I have installed FW RUT36X_R_00.07.06.10.
When I want to join an external wireless network, i get the error message “2.4 GHz radio(s) have already one client or Multi APs…”
What is wrong?
What is wrong?
First of all you can bring your router to the latets firmware version 07.07.1:
And then your problem might be described here?
To configure in RutOS v7:
Does this help?
Hello @Dobue,
I see that @TeWe already provided some excellent resources for help.
If you wish to stay on firmware 07.06.10 you can follow the 2nd link they provided.
I would recommend upgrading to our latest firmware RUT36X_R_00.07.07.1_WEBUI.bin, which can be found here (RUT360 Firmware Downloads - Teltonika Networks Wiki).
It provides additional software improvements as well as bug fixes, while simplfying the process of adding multiple access point networks.
Updated Wifi configuration information can be found here (RUT360 Wireless - Teltonika Networks Wiki).
NOTE: I would also make sure to delete any new Access Point configurations you were initially trying to create when you received that error.
