RUTX11 broken power connector
today i need to relocate our X11, after unplug the cable, the power connector inside disappears. Checking it and shows up that the soldered connection points are ripped off and there is no soldering point more on the board.
What kind of idea is this, build such a unstable connection for a industrial router? I have seen this guy with the X12 and same issue.
I had taken over this router from the previous owner in the camper truck and was happy to have a industrial device. Device was not moved as much, but is never had this on a normal home router after 15 years in IT.
I’m sorry to hear about the issue with your power connector. I recommend reaching out to your sales manager or the reseller from whom you purchased the device to initiate the RMA (Return Merchandise Authorization) procedure. Alternatively, you can use the ‘contact us’ form available here.
If you need any further assistance or have additional questions, feel free to let me know.
