RUT260 does not connect to the Orange pl LTE network
Have the same issue as mentioned in TOPIC
SIM Card from Orange PL (260 03) doesn’t work with RUT260, but works With RUT200
LTE modem (in RUT260) can’t get an access to the network, cant’t see any LTE network parameters but I got an information that the LTE provider has blocked access to the network. The strange thing is that the same SIM card works fine on every other device. Moreover, SIM cards from other Polish operators inserted into RUT260 work properly.
Tested on 00.07.22.4 and 00.07.23.6 firmware and SLM828G-EU06_1.57.2_EQ100 LTE modem firmware.
Antennas checked and installed properly.
Tested with settings:
PIN disabled
Auto APN disabled
APN: internet
Authentication type: PAP or CHAP
Username and password: internet
PDP type: IPv4
VoLTE: Auto / On / Off
Network type: 4G Only
Band selection: Auto and Manual
No Data limit
Operator selection mode: Auto
Please help
Are you positive this SIM does not require PAP authentication?
Unfortunately neither PAP nor CHAP work with this SIM
I tested another setting that works: IPv4/IPv6 with internetipv6 APN. The problem is that I need IPv4 with a vpn APN in order to get a public IP.
