RUT955 w data-only SIM
I have a RUT955 which has the latest firmware. I am having trouble connecting to the internet using the mobile data only SIM card [KPN cellular provider in the Netherlands]. Looking forward to your help. (I am not a network expert but am somewhat technical)
Thank you, Ann
Could you please provide more details about the issues you are experiencing? Additionally, it would be helpful if you could retrieve logs related to the initiation of the mobile connection. To do this, please follow these steps:
  1. Restart the device.
  2. Connect to the device via the web user interface (webUI).
  3. Navigate to System → Maintenance → CLI Log (Username: root, Password: <your_device_password>).
  4. Execute the following command:
logread
  1. Copy the output and provide it for further investigation.
Here is the output from the command:
root@RUT955:~# logread
Tue May 14 13:30:14 2024 kern.notice kernel: [ 0.000000] Linux version 5.4.259 (app@runner-ffj
pezdj-project-352-concurrent-0) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r16279-5cc0535800)) #0 Fri
May 3 04:53:06 2024
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.000000] printk: bootconsole [early0] enabled
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.000000] CPU0 revision is: 0001974c (MIPS 74Kc)
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.000000] MIPS: machine is Teltonika RUT9XX
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.000000] SoC: Atheros AR9344 rev 3
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.000000] Initrd not found or empty - disabling i
nitrd
Tue May 14 13:30:14 2024 kern.warn kernel: [ 0.000000] Primary instruction cache 64kB, VIPT, 4
-way, linesize 32 bytes.
Tue May 14 13:30:14 2024 kern.warn kernel: [ 0.000000] Primary data cache 32kB, 4-way, VIPT, c
ache aliases, linesize 32 bytes
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.000000] Zone ranges:
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.000000] Normal [mem 0x0000000000000000-0x00
00000007ffffff]
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.000000] Movable zone start for each node
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.000000] Early memory node ranges
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.000000] node 0: [mem 0x0000000000000000-0x0
000000007ffffff]
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.000000] Initmem setup node 0 [mem 0x00000000000
00000-0x0000000007ffffff]
Tue May 14 13:30:14 2024 kern.debug kernel: [ 0.000000] On node 0 totalpages: 32768
Tue May 14 13:30:14 2024 kern.debug kernel: [ 0.000000] Normal zone: 256 pages used for memm
ap
Tue May 14 13:30:14 2024 kern.debug kernel: [ 0.000000] Normal zone: 0 pages reserved
Tue May 14 13:30:14 2024 kern.debug kernel: [ 0.000000] Normal zone: 32768 pages, LIFO batch
:7
Tue May 14 13:30:14 2024 kern.debug kernel: [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=
132768
Tue May 14 13:30:14 2024 kern.debug kernel: [ 0.000000] pcpu-alloc: [0] 0
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.000000] Built 1 zonelists, mobility grouping on
. Total pages: 32512
Tue May 14 13:30:14 2024 kern.notice kernel: [ 0.000000] Kernel command line: console=ttyS0,11
5200 rootfstype=squashfs,jffs2
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.000000] Dentry cache hash table entries: 16384
(order: 4, 65536 bytes, linear)
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.000000] Inode-cache hash table entries: 8192 (o
rder: 3, 32768 bytes, linear)
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.000000] Writing ErrCtl register=00000000
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.000000] Readback ErrCtl register=00000000
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.000000] mem auto-init: stack:off, heap alloc:of
f, heap free:off
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.000000] Memory: 123592K/131072K available (4046
K kernel code, 164K rwdata, 620K rodata, 1240K init, 187K bss, 7480K reserved, 0K cma-reserved)
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects
=0, CPUs=1, Nodes=1
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.000000] NR_IRQS: 51
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.000000] CPU clock: 550.000 MHz
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.000000] clocksource: MIPS: mask: 0xffffffff max
_cycles: 0xffffffff, max_idle_ns: 6950037990 ns
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.000011] sched_clock: 32 bits at 275MHz, resolut
ion 3ns, wraps every 7809031678ns
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.008788] Calibrating delay loop… 273.66 BogoMI
PS (lpj=547328)
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.055668] pid_max: default: 32768 minimum: 301
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.060978] Mount-cache hash table entries: 1024 (o
rder: 0, 4096 bytes, linear)
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.069146] Mountpoint-cache hash table entries: 10
24 (order: 0, 4096 bytes, linear)
Tue May 14 13:30:14 2024 kern.warn kernel: [ 0.080231] Duplicate name in mnfinfo, renamed to "
name#1"
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.090905] clocksource: jiffies: mask: 0xffffffff
max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.101812] futex hash table entries: 256 (order: -
1, 3072 bytes, linear)
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.109469] pinctrl core: initialized pinctrl subsy
stem
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.117205] NET: Registered protocol family 16
Tue May 14 13:30:14 2024 kern.warn kernel: [ 0.158051] gpio-17 (i2c@0): enforced open drain pl
ease flag it properly in DT/ACPI DSDT/board file
Tue May 14 13:30:14 2024 kern.warn kernel: [ 0.168264] gpio-16 (i2c@0): enforced open drain pl
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.178867] i2c-gpio i2c@0: using lines 17 (SDA) an
d 16 (SCL)
Tue May 14 13:30:14 2024 kern.warn kernel: [ 0.185701] workqueue: max_active 576 requested for
napi_workq is out of range, clamping between 1 and 512
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.202019] clocksource: Switched to clocksource MI
PS
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.209103] NET: Registered protocol family 2
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.214355] IP idents hash table entries: 2048 (ord
er: 2, 16384 bytes, linear)
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.223486] tcp_listen_portaddr_hash hash table ent
ries: 512 (order: 0, 4096 bytes, linear)
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.232913] TCP established hash table entries: 102
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.241488] TCP bind hash table entries: 1024 (orde
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.249376] TCP: Hash tables configured (establishe
d 1024 bind 1024)
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.256644] UDP hash table entries: 256 (order: 0,
4096 bytes, linear)
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.264000] UDP-Lite hash table entries: 256 (order
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.272136] NET: Registered protocol family 1
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.277081] PCI: CLS 0 bytes, default 32
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.286791] workingset: timestamp_bits=30 max_order
=15 bucket_order=0
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.301213] squashfs: version 4.0 (2009/01/31) Phil
lip Lougher
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.307775] squashfs: patched 4.0 (2020/11/10) Oeve
r Gonzalez
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.314194] jffs2: version 2.2 (NAND) (SUMMARY) (LZ
MA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.344469] pinctrl-single 1804002c.pinmux: 544 pin
s, size 68
Tue May 14 13:30:14 2024 kern.err kernel: [ 0.357709] spi spi0.1: INFO: gpio[3] set up status(
0)
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.364514] shift_io@0 enforce active low on chipse
lect handle
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.377034] spi-nor spi0.0: xt25f128b (16384 Kbytes
Tue May 14 13:30:14 2024 kern.notice kernel: [ 0.382703] 5 fixed-partitions partitions found o
n MTD device spi0.0
Tue May 14 13:30:14 2024 kern.notice kernel: [ 0.389807] Creating 5 MTD partitions on “spi0.0”
Tue May 14 13:30:14 2024 kern.notice kernel: [ 0.395184] 0x000000000000-0x000000020000 : “u-bo
ot”
Tue May 14 13:30:14 2024 kern.notice kernel: [ 0.401895] 0x000000020000-0x000000030000 : “conf
ig”
Tue May 14 13:30:14 2024 kern.notice kernel: [ 0.408629] 0x000000030000-0x000000040000 : “art”
Tue May 14 13:30:14 2024 kern.notice kernel: [ 0.415087] 0x000000040000-0x000000f70000 : “firm
ware”
Tue May 14 13:30:14 2024 kern.notice kernel: [ 0.427091] 2 tplink-fw partitions found on MTD d
evice firmware
Tue May 14 13:30:14 2024 kern.notice kernel: [ 0.433752] Creating 2 MTD partitions on “firmwar
e”:
Tue May 14 13:30:14 2024 kern.notice kernel: [ 0.439313] 0x000000000000-0x00000018e9e3 : “kern
el”
Tue May 14 13:30:14 2024 kern.notice kernel: [ 0.446080] 0x00000018e9e4-0x000000f30000 : “root
fs”
Tue May 14 13:30:14 2024 kern.notice kernel: [ 0.452718] mtd: device 5 (rootfs) set to be root
filesystem
Tue May 14 13:30:14 2024 kern.notice kernel: [ 0.461551] 1 squashfs-split partitions found on
MTD device rootfs
Tue May 14 13:30:14 2024 kern.notice kernel: [ 0.468525] 0x000000c60000-0x000000f30000 : “root
fs_data”
Tue May 14 13:30:14 2024 kern.notice kernel: [ 0.475702] 0x000000f70000-0x000001000000 : “even
t-log”
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.486859] MNFINFO PROPERTIES:
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.490425] mac : 001E423C5ADC
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.494424] name : RUT955V03XXX
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.498415] serial : 1112458651
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.502207] hwver : 1714
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.505405] batch : 0103
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.508623] sim_count: 2
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.511544] blver : 3.2.6
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.515254] Serial: 8250/16550 driver, 1 ports, IRQ
sharing disabled
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.523364] printk: console [ttyS0] disabled
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.528262] 18020000.uart: ttyS0 at MMIO 0x18020000
(irq = 9, base_baud = 2500000) is a 16550A
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.537911] printk: console [ttyS0] enabled
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.546826] printk: bootconsole [early0] disabled
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.560550] ar933x-uart 18500000.uart: Incompatible
hardware, disabling RS485 RTS control!
Tue May 14 13:30:14 2024 kern.info kernel: [ 0.569145] 18500000.uart: ttyATH1 at MMIO 0x185000
00 (irq = 12, base_baud = 2500000) is a AR933X UART
Tue May 14 13:30:14 2024 kern.err kernel: [ 0.923137] ag71xx 19000000.eth: Could not connect t
o PHY device. Deferring probe.
Tue May 14 13:30:14 2024 kern.info kernel: [ 1.572232] switch0: Atheros AR8229 rev. 1 switch r
egistered on mdio.0
Tue May 14 13:30:14 2024 kern.info kernel: [ 1.616046] ag71xx 1a000000.eth: connected to PHY a
t fixed-0:00 [uid=00000000, driver=Generic PHY]
Tue May 14 13:30:14 2024 kern.info kernel: [ 1.626120] eth0: Atheros AG71xx at 0xba000000, irq
5, mode: gmii
Tue May 14 13:30:14 2024 kern.info kernel: [ 1.632634] i2c /dev entries driver
Tue May 14 13:30:14 2024 kern.info kernel: [ 1.646772] NET: Registered protocol family 10
Tue May 14 13:30:14 2024 kern.info kernel: [ 1.657402] Segment Routing with IPv6
Tue May 14 13:30:14 2024 kern.info kernel: [ 1.661379] NET: Registered protocol family 17
Tue May 14 13:30:14 2024 kern.info kernel: [ 1.666397] 8021q: 802.1Q VLAN Support v1.8
Tue May 14 13:30:14 2024 kern.info kernel: [ 1.673156] gpio-export gpio-export: 5 gpio(s) expo
rted
Tue May 14 13:30:14 2024 kern.info kernel: [ 1.995987] ag71xx 19000000.eth: connected to PHY a
t mdio.0:1f:04 [uid=004dd042, driver=Generic PHY]
Tue May 14 13:30:14 2024 kern.info kernel: [ 2.006640] eth1: Atheros AG71xx at 0xb9000000, irq
4, mode: mii
Tue May 14 13:30:14 2024 kern.info kernel: [ 2.021075] VFS: Mounted root (squashfs filesystem)
readonly on device 31:5.
Tue May 14 13:30:14 2024 kern.info kernel: [ 2.035873] Freeing unused kernel memory: 1240K
Tue May 14 13:30:14 2024 kern.warn kernel: [ 2.040516] This architecture does not have kernel
memory protection.
Tue May 14 13:30:14 2024 kern.info kernel: [ 2.047061] Run /sbin/init as init process
Tue May 14 13:30:14 2024 user.info kernel: [ 2.686492] init: Console is alive
Tue May 14 13:30:14 2024 user.info kernel: [ 2.690593] init: - watchdog -
Tue May 14 13:30:14 2024 user.info kernel: [ 5.349480] kmodloader: loading kernel modules from
/etc/modules-boot.d/
Tue May 14 13:30:14 2024 kern.info kernel: [ 5.542659] usbcore: registered new interface drive
r usbfs
Tue May 14 13:30:14 2024 kern.info kernel: [ 5.548402] usbcore: registered new interface drive
r hub
Tue May 14 13:30:14 2024 kern.info kernel: [ 5.553932] usbcore: registered new device driver u
sb
Tue May 14 13:30:14 2024 kern.info kernel: [ 5.722614] ehci_hcd: USB 2.0 ‘Enhanced’ Host Contr
oller (EHCI) Driver
Tue May 14 13:30:14 2024 kern.notice kernel: [ 5.742644] SCSI subsystem initialized
Tue May 14 13:30:14 2024 kern.info kernel: [ 5.754972] fsl-ehci: Freescale EHCI Host controlle
r driver
Tue May 14 13:30:14 2024 kern.info kernel: [ 5.763888] ehci-platform: EHCI generic platform dr
iver
Tue May 14 13:30:14 2024 kern.info kernel: [ 5.769627] ehci-platform 1b000000.usb: EHCI Host C
ontroller
Tue May 14 13:30:14 2024 kern.info kernel: [ 5.775486] ehci-platform 1b000000.usb: new USB bus
registered, assigned bus number 1
Tue May 14 13:30:14 2024 kern.info kernel: [ 5.783572] ehci-platform 1b000000.usb: irq 3, io m
em 0x1b000000
Tue May 14 13:30:14 2024 kern.info kernel: [ 5.802048] ehci-platform 1b000000.usb: USB 2.0 sta
rted, EHCI 1.00
Tue May 14 13:30:14 2024 kern.info kernel: [ 5.809485] hub 1-0:1.0: USB hub found
Tue May 14 13:30:14 2024 kern.info kernel: [ 5.813934] hub 1-0:1.0: 1 port detected
Tue May 14 13:30:14 2024 kern.info kernel: [ 5.843557] usbcore: registered new interface drive
r usb-storage
Tue May 14 13:30:14 2024 kern.info kernel: [ 6.074059] usb 1-1: new high-speed USB device numb
er 2 using ehci-platform
Tue May 14 13:30:14 2024 kern.info kernel: [ 6.245006] hub 1-1:1.0: USB hub found
Tue May 14 13:30:14 2024 kern.info kernel: [ 6.253159] hub 1-1:1.0: 4 ports detected
Tue May 14 13:30:14 2024 kern.info kernel: [ 6.550067] usb 1-1.3: new full-speed USB device nu
mber 3 using ehci-platform
Tue May 14 13:30:14 2024 kern.info kernel: [ 8.882132] mmc_spi spi0.1: SD/MMC host mmc0, no WP
, no poweroff, cd polling
Tue May 14 13:30:14 2024 user.info kernel: [ 8.891939] kmodloader: done loading kernel modules
from /etc/modules-boot.d/*
Tue May 14 13:30:14 2024 kern.warn kernel: [ 8.899538] mmc_spi spi0.1: no card detected
Tue May 14 13:30:14 2024 kern.err kernel: [ 8.903913] mmc0: error -22 whilst initialising SD c
ard
Tue May 14 13:30:14 2024 user.info kernel: [ 8.919789] init: - preinit -
Tue May 14 13:30:14 2024 kern.notice kernel: [ 11.429204] random: jshn: uninitialized urandom r
ead (4 bytes read)
Tue May 14 13:30:14 2024 kern.notice kernel: [ 11.552690] random: jshn: uninitialized urandom r
ead (4 bytes read)
Tue May 14 13:30:14 2024 user.info kernel: [ 11.888071] mount_root: loading kmods from internal
overlay
Tue May 14 13:30:14 2024 user.info kernel: [ 12.026328] kmodloader: loading kernel modules from
//etc/modules-boot.d/*
Tue May 14 13:30:14 2024 user.info kernel: [ 12.041053] kmodloader: done loading kernel modules
from //etc/modules-boot.d/*
Tue May 14 13:30:14 2024 kern.notice kernel: [ 12.860365] jffs2: notice: (648) jffs2_build_xatt
r_subsystem: complete building xattr subsystem, 77 of xdatum (58 unchecked, 19 orphan) and 94 of
xref (7 dead, 18 orphan) found.
Tue May 14 13:30:14 2024 user.info kernel: [ 12.877274] block: attempting to load /tmp/jffs_cfg
/upper/etc/config/fstab
Tue May 14 13:30:14 2024 user.info kernel: [ 12.902715] block: extroot: not configured
Tue May 14 13:30:14 2024 kern.notice kernel: [ 13.003114] jffs2: notice: (646) jffs2_build_xatt
Tue May 14 13:30:14 2024 user.info kernel: [ 13.556206] block: attempting to load /tmp/jffs_cfg
Tue May 14 13:30:14 2024 user.info kernel: [ 13.581700] block: extroot: not configured
Tue May 14 13:30:14 2024 user.info kernel: [ 13.587574] mount_root: switching to jffs2 overlay
Tue May 14 13:30:14 2024 kern.warn kernel: [ 13.598440] overlayfs: upper fs does not support tm
pfile.
Tue May 14 13:30:14 2024 user.warn kernel: [ 13.610328] urandom-seed: Seeding with /etc/urandom
.seed
Tue May 14 13:30:14 2024 kern.notice kernel: [ 13.749434] random: mctl: uninitialized urandom r
ead (4 bytes read)
Tue May 14 13:30:14 2024 user.warn kernel: [ 15.084801] - preparing events-log partition -
Tue May 14 13:30:14 2024 user.warn kernel: [ 15.196028] Unlocking /dev/mtd7 …
Tue May 14 13:30:14 2024 kern.notice kernel: [ 15.295733] jffs2: notice: (661) jffs2_build_xatt
r_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref
(0 dead, 0 orphan) found.
Tue May 14 13:30:14 2024 user.info kernel: [ 15.376910] procd: - early -
Tue May 14 13:30:14 2024 user.info kernel: [ 15.380323] procd: - watchdog -
Tue May 14 13:30:14 2024 user.warn kernel: [ 16.002500] [01-serial-symlink.sh] New device ttyS0
at /devices/platform/ahb/ahb:apb/18020000.uart/tty/ttyS0 appeared!
Tue May 14 13:30:14 2024 kern.notice kernel: [ 16.040274] random: jsonfilter: uninitialized ura
ndom read (4 bytes read)
Tue May 14 13:30:14 2024 kern.notice kernel: [ 16.060193] random: jsonfilter: uninitialized ura
Tue May 14 13:30:14 2024 kern.notice kernel: [ 16.080412] random: jsonfilter: uninitialized ura
Tue May 14 13:30:14 2024 user.info kernel: [ 16.087640] procd: - watchdog -
Tue May 14 13:30:14 2024 user.info kernel: [ 16.095561] procd: - ubus -
Tue May 14 13:30:14 2024 user.info kernel: [ 16.279029] procd: - init -
Tue May 14 13:30:14 2024 user.warn kernel: [ 16.411970] [01-serial-symlink.sh] New device ttyAT
H1 at /devices/platform/ahb/ahb:apb/18500000.uart/tty/ttyATH1 appeared!
Tue May 14 13:30:14 2024 user.warn kernel: [ 16.656378] [01-serial-symlink.sh] Creating /dev/tt
yATH1 → /dev/rs485 symlink…
Tue May 14 13:30:14 2024 kern.notice kernel: [ 17.999769] random: jshn: uninitialized urandom r
ead (4 bytes read)
Tue May 14 13:30:14 2024 kern.notice kernel: [ 18.038321] random: ubusd: uninitialized urandom
read (4 bytes read)
Tue May 14 13:30:14 2024 kern.notice kernel: [ 18.045244] random: ubus: uninitialized urandom r
ead (4 bytes read)
Tue May 14 13:30:14 2024 user.info kernel: [ 18.991094] urngd: v1.0.2 started.
Tue May 14 13:30:14 2024 kern.notice kernel: [ 19.297246] random: jsonfilter: uninitialized ura
Tue May 14 13:30:14 2024 kern.notice kernel: [ 19.352258] random: crng init done
Tue May 14 13:30:14 2024 kern.notice kernel: [ 19.355773] random: 37 urandom warning(s) missed
due to ratelimiting
Tue May 14 13:30:14 2024 user.info kernel: [ 20.174826] kmodloader: loading kernel modules from
/etc/modules.d/*
Tue May 14 13:30:14 2024 kern.info kernel: [ 20.385634] ntfs: driver 2.1.32 [Flags: R/O MODULE]
Tue May 14 13:30:14 2024 kern.info kernel: [ 20.411570] NET: Registered protocol family 15
Tue May 14 13:30:14 2024 kern.info kernel: [ 20.423467] Initializing XFRM netlink socket
Tue May 14 13:30:14 2024 kern.info kernel: [ 20.433564] tun: Universal TUN/TAP device driver, 1
.6
Tue May 14 13:30:14 2024 kern.info kernel: [ 20.524469] l2tp_core: L2TP core driver, V2.0
Tue May 14 13:30:14 2024 kern.info kernel: [ 20.536805] l2tp_netlink: L2TP netlink interface
Tue May 14 13:30:14 2024 kern.info kernel: [ 20.553721] sit: IPv6, IPv4 and MPLS over IPv4 tunn
eling driver
Tue May 14 13:30:14 2024 kern.info kernel: [ 20.577342] l2tp_eth: L2TP ethernet pseudowire supp
ort (L2TPv3)
Tue May 14 13:30:14 2024 kern.info kernel: [ 20.596082] l2tp_ip: L2TP IP encapsulation support
(L2TPv3)
Tue May 14 13:30:14 2024 kern.info kernel: [ 20.624763] l2tp_ip6: L2TP IP encapsulation support
for IPv6 (L2TPv3)
Tue May 14 13:30:14 2024 kern.info kernel: [ 20.641258] gre: GRE over IPv4 demultiplexor driver
Tue May 14 13:30:14 2024 kern.info kernel: [ 20.665469] ip_gre: GRE over IPv4 tunneling driver
Tue May 14 13:30:14 2024 kern.info kernel: [ 20.709894] ip6_gre: GRE over IPv6 tunneling driver
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.090216] tlt-gpio: set names for 18040000.gpio c
hip
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.096752] tlt-gpio: set names for 74hc595 chip
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.117518] GACT probability on
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.136321] Mirror/redirect action on
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.184657] u32 classifier
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.187477] input device check on
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.191219] Actions configured
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.251879] fuse: init (API version 7.31)
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.281628] usbcore: registered new interface drive
r usbserial_generic
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.288425] usbserial: USB Serial support registere
d for generic
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.324632] usbcore: registered new interface drive
r cypress_reconf
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.331187] usbcore: registered new interface drive
r cypress_serial
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.337693] usbserial: USB Serial support registere
d for CY7C65213
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.344100] cypress_serial 1-1.3:1.0: CY7C65213 con
verter detected
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.438564] usb 1-1.3: CY7C65213 converter now atta
ched to ttyUSB0
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.540505] usbcore: registered new interface drive
r ark3116
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.546436] usbserial: USB Serial support registere
d for ark3116
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.577907] usbcore: registered new interface drive
r belkin_sa
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.584029] usbserial: USB Serial support registere
d for Belkin / Peracom / GoHubs USB Serial Adapter
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.618576] usbcore: registered new interface drive
r cdc_acm
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.624382] cdc_acm: USB Abstract Control Model dri
ver for USB modems and ISDN adapters
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.657367] usbcore: registered new interface drive
r cdc_wdm
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.676062] usbcore: registered new interface drive
r ch341
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.681816] usbserial: USB Serial support registere
d for ch341-uart
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.718515] usbcore: registered new interface drive
r usb_ch343
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.724490] ch343: USB serial driver for ch342/ch34
3/ch344/ch347/ch9101/ch9102/ch9103/ch9104, etc.
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.733595] ch343: V1.5 On 2022.12
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.772030] Loading modules backported from Linux v
ersion v5.10.68-0-g4d8524048a35
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.779787] Backport generated by backports.git v5.
10.68-1-0-ga4f9ba32
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.800045] usbcore: registered new interface drive
r cp210x
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.805889] usbserial: USB Serial support registere
d for cp210x
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.854558] usbcore: registered new interface drive
r cypress_m8
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.860758] usbserial: USB Serial support registere
d for DeLorme Earthmate USB
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.868245] usbserial: USB Serial support registere
d for HID->COM RS232 Adapter
Tue May 14 13:30:14 2024 kern.info kernel: [ 21.875812] usbserial: USB Serial support registere
d for Nokia CA-42 V2 Adapter
Tue May 14 13:30:14 2024 kern.info kernel: [ 22.091539] usbcore: registered new interface drive
r ftdi_sio
Tue May 14 13:30:14 2024 kern.info kernel: [ 22.097580] usbserial: USB Serial support registere
d for FTDI USB Serial Device
Tue May 14 13:30:14 2024 kern.info kernel: [ 22.170420] mcp3021 0-004d: Found ADC: MCP3021
Tue May 14 13:30:14 2024 kern.info kernel: [ 22.314551] usbcore: registered new interface drive
r pl2303
Tue May 14 13:30:14 2024 kern.info kernel: [ 22.320395] usbserial: USB Serial support registere
d for pl2303
Tue May 14 13:30:14 2024 kern.info kernel: [ 22.418570] usbcore: registered new interface drive
r usblp
Tue May 14 13:30:14 2024 kern.info kernel: [ 22.645502] xt_time: kernel timezone is -0000
Tue May 14 13:30:14 2024 kern.info kernel: [ 23.537758] usbcore: registered new interface drive
r option
Tue May 14 13:30:14 2024 kern.info kernel: [ 23.543638] usbserial: USB Serial support registere
d for GSM modem (1-port)
Tue May 14 13:30:14 2024 kern.info kernel: [ 23.630118] PPP generic driver version 2.4.2
Tue May 14 13:30:14 2024 kern.info kernel: [ 23.651498] PPP MPPE Compression module registered
Tue May 14 13:30:14 2024 kern.info kernel: [ 23.676632] NET: Registered protocol family 24
Tue May 14 13:30:14 2024 kern.info kernel: [ 23.704260] PPTP driver version 0.8.5
Tue May 14 13:30:14 2024 kern.info kernel: [ 23.750693] usbcore: registered new interface drive
r qmi_wwan
Tue May 14 13:30:14 2024 kern.info kernel: [ 23.779620] wireguard: WireGuard 1.0.0 loaded. See
www.wireguard.com for information.
Tue May 14 13:30:14 2024 kern.info kernel: [ 23.787644] wireguard: Copyright (C) 2015-2019 Jaso
n A. Donenfeld Jason@zx2c4.com. All Rights Reserved.
Tue May 14 13:30:14 2024 kern.info kernel: [ 24.070431] l2tp_ppp: PPPoL2TP kernel driver, V2.0
Tue May 14 13:30:14 2024 kern.debug kernel: [ 24.149278] ath: EEPROM regdomain sanitized
Tue May 14 13:30:14 2024 kern.debug kernel: [ 24.149291] ath: EEPROM regdomain: 0x64
Tue May 14 13:30:14 2024 kern.debug kernel: [ 24.149296] ath: EEPROM indicates we should expect
a direct regpair map
Tue May 14 13:30:14 2024 kern.debug kernel: [ 24.149323] ath: Country alpha2 being used: 00
Tue May 14 13:30:14 2024 kern.debug kernel: [ 24.149328] ath: Regpair used: 0x64
Tue May 14 13:30:14 2024 kern.debug kernel: [ 24.163291] ieee80211 phy0: Selected rate control
algorithm ‘minstrel_ht’
Tue May 14 13:30:14 2024 kern.info kernel: [ 24.166115] ieee80211 phy0: Atheros AR9340 Rev:3 me
m=0xb8100000, irq=13
Tue May 14 13:30:14 2024 user.info kernel: [ 24.205689] kmodloader: done loading kernel modules
from /etc/modules.d/*
Tue May 14 13:30:14 2024 user.warn kernel: [ 24.247257] [01-serial-symlink.sh] New device ttyUS
B0 at /devices/platform/ahb/1b000000.usb/usb1/1-1/1-1.3/1-1.3:1.0/ttyUSB0/tty/ttyUSB0 appeared!
Tue May 14 13:30:14 2024 user.warn kernel: [ 24.432130] [01-serial-symlink.sh] Creating /dev/tt
yUSB0 → /dev/rs232 symlink…
Tue May 14 13:30:14 2024 kern.info kernel: [ 27.262196] usb 1-1.4: new high-speed USB device nu
mber 4 using ehci-platform
Tue May 14 13:30:14 2024 kern.info kernel: [ 27.400978] option 1-1.4:1.0: GSM modem (1-port) co
nverter detected
Tue May 14 13:30:14 2024 kern.info kernel: [ 27.407819] usb 1-1.4: GSM modem (1-port) converter
now attached to ttyUSB1
Tue May 14 13:30:14 2024 kern.info kernel: [ 27.416091] option 1-1.4:1.1: GSM modem (1-port) co
nverter detected
Tue May 14 13:30:14 2024 kern.info kernel: [ 27.422893] usb 1-1.4: GSM modem (1-port) converter
now attached to ttyUSB2
Tue May 14 13:30:14 2024 kern.info kernel: [ 27.431197] option 1-1.4:1.2: GSM modem (1-port) co
nverter detected
Tue May 14 13:30:14 2024 kern.info kernel: [ 27.437988] usb 1-1.4: GSM modem (1-port) converter
now attached to ttyUSB3
Tue May 14 13:30:14 2024 kern.info kernel: [ 27.446345] option 1-1.4:1.3: GSM modem (1-port) co
nverter detected
Tue May 14 13:30:14 2024 kern.info kernel: [ 27.453136] usb 1-1.4: GSM modem (1-port) converter
now attached to ttyUSB4
Tue May 14 13:30:14 2024 kern.info kernel: [ 27.598538] qmi_wwan 1-1.4:1.4: cdc-wdm0: USB WDM d
evice
Tue May 14 13:30:14 2024 kern.info kernel: [ 27.618623] qmi_wwan 1-1.4:1.4 wwan0: register ‘qmi
_wwan’ at usb-1b000000.usb-1.4, WWAN/QMI device, ce:21:81:d7:ae:c7
Tue May 14 13:30:14 2024 user.warn kernel: [ 28.100798] [01-serial-symlink.sh] New device ttyUS
B1 at /devices/platform/ahb/1b000000.usb/usb1/1-1/1-1.4/1-1.4:1.0/ttyUSB1/tty/ttyUSB1 appeared!
Tue May 14 13:30:14 2024 user.warn kernel: [ 29.247333] [01-serial-symlink.sh] New device ttyUS
B2 at /devices/platform/ahb/1b000000.usb/usb1/1-1/1-1.4/1-1.4:1.1/ttyUSB2/tty/ttyUSB2 appeared!
Tue May 14 13:30:14 2024 user.warn kernel: [ 30.254568] [01-serial-symlink.sh] New device ttyUS
B3 at /devices/platform/ahb/1b000000.usb/usb1/1-1/1-1.4/1-1.4:1.2/ttyUSB3/tty/ttyUSB3 appeared!
Tue May 14 13:30:15 2024 user.warn kernel: [ 32.057676] [01-serial-symlink.sh] New device ttyUS
B4 at /devices/platform/ahb/1b000000.usb/usb1/1-1/1-1.4/1-1.4:1.3/ttyUSB4/tty/ttyUSB4 appeared!
Tue May 14 13:30:19 2024 user.notice : Added device handler type: bonding
Tue May 14 13:30:19 2024 user.notice : Added device handler type: 8021ad
Tue May 14 13:30:19 2024 user.notice : Added device handler type: 8021q
Tue May 14 13:30:19 2024 user.notice : Added device handler type: macvlan
Tue May 14 13:30:19 2024 user.notice : Added device handler type: veth
Tue May 14 13:30:19 2024 user.notice : Added device handler type: bridge
Tue May 14 13:30:19 2024 user.notice : Added device handler type: Network device
Tue May 14 13:30:19 2024 user.notice : Added device handler type: tunnel
Tue May 14 13:30:22 2024 user.notice dnsmasq: DNS rebinding protection is active, will discard up
stream RFC1918 responses!
Tue May 14 13:30:22 2024 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Tue May 14 13:30:23 2024 daemon.info dnsmasq[2154]: started, version 2.89 cachesize 150
Tue May 14 13:30:23 2024 daemon.info dnsmasq[2154]: compile time options: IPv6 GNU-getopt no-DBus
UBus no-i18n no-regex no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-nftset no-auth
no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Tue May 14 13:30:23 2024 daemon.info dnsmasq[2154]: UBus support enabled: connected to system bus
Tue May 14 13:30:23 2024 daemon.info dnsmasq[2154]: using only locally-known addresses for test
Tue May 14 13:30:23 2024 daemon.info dnsmasq[2154]: using only locally-known addresses for onion
Tue May 14 13:30:23 2024 daemon.info dnsmasq[2154]: using only locally-known addresses for localh
ost
Tue May 14 13:30:23 2024 daemon.info dnsmasq[2154]: using only locally-known addresses for invali
d
Tue May 14 13:30:23 2024 daemon.info dnsmasq[2154]: using only locally-known addresses for bind
Tue May 14 13:30:23 2024 daemon.info dnsmasq[2154]: using only locally-known addresses for lan
Tue May 14 13:30:23 2024 daemon.warn dnsmasq[2154]: no servers found in /tmp/resolv.conf.d/resolv
.conf.auto, will retry
Tue May 14 13:30:23 2024 daemon.info dnsmasq[2154]: read /etc/hosts - 12 names
Tue May 14 13:30:23 2024 daemon.info dnsmasq[2154]: read /tmp/hosts/dhcp.cfg01411c - 0 names
Tue May 14 13:30:29 2024 daemon.notice wpa_supplicant[2209]: Successfully initialized wpa_supplic
ant
Tue May 14 13:30:30 2024 daemon.info gsmd[2326]: gsmd-ng init
Tue May 14 13:30:30 2024 daemon.info gsmd[2326]: gsmd-ng canary build git#eaf37eeff60
Tue May 14 13:30:30 2024 daemon.info gsmd[2326]: AT traffic support: yes
Tue May 14 13:30:30 2024 daemon.info gsmd[2326]: Baseband feature support: no
Tue May 14 13:30:30 2024 daemon.info gsmd[2326]: gsmd-ng running
Tue May 14 13:30:32 2024 daemon.notice procd: /etc/rc.d/S13openssl: Generating engines.cnf
Tue May 14 13:30:32 2024 daemon.notice procd: /etc/rc.d/S13openssl: Generating providers.cnf
Tue May 14 13:30:32 2024 daemon.err mobifd: Failed to get information about modems
Tue May 14 13:30:33 2024 daemon.notice procd: /etc/rc.d/S13openssl: Enabling legacy
Tue May 14 13:30:35 2024 daemon.info gsmd[2326]: [ubus_notify_event:299] error: [MODEM_UBUS] Fail
ed to send ubus notify for 1-1.4 [2c7c:0125] modem!
Tue May 14 13:30:35 2024 daemon.info mobifd: [gsm.modem0] Starting modem settings init
Tue May 14 13:30:35 2024 daemon.info mobifd: [gsm.modem0] SIM is ready
Tue May 14 13:30:36 2024 daemon.err mobifd: [gsm.modem0] GSM error in “mb_check_sms_storage:526”
(Failed to parse response), gsmd_method_id: “63”
Tue May 14 13:30:36 2024 daemon.err mobifd: [gsm.modem0] Failed to get SMS storage
Tue May 14 13:30:41 2024 daemon.info mobifd: [gsm.modem0] Modem settings init completed
Tue May 14 13:30:41 2024 daemon.info mobifd: [gsm.modem0] Starting connection setup
Tue May 14 13:30:42 2024 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to o
perator with “15s” of timeout
Tue May 14 13:30:42 2024 daemon.info mobifd: [gsm.modem0] Connected to operator “KPN KPN”
Tue May 14 13:30:42 2024 daemon.info mobifd: [gsm.modem0] -CFUN- Functionality: “Full”
Tue May 14 13:30:42 2024 daemon.info mobifd: [gsm.modem0] -COPS- Mode: “Auto”, operator: "KPN KPN
Tue May 14 13:30:42 2024 daemon.info mobifd: [gsm.modem0] -CREG- Mode: “Enabled (with location in
formation)”, status: “Registered, home”, LAC: “33001”, cell ID: “7411489”, technology: “E-UTRAN”
Tue May 14 13:30:42 2024 daemon.info mobifd: [gsm.modem0] -CGREG- Mode: “Enabled (with location i
nformation)”, status: “Registered, home”, LAC: “33001”, cell ID: “7411489”, technology: “E-UTRAN”
Tue May 14 13:30:42 2024 daemon.info mobifd: [gsm.modem0] -CEREG- Mode: “Enabled (with location i
Tue May 14 13:30:42 2024 daemon.info mobifd: [gsm.modem0] IP address on PDP context “1”: “100.94.
188.248”
Tue May 14 13:30:44 2024 authpriv.info dropbear[2754]: Not backgrounding
Tue May 14 13:30:50 2024 kern.info kernel: [ 66.682312] eth0: link up (1000Mbps/Full duplex)
Tue May 14 13:30:50 2024 kern.info kernel: [ 66.703916] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: li
nk becomes ready
Tue May 14 13:30:50 2024 kern.info kernel: [ 66.715811] br-lan: port 1(eth0.1) entered blocking
state
Tue May 14 13:30:50 2024 kern.info kernel: [ 66.721380] br-lan: port 1(eth0.1) entered disabled
state
Tue May 14 13:30:50 2024 kern.info kernel: [ 66.727469] device eth0.1 entered promiscuous mode
Tue May 14 13:30:50 2024 kern.info kernel: [ 66.732396] device eth0 entered promiscuous mode
Tue May 14 13:30:50 2024 kern.info kernel: [ 66.784782] br-lan: port 1(eth0.1) entered blocking
state
Tue May 14 13:30:50 2024 kern.info kernel: [ 66.790354] br-lan: port 1(eth0.1) entered forwardi
ng state
Tue May 14 13:30:50 2024 daemon.notice netifd: Interface ‘lan’ is enabled
Tue May 14 13:30:50 2024 daemon.notice netifd: Interface ‘lan’ is setting up now
Tue May 14 13:30:50 2024 daemon.notice netifd: Interface ‘lan’ is now up
Tue May 14 13:30:50 2024 daemon.notice netifd: bridge ‘br-lan’ link is up
Tue May 14 13:30:50 2024 daemon.notice netifd: Interface ‘lan’ has link connectivity
Tue May 14 13:30:50 2024 daemon.notice netifd: Interface ‘loopback’ is enabled
Tue May 14 13:30:50 2024 daemon.notice netifd: Interface ‘loopback’ is setting up now
Tue May 14 13:30:50 2024 daemon.notice netifd: Interface ‘loopback’ is now up
Tue May 14 13:30:50 2024 daemon.notice netifd: Interface ‘wan’ is enabled
Tue May 14 13:30:50 2024 daemon.notice netifd: Interface ‘wan6’ is enabled
Tue May 14 13:30:50 2024 daemon.notice netifd: VLAN ‘eth0.1’ link is up
Tue May 14 13:30:50 2024 daemon.notice netifd: Interface ‘mob1s1a1’ is setting up now
Tue May 14 13:30:50 2024 daemon.notice netifd: bridge ‘br-lan’ link is down
Tue May 14 13:30:50 2024 daemon.notice netifd: Interface ‘lan’ has link connectivity loss
Tue May 14 13:30:50 2024 daemon.notice netifd: VLAN ‘eth0.1’ link is down
Tue May 14 13:30:50 2024 daemon.notice netifd: Network device ‘eth0’ link is up
Tue May 14 13:30:50 2024 daemon.notice netifd: Network device ‘lo’ link is up
Tue May 14 13:30:50 2024 daemon.notice netifd: Interface ‘loopback’ has link connectivity
Tue May 14 13:30:51 2024 kern.info kernel: [ 67.686144] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan:
link becomes ready
Tue May 14 13:30:52 2024 daemon.notice netifd: radio0 (2935): WARNING: Variable ‘data’ does not e
xist or is not an array/object
Tue May 14 13:30:53 2024 daemon.notice netifd: mob1s1a1 (2940): wwan[2940] Using wwan usb device
on bus 1-1.4
Tue May 14 13:30:54 2024 daemon.notice netifd: mob1s1a1 (2940): wwan[2940] Using proto:qmux devic
e:/dev/cdc-wdm0 iface:wwan0 desc:Quectel EC25
Tue May 14 13:30:57 2024 daemon.notice netifd: mob1s1a1 (2940): Quering active sim position
Tue May 14 13:30:57 2024 kern.debug kernel: [ 74.362263] ath: EEPROM regdomain: 0x8348
Tue May 14 13:30:57 2024 kern.debug kernel: [ 74.362273] ath: EEPROM indicates we should expect
a country code
Tue May 14 13:30:57 2024 kern.debug kernel: [ 74.362283] ath: doing EEPROM country->regdmn map
search
Tue May 14 13:30:57 2024 kern.debug kernel: [ 74.362291] ath: country maps to regdmn code: 0x3a
Tue May 14 13:30:57 2024 kern.debug kernel: [ 74.362298] ath: Country alpha2 being used: US
Tue May 14 13:30:57 2024 kern.debug kernel: [ 74.362303] ath: Regpair used: 0x3a
Tue May 14 13:30:57 2024 kern.debug kernel: [ 74.362312] ath: regdomain 0x8348 dynamically upda
ted by user
Tue May 14 13:30:58 2024 daemon.notice netifd: mob1s1a1 (2940): Calculated qmimux ifname: qmimux0
Tue May 14 13:30:59 2024 daemon.notice hostapd: Set new config for phy phy0:
Tue May 14 13:30:59 2024 daemon.notice wpa_supplicant[2209]: Set new config for phy phy0
Tue May 14 13:30:59 2024 user.notice root: uqmi -d /dev/cdc-wdm0 --timeout 6000 --wda-set-data-fo
rmat --link-layer-protocol raw-ip --ul-protocol qmap --dl-protocol qmap --dl-max-datagrams 16 --d
l-datagram-max-size 4096 --ul-max-datagrams 11 --ul-datagram-max-size 4096 --dl-min-padding 0
Tue May 14 13:31:00 2024 daemon.notice netifd: mob1s1a1 (2940): Starting network mob1s1a1 using A
PN: internet.mvno.mobi
Tue May 14 13:31:01 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id
wds,17 --release-client-id wds --modify-profile --profile-identifier 3gpp,1 --profile-name profi
le1 --roaming-disallowed-flag no --username mvno --password mvno --auth-type pap --apn intern
et.mvno.mobi --pdp-type ipv4v6
Tue May 14 13:31:02 2024 daemon.notice wpa_supplicant[2209]: Set new config for phy phy0
Tue May 14 13:31:02 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --get-client-id
wds
Tue May 14 13:31:03 2024 daemon.notice hostapd: Set new config for phy phy0: /var/run/hostapd-phy
0.conf
Tue May 14 13:31:03 2024 daemon.notice hostapd: Restart interface for phy phy0
Tue May 14 13:31:03 2024 daemon.notice netifd: mob1s1a1 (2940): 17
Tue May 14 13:31:03 2024 daemon.notice netifd: mob1s1a1 (2940): cid4: 17
Tue May 14 13:31:03 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --wds-bind-mux-
data-port --mux-id 1 --ep-iface-number 4 --set-client-id wds,17
Tue May 14 13:31:04 2024 daemon.info dnsmasq[2154]: exiting on receipt of SIGTERM
Tue May 14 13:31:04 2024 daemon.info dnsmasq[3583]: started, version 2.89 cachesize 150
Tue May 14 13:31:04 2024 daemon.info dnsmasq[3583]: compile time options: IPv6 GNU-getopt no-DBus
Tue May 14 13:31:04 2024 daemon.info dnsmasq[3583]: UBus support enabled: connected to system bus
Tue May 14 13:31:04 2024 daemon.info dnsmasq-dhcp[3583]: DHCP, IP range 192.168.2.100 – 192.168.
2.254, lease time 12h
Tue May 14 13:31:04 2024 daemon.info dnsmasq[3583]: using only locally-known addresses for test
Tue May 14 13:31:04 2024 daemon.info dnsmasq[3583]: using only locally-known addresses for onion
Tue May 14 13:31:04 2024 daemon.info dnsmasq[3583]: using only locally-known addresses for localh
ost
Tue May 14 13:31:04 2024 daemon.info dnsmasq[3583]: using only locally-known addresses for invali
d
Tue May 14 13:31:04 2024 daemon.info dnsmasq[3583]: using only locally-known addresses for bind
Tue May 14 13:31:04 2024 daemon.info dnsmasq[3583]: using only locally-known addresses for lan
Tue May 14 13:31:04 2024 daemon.warn dnsmasq[3583]: no servers found in /tmp/resolv.conf.d/resolv
Tue May 14 13:31:04 2024 daemon.info dnsmasq[3583]: read /etc/hosts - 12 names
Tue May 14 13:31:04 2024 daemon.info dnsmasq[3583]: read /tmp/hosts/dhcp.cfg01411c - 4 names
Tue May 14 13:31:04 2024 daemon.info dnsmasq-dhcp[3583]: read /etc/ethers - 0 addresses
Tue May 14 13:31:04 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-ip-family
ipv4 --set-client-id wds,17
Tue May 14 13:31:05 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id
wds,17 --start-network --apn internet.mvno.mobi --profile 1 --auth-type pap --username mvno --p
assword mvno
Tue May 14 13:31:06 2024 daemon.notice netifd: mob1s1a1 (2940): pdh4: -2026141888
Tue May 14 13:31:06 2024 daemon.notice hostapd: Configuration file: data: driver=nl80211 logger_s
yslog=127 logger_syslog_level=2 logger_stdout=127 logger_stdout_level=2 country_code=US ieee80211
d=1 hw_mode=g supported_rates=60 90 120 180 240 360 480 540 basic_rates=60 120 240 beacon_int=100
dtim_period=2 #num_global_macaddr=1 ieee80211n=1 ht_coex=0 ht_capab=[LDPC][SHORT-GI-20][SHORT-GI
-40][TX-STBC][RX-STBC1][DSSS_CCK-40] channel=acs_survey interface=wlan0 bssid=00:1e:42:3c:5a:de
ctrl_interface=/var/run/hostapd ap_isolate=1 bss_load_update_period=60 chan_util_avg_period=600 d
isassoc_low_ack=1 skip_inactivity_poll=0 preamble=1 wmm_enabled=1 ignore_broadcast_ssid=0 uapsd_a
dvertisement_enabled=1 utf8_ssid=1 multi_ap=0 wpa_passphrase=x1S2Mji4 wpa_psk_file=/etc/hostapd/w
lan0.psk auth_algs=1 wpa=2 wpa_pairwise=CCMP ssid=RUT955_5ADE bridge=br-lan wpa_disable_eapol_key
_retries=0 wpa_key_mgmt=WPA-PSK okc=0 disable_pmksa_caching=1 dynamic_vlan=0 vlan_naming=1 vlan_f
ile=/var/run/hostapd-wlan0.vlan config_id=a408d515513c55428c4ef26bcb1055
Tue May 14 13:31:06 2024 daemon.notice netifd: mob1s1a1 (2940): -2026141888
Tue May 14 13:31:06 2024 kern.info kernel: [ 83.099827] br-lan: port 2(wlan0) entered blocking
state
Tue May 14 13:31:06 2024 kern.info kernel: [ 83.105297] br-lan: port 2(wlan0) entered disabled
state
Tue May 14 13:31:06 2024 kern.info kernel: [ 83.111146] device wlan0 entered promiscuous mode
Tue May 14 13:31:06 2024 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->COUNTRY_UPD
ATE
Tue May 14 13:31:06 2024 daemon.notice hostapd: ACS: Automatic channel selection started, this ma
y take a bit
Tue May 14 13:31:06 2024 daemon.notice hostapd: wlan0: interface state COUNTRY_UPDATE->ACS
Tue May 14 13:31:06 2024 daemon.notice hostapd: wlan0: ACS-STARTED
Tue May 14 13:31:07 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --get-client-id
wds
Tue May 14 13:31:08 2024 daemon.notice netifd: mob1s1a1 (2940): 18
Tue May 14 13:31:08 2024 daemon.notice netifd: mob1s1a1 (2940): cid6: 18
Tue May 14 13:31:08 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --wds-bind-mux-
data-port --mux-id 1 --ep-iface-number 4 --set-client-id wds,18
Tue May 14 13:31:08 2024 daemon.notice netifd: Wireless device ‘radio0’ is now up
Tue May 14 13:31:09 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-ip-family
ipv6 --set-client-id wds,18
Tue May 14 13:31:11 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id
wds,18 --start-network --apn internet.mvno.mobi --profile 1 --auth-type pap --username mvno --p
assword mvno
Tue May 14 13:31:12 2024 user.notice mobile.sh: QMI call error, reason type INTERNAL: “PDN IPv6 c
all disallowed” “Call failed”
Tue May 14 13:31:12 2024 daemon.notice netifd: mob1s1a1 (2940): pdh6: QMI call error, reason type
INTERNAL: “PDN IPv6 call disallowed”
Tue May 14 13:31:12 2024 daemon.notice netifd: mob1s1a1 (2940): “Call failed”
Tue May 14 13:31:12 2024 daemon.notice netifd: mob1s1a1 (2940): Unable to connect IPv6
Tue May 14 13:31:12 2024 daemon.notice netifd: mob1s1a1 (2940): Releasing client-id 18 on /dev/cd
c-wdm0
Tue May 14 13:31:13 2024 user.notice netifd: uqmi -d /dev/cdc-wdm0 --timeout 6000 --set-client-id
wds,18 --release-client-id wds
Tue May 14 13:31:13 2024 daemon.notice hostapd: wlan0: ACS-COMPLETED freq=2457 channel=10
Tue May 14 13:31:13 2024 user.notice mwan3-hotplug[2934]: mwan3 hotplug on lan not called because
interface disabled
Tue May 14 13:31:14 2024 daemon.notice netifd: mob1s1a1 (2940): Setting up qmimux0
Tue May 14 13:31:14 2024 daemon.notice netifd: mob1s1a1 (2940): Setting dynamic MTU: 1500 on qmim
ux0
Tue May 14 13:31:14 2024 kern.info kernel: [ 91.275851] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: l
ink becomes ready
Tue May 14 13:31:14 2024 kern.info kernel: [ 91.282672] br-lan: port 2(wlan0) entered blocking
state
Tue May 14 13:31:14 2024 kern.info kernel: [ 91.288140] br-lan: port 2(wlan0) entered forwardin
g state
Tue May 14 13:31:14 2024 daemon.notice netifd: Network device ‘wlan0’ link is up
Tue May 14 13:31:15 2024 daemon.notice hostapd: wlan0: interface state ACS->ENABLED
Tue May 14 13:31:15 2024 daemon.notice hostapd: wlan0: AP-ENABLED
Tue May 14 13:31:15 2024 daemon.notice netifd: Interface ‘mob1s1a1’ is now up
Tue May 14 13:31:15 2024 daemon.info dnsmasq[3583]: reading /tmp/resolv.conf.d/resolv.conf.auto
Tue May 14 13:31:15 2024 daemon.info dnsmasq[3583]: using nameserver 8.8.8.8#53
Tue May 14 13:31:15 2024 daemon.info dnsmasq[3583]: using nameserver 4.4.4.4#53
Tue May 14 13:31:15 2024 daemon.info dnsmasq[3583]: using only locally-known addresses for test
Tue May 14 13:31:15 2024 daemon.info dnsmasq[3583]: using only locally-known addresses for onion
Tue May 14 13:31:15 2024 daemon.info dnsmasq[3583]: using only locally-known addresses for localh
ost
Tue May 14 13:31:15 2024 daemon.notice netifd: Network device ‘wwan0’ link is up
Tue May 14 13:31:15 2024 daemon.info dnsmasq[3583]: using only locally-known addresses for invali
d
Tue May 14 13:31:15 2024 daemon.info dnsmasq[3583]: using only locally-known addresses for bind
Tue May 14 13:31:15 2024 daemon.info dnsmasq[3583]: using only locally-known addresses for lan
Tue May 14 13:31:15 2024 daemon.notice netifd: mob1s1a1 (2940): Setting up qmimux0 V4 DCHP
Tue May 14 13:31:15 2024 daemon.notice netifd: Interface ‘mob1s1a1_4’ is enabled
Tue May 14 13:31:16 2024 daemon.notice netifd: Network device ‘qmimux0’ link is up
Tue May 14 13:31:16 2024 daemon.notice netifd: Interface ‘mob1s1a1_4’ has link connectivity
Tue May 14 13:31:16 2024 daemon.notice netifd: Interface ‘mob1s1a1_4’ is setting up now
Tue May 14 13:31:16 2024 kern.notice Port link state of port CPU/WiFi changed to UP
Tue May 14 13:31:16 2024 kern.notice Port speed for port CPU/WiFi changed to 1000 baseT
Tue May 14 13:31:16 2024 kern.notice Port link state of port LAN1 changed to UP
Tue May 14 13:31:16 2024 kern.notice Port speed for port LAN1 changed to 100 baseT
Tue May 14 13:31:17 2024 daemon.notice netifd: mob1s1a1_4 (4268): udhcpc: started, v1.34.1
Tue May 14 13:31:18 2024 daemon.notice netifd: mob1s1a1_4 (4268): udhcpc: broadcasting discover
Tue May 14 13:31:18 2024 daemon.notice netifd: mob1s1a1_4 (4268): udhcpc: broadcasting select for
100.94.188.248, server 100.94.188.249
Tue May 14 13:31:18 2024 daemon.notice netifd: mob1s1a1_4 (4268): udhcpc: lease of 100.94.188.248
obtained from 100.94.188.249, lease time 7200
Tue May 14 13:31:19 2024 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Tue May 14 13:31:20 2024 daemon.info mobifd: Auto APN is disabled for ‘mob1s1a1’. Skipping Ping T
o DNS functionality
Tue May 14 13:31:20 2024 daemon.notice netifd: Interface ‘mob1s1a1_4’ is now up
Tue May 14 13:31:20 2024 daemon.info mobifd: Connection setup completed for ‘mob1s1a1’
Tue May 14 13:31:20 2024 daemon.info dnsmasq[3583]: reading /tmp/resolv.conf.d/resolv.conf.auto
Tue May 14 13:31:20 2024 daemon.info dnsmasq[3583]: using nameserver 8.8.8.8#53
Tue May 14 13:31:20 2024 daemon.info dnsmasq[3583]: using nameserver 4.4.4.4#53
Tue May 14 13:31:20 2024 daemon.info dnsmasq[3583]: using only locally-known addresses for test
Tue May 14 13:31:20 2024 daemon.info dnsmasq[3583]: using only locally-known addresses for onion
Tue May 14 13:31:20 2024 daemon.info dnsmasq[3583]: using only locally-known addresses for localh
ost
Tue May 14 13:31:20 2024 daemon.info dnsmasq[3583]: using only locally-known addresses for invali
d
Tue May 14 13:31:20 2024 daemon.info dnsmasq[3583]: using only locally-known addresses for bind
Tue May 14 13:31:20 2024 daemon.info dnsmasq[3583]: using only locally-known addresses for lan
Tue May 14 13:31:20 2024 daemon.err ip_blockd[4271]: Another app is currently holding the xtables
lock. Perhaps you want to use the -w option?
Tue May 14 13:31:20 2024 kern.notice ip_blockd service is enabled, initialized firewall rules
Tue May 14 13:31:24 2024 cron.err crond[4568]: crond (busybox 1.34.1) started, log level 5
Tue May 14 13:31:26 2024 user.notice mwan3-hotplug[4518]: mwan3 hotplug on loopback not called be
cause interface disabled
Tue May 14 13:31:30 2024 cron.err crond[4916]: crond (busybox 1.34.1) started, log level 5
Tue May 14 13:31:30 2024 daemon.info dnsmasq-dhcp[3583]: DHCPDISCOVER(br-lan) 00:e0:4c:68:67:fe
Tue May 14 13:31:30 2024 daemon.info dnsmasq-dhcp[3583]: DHCPOFFER(br-lan) 192.168.2.198 00:e0:4c
:68:67:fe
Tue May 14 13:31:31 2024 daemon.info dnsmasq-dhcp[3583]: DHCPREQUEST(br-lan) 192.168.2.198 00:e0:
4c:68:67:fe
Tue May 14 13:31:31 2024 daemon.info dnsmasq-dhcp[3583]: DHCPACK(br-lan) 192.168.2.198 00:e0:4c:6
8:67:fe Anns-MBP-16
Tue May 14 13:31:32 2024 kern.info Leased 192.168.2.198 IP address for client 00:e0:4c:68:67:fe -
Anns-MBP-16 in LAN
Tue May 14 13:31:33 2024 user.notice mwan3-hotplug[4878]: Execute ifup event on interface mob1s1a
1 (wwan0)
Tue May 14 13:31:40 2024 kern.info Switched to backup WAN (mob1s1a1)
Tue May 14 13:31:40 2024 user.info mwan3track[3793]: Detect ifup event on interface mob1s1a1 ()
Tue May 14 13:31:42 2024 user.notice mwan3track[3793]: Interface mob1s1a1 (qmimux0) is online
Tue May 14 13:31:45 2024 user.notice firewall: Reloading firewall due to ifup of mob1s1a1 (wwan0)
Tue May 14 13:31:49 2024 daemon.notice procd: /etc/rc.d/S96ledman: setting up led LAN1
Tue May 14 13:31:50 2024 daemon.notice procd: /etc/rc.d/S96ledman: setting up led LAN2
Tue May 14 13:31:50 2024 daemon.notice procd: /etc/rc.d/S96ledman: setting up led LAN3
Tue May 14 13:31:50 2024 daemon.notice procd: /etc/rc.d/S96ledman: setting up led WAN
Tue May 14 13:54:09 2024 kern.warn kernel: [ 127.299462] process ‘ntpclient’ launched ‘/usr/sbin
/ntpd-hotplug’ with NULL argv: empty string added
Tue May 14 13:54:09 2024 cron.err crond[5958]: crond (busybox 1.34.1) started, log level 5
Tue May 14 13:54:14 2024 daemon.info dnsmasq[3583]: read /etc/hosts - 12 names
Tue May 14 13:54:14 2024 daemon.info dnsmasq[3583]: read /tmp/hosts/dhcp.cfg01411c - 4 names
Tue May 14 13:54:14 2024 daemon.info dnsmasq-dhcp[3583]: read /etc/ethers - 0 addresses
Tue May 14 13:54:17 2024 daemon.info hostapd: wlan0: STA 16:8d:cb:62:24:43 IEEE 802.11: authentic
ated
Tue May 14 13:54:17 2024 daemon.info hostapd: wlan0: STA 16:8d:cb:62:24:43 IEEE 802.11: associate
d (aid 1)
Tue May 14 13:54:17 2024 daemon.notice hostapd: wlan0: AP-STA-CONNECTED 16:8d:cb:62:24:43 auth_al
g=open
Tue May 14 13:54:17 2024 kern.notice RUT955_5ADE: WiFi client connected: 16:8D:CB:62:24:43
Tue May 14 13:54:17 2024 daemon.info hostapd: wlan0: STA 16:8d:cb:62:24:43 RADIUS: starting accou
nting session 4B89B875D8D9D643
Tue May 14 13:54:17 2024 daemon.info hostapd: wlan0: STA 16:8d:cb:62:24:43 WPA: pairwise key hand
shake completed (RSN)
Tue May 14 13:54:17 2024 daemon.notice hostapd: wlan0: EAPOL-4WAY-HS-COMPLETED 16:8d:cb:62:24:43
Tue May 14 13:54:21 2024 daemon.info dnsmasq-dhcp[3583]: DHCPDISCOVER(br-lan) 16:8d:cb:62:24:43
Tue May 14 13:54:21 2024 daemon.info dnsmasq-dhcp[3583]: DHCPOFFER(br-lan) 192.168.2.168 16:8d:cb
:62:24:43
:62:24:43
Tue May 14 13:54:21 2024 daemon.info dnsmasq[3583]: read /etc/hosts - 12 names
Tue May 14 13:54:21 2024 daemon.info dnsmasq[3583]: read /tmp/hosts/dhcp.cfg01411c - 4 names
Tue May 14 13:54:21 2024 daemon.info dnsmasq-dhcp[3583]: read /etc/ethers - 0 addresses
Tue May 14 13:54:22 2024 daemon.info dnsmasq-dhcp[3583]: DHCPREQUEST(br-lan) 192.168.2.168 16:8d:
cb:62:24:43
Tue May 14 13:54:22 2024 daemon.info dnsmasq-dhcp[3583]: DHCPACK(br-lan) 192.168.2.168 16:8d:cb:6
2:24:43
Tue May 14 13:54:27 2024 kern.notice Password auth succeeded for admin on HTTP from 192.168.2.198
Tue May 14 13:54:27 2024 daemon.err uhttpd[2576]: vuci: accepted login for admin from 192.168.2.1
98
Tue May 14 13:54:28 2024 user.notice mwan3-hotplug[6809]: mwan3 hotplug on mob1s1a1_4 not called
because interface disabled
Tue May 14 13:54:32 2024 user.notice firewall: Reloading firewall due to ifup of mob1s1a1_4 (qmim
ux0)
Tue May 14 13:54:49 2024 daemon.info dnsmasq[3583]: read /etc/hosts - 12 names
Tue May 14 13:54:49 2024 daemon.info dnsmasq[3583]: read /tmp/hosts/dhcp.cfg01411c - 4 names
Tue May 14 13:54:49 2024 daemon.info dnsmasq-dhcp[3583]: read /etc/ethers - 0 addresses
Tue May 14 13:54:49 2024 daemon.info dnsmasq-dhcp[3583]: DHCPDISCOVER(br-lan) 16:8d:cb:62:24:43
Tue May 14 13:54:49 2024 daemon.info dnsmasq-dhcp[3583]: DHCPOFFER(br-lan) 192.168.2.168 16:8d:cb
:62:24:43
Tue May 14 13:54:50 2024 daemon.info dnsmasq-dhcp[3583]: DHCPREQUEST(br-lan) 192.168.2.168 16:8d:
cb:62:24:43
Tue May 14 13:54:50 2024 daemon.info dnsmasq-dhcp[3583]: DHCPACK(br-lan) 192.168.2.168 16:8d:cb:6
2:24:43
Tue May 14 13:54:52 2024 kern.info Mobile data connected (internal modem)
Tue May 14 13:54:52 2024 kern.info Joined LTE network (internal modem)
Tue May 14 13:54:52 2024 kern.info Connected to KPN KPN operator (internal modem)
Tue May 14 13:54:57 2024 daemon.info procd: - init complete -
Tue May 14 13:54:57 2024 daemon.info dfota[6558]: Searching for WAN…
Tue May 14 13:54:57 2024 daemon.info dfota[6558]: WAN found on interface: mob1s1a1_4
Tue May 14 13:54:57 2024 daemon.info dfota[6558]: Preparing for gsm.modem0 update!
Tue May 14 13:54:58 2024 daemon.info dfota[6558]: Searching for updates…
Tue May 14 13:54:58 2024 daemon.info dfota[6558]: No update found!
Tue May 14 13:55:02 2024 cron.err crond[8349]: crond (busybox 1.34.1) started, log level 5
Tue May 14 13:55:03 2024 daemon.info dfota[6558]: Update script done!
Tue May 14 13:55:04 2024 cron.err crond[8442]: crond (busybox 1.34.1) started, log level 5
Tue May 14 13:55:27 2024 kern.notice Bad password attempt for root on CLI (pts/0) from 192.168.2.
198
Tue May 14 13:55:27 2024 kern.notice Failed connection from IP 192.168.2.198, attempt 1/10 (CLI).
Tue May 14 13:56:20 2024 kern.notice IP blocking entry (192.168.2.198 → :4200-4220) deleted.
Tue May 14 13:56:20 2024 kern.notice Password auth succeeded for root on CLI (pts/0) from 192.168
.2.198
Hello, is there any progress on this issue? I included the command output (several days ago) but can add any other information you may need.
After reviewing your troubleshoot file, it appears that you are not experiencing any issues related to mobile connections. The problem may be caused by the failover feature. Please try disabling the failover, and then run a single mobile interface to check if the issues persist.
Hello, thank you for the response. In the webUI, Network > Failover/Load balancing interfaces, I have toggled all interfaces OFF. Is that all required to disable Failover? If so, I am still unable to connect to the internet through the RUT access point. I may be missing something basic, but don’t have enough expertise to figure out what that might be.
Is there a way to get remote assistance to get this router configured properly?
Could you please provide a screenshot of the Status → Network → Mobile page? This would help us understand the issue better. Additionally, please ensure the correct APN is set. Sometimes, the Auto APN feature does not select the correct APN for your carrier.
To set the APN manually, go to Network → WAN and press “Edit” next to the mobile interface. Then, disable the “Auto APN” setting and manually enter the required APN.
Here is the screenshot
The APN settings were provided by our cell carrier KPN when we purchased the data SIM card. Some of the settings do not seem to have data entry fields in the Teltonika webUI. I have attached the KPN recommendations here:
It looks like the mobile signal values on the Mobile Data page are very poor. This might be the root of the issue, especially since it’s surprising that the connection state is listed as “Connected” with such low signal values.
To get a better signal, have you tried changing the location of the device? Also, please ensure that the antennas are attached correctly and standing at 90-degree angle.
The router is installed into an expedition vehicle by BiMobil in Germany. Their network engineers installed it, using an external antenna so I am unable to move the antenna or router. As a troubleshooting measure I swapped the SIM card with a known working SIM from my phone and the poor connection numbers didn’t change much. Do you have a distributor in the Netherlands (where we live ) that we could take our vehicle for diagnostic tests and could possibly fix the issue?
Yes, there are many distributors, but I doubt they offer diagnostic services. It’s possible that during installation, the wrong antenna was connected to the wrong mobile antenna port. Make sure the antenna is screwed into the port marked “Main Antenna.”
For reference this is how my kpn 4g connection looks like
It looks like data is being transmitted and received. Can you access your device via SSH/CLI and execute the following command: ping 8.8.8.8, and provide the output?
2024-05-22-10-59-12-RUT955 w data-only SIM - Teltonika Networks - Teltonika Community — Mozilla Fire
Hello, thank you for your reply. Our camper is at the shop right now and I will be able to test this in a few days. I will post your test when we have it available again.
I will check this after our vehicle comes back from the shop. Thank you.
I’ll be waiting to hear about the results of your testing.
Hello, our vehicle is back from the shop. I am following up on the suggestion to check the antenna is connected to “Main” on the router.
I have done the following, but the results are the same as before - the router does not connect to the internet.
  1. I attached one of the two mobile antennas included in the original router kit to the main antenna access point on the router. I then placed the antenna outside of the vehicle where the cell signal is strong.
  2. I then attached the second of the two antennas from the kit to the AUX point on the router (so now both MAIN and AUX are attached with the original kit antennas.
Neither of these steps resulted in a good signal to the internet. I’ve attached a screenshot of the webUI Network > Mobile status screen:
Does this mean the router itself may need to be upgraded or replaced, and if so what device would you recommend?
On the PING, I may not be doing this right. In the webUI, I went to System> Maintenance > CLI and entered admin and the admin password (to login to the webUI) and got the response as shown in the screenshot.
CLI login is “root” and your password from GUI login.
User “admin” only works on the GUI.
CLI is always “root”.
