Help! - RUTX12 Weak Power Connector & Short Circuit No Power
Hi All,
I need some help. I’m using a RutX12 as an LTE gateway for a remote site. After relocating the router, the onsite person reported that the power connector broke off and slid inside the device without any excessive force. Upon inspection, it was found detached from the solder points on the board.
Since RMA wasn’t an option, I had it soldered back. The router powered on, and the BGP session normalized, but it shut down again after a few minutes due to a short circuit detected by the 12V Meanwell power supply. The technician suspects the initial damage caused an internal short, rendering the device unusable.
I’m truly disappointed that an industrial-rated product has such a weak, delicate power connector. If this were installed in a mobile application, I doubt it would survive. I’ve purchased several of these routers for other sites, and now I’m concerned about their build quality.
I also found a similar issue reported here: RUTX11 broken power connector, showing that another device experienced the same problem.
My only option now is to get this repaired. Can I send it back to Teltonika for repair? If so, how and where should I send it, and what would be the cost for such a repair?
Thanks.
Could anyone help with this please ?
For further assistance regarding the RMA process, we will need to contact you privately. To proceed, I have sent you a form to fill out. When completing for the ticket ID use 12017. Once submitted, we will reach out to request the necessary information for the RMA.
Any update on this ? I filled and submit the form that sent to me but no update after that
Hello @semiraue,
You should have received an email from us with instructions regarding the RMA process. Could you please check your email inbox, including your spam/junk folders, to ensure you received it?
Looking forward to your response.
