Observed when two (2) NTRIP instances are configured, Instance #1 works as expected when enabled and Instance #2 is disabled.
Disable Instance #1, Enable Instance #2 which then indicates in the CLI there is a conflict with Instance #1, Instance #2 appears to be attempting to run with/include Instance #1 configuration variables.
Delete Instance #1 and then what was the 2nd Instance runs ok. Have been able to duplicate this scenario with consistency, between disabling/enabling etc [Save] indicates as completed ok
Summary: A single NTRIP Instance appears fine, with multiple NTRIP config Instances (and apart from Instance #1) other enabled instances want to run with and/or pick up the #1 (disabled) parameters.
