the entire router has better success, possibly because it takes longer. When this doesn’t work, i turn the router off for ten mins, this solves the problem.
The only time this didn’t work was when unbeknown to me my preferred mast had actually gone offline altogether for a tad over 24hrs.
